Question about Frigidaire 1.6 Cu. Ft. Over-the-Range Microwave
Microwave shorted out when metal grease filter contacted inside
The little metal grease filter fell out of the underneath of the microwave. I was heating up something and tried to put the metal grease filter back in. I got it crooked and it contacted the inside of the microwave and caused a spark. The breaker to that outlet flipped, and now the microwave won't work at all.
Is this an easy fix or should I replace it?
  • 2 more comments
  • shannondowns Jun 30, 2009
    It is a frigidaire FMV156DCB> I looked inside and can't find the fuse.
  • shannondowns Jul 01, 2009
  • William Miller
    William Miller May 11, 2010
    It may have just blown the internal fuse, or it may have also damaged the circuit board, which usually can be repaired. Please reply back with your brand and model number so we can help you.
    Problem Solver:
  • 5 Answers
It might be that the internal power fuse of the MW may have blown. You may have to just replace that fuse if possible. Other wise the electronics (most likely a circuit board) may have been blown.
Posted on Oct 17, 2009
I've got grease dripping down from the top left inside corner of my otr microwave. I've cleaned the grease filters. Is it a problem with the vent to the outside?
Without a long explanation as to why but they will get a build up. At this juncture i would be prudent to just clean it well. Because it will require you to remove the outer cover, you must disconnect it. Be careful when you do this, no metal objects. It has parts that store electric. Once you open it you will see the build-up. Do not open the metal box, it is the part that stores the electric.
Nov 10, 2013 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Paint inside microwave is chipped and blistered. How do you fix it?
HI,
If you are able to spent money for a new Microwave then go for a new one.
If you are interested to repair and reuse the existing Microwave then keep on thing in mind, if you paint it then also it will not lasts for a long time as the metal underneath is rusted.
Ajin
Jul 14, 2012 | GE Microwave Ovens
I have a new JVM1750 just installed yesterday. There was some arcing, in what looked like underneath, a white circular disc in the ceiling of the internal cavity. Have checked for foil - none inside the...
That is your stirrer cover.
Any arcing there is usually due to grease or food particles, so on a new oven that would be as mystery.
But any time you get arcing under it, it has to be removed and cleaned.
Oct 12, 2011 | GE Spacemaker JVM1750 Microwave Oven
Sparks are coming from behind the little revovable plate inside the oven.
these covers are made of a mica material; and tend to get grease-soaked from food splatter. this is where the microwaves pass through. if cover is burned, you will need to replace and clean greasy mess underneath. hopefully, the magnetron is not damaged.
Aug 06, 2011 | Jenn-Air JMC9158AA Convection Microwave...
WMH 1162X VS -1 (watts unknown) Builder purchased
If the oven is set up to vent outside, then the metal mesh grease filters are used, and they should be cleaned in warm soapy water whenever they look greasy or dirty.
If the oven is set up to recirculate, then the charcoal filter is used, and it must be replaced (not cleaned) every 6-12 months, depending on use.
This model does not have a separate cooling fan like most other models. It replies on the vent fan for magnetron cooling, so if the filter(s) gets too dirty, it can reduce the cooling air flow, which can allow the magnetron to overheat and be destroyed.
I would need to know a little more to help narrow down the "no heat" problem.
If the cooling fan, turntable, and inside light all come on when you press "Start" to cook, then I would ask if you here a "thump" when you press "Start."
If so, then the high voltage section is getting energized. If not, then it may be the cook relay on the control board, which I can affordably repair.
The support page for your oven is here, and it has manuals and part lists you can download.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 10, 2017 | Whirlpool WMH1162XV Microwave Oven
How to set it to high, med or low
Grease filters can be cleaned, according to your manual.
If you've misplaced yours, it's online here.
Charcoal filters cannot be cleaned and must be repaired.
From the manual:
Reusable Grease Filters
The reusable grease filters should be cleaned at
least once a month. Never operate the
microwave without the filters in place. In
situations where flaming might occur on
surfaces below the hood, filters will stop the
entry of flames into the unit.
To Remove Grease Filter
To remove grease filter, grasp the “finger hold”
on the filter and slide to the rear. Then pull filter
downward and to the front. The filter will drop
out.
To clean Grease Filter
To clean grease filters, soak and then agitate
filter in solution of hot water and detergent. Do
not use ammonia or ammonia products because
they will darken the metal. Light brushing can
be used to remove embedded dirt. Rinse, shake
and remove moisture before replacing.
To Replace Grease Filter
To replace grease filter, slide the filter in the
frame slot on the back of the opening. Pull filter
upward and to the front to lock into place.
May 27, 2010 | Microwave Ovens
My NN-S254 Microwave comes on intermittently, mostly dead
Try cleaning (pull the power cord plug first) the inner side of the sheet metal waveguide which may have a layer of grease that could short out the microwaves. This waveguide runs from the magnetron base over to the cooking cavity and usually can be removed by undoing some sheet metal screws along it's length. There is a fan-like device called a 'stirrer' that is located near the cavity opening under the wave guide and it should be cleaned also along with the cavity entry window. Hope this helps!
Nov 11, 2009 | Panasonic NN-S254BF Microwave Oven
Does this microwave oven use charcoal filters
Hi.
The only time your microwave will use a charcoal filter is if it is mounted over the stove, as a microhood, and discharges into the room, rather than up a stack. If yours is set up as a hood, you'll have the woven grease traps underneath, and the filter will be behind the upper grille.
Best regards, --W/D--
Aug 12, 2009 | GE XL1800 1100 Watts Microwave Oven
Wrong Grease Filter for Sharp R-1870 Microwave
I also have a Sharp over the Range Microwave oven that requires a charcoal filter. But my diagram shows that the charcoal filter goes behind the slotted panel at the top of the microwave. To reach the filter, you must remove a screw on the top edge of the microwave. This allows the panel to come off. Your charcoal filter goes there. Since your oven is new, you do not need to change this filter yet because it's not dirty. I would save it for future use.
According to my book, there are two kinds of filters with this oven. The charcoal filter is the one behind the front panel. The Grease filters ARE the two metal mesh ones. They can be cleaned with hot soapy water, or I put mine in the dishwasher.
Mar 14, 2009 | Sharp R-1480 Microwave Oven
Ge profile spacemaker XL 1800 undercabnet microwave
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Sep 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire 1.6 Cu. Ft. Over-the-Range Microwave Logo
425 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
