Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
The electric clutch on my cub cadet lt1045 does not stay running
When I start to use the mower, the pto will turn on just fine, but then after you mow a few mintues it shuts off. Sometimes I can get it going again, but it usually quits at least once every round I do. I just had it in to cub cadet dealer for this problem and he replaced a relay (and charged me $35 to replace a perfectly fine belt) but it still acts up all the time.
I had the exact same issue early this mowing season on a LT1045 with 184 hours on it. On a wild hunch I lifted the seat and simply sprayed the PTO shut-off safety switch with electronic contact cleaner/enhancer and have had to problems since.
Posted on Jun 14, 2010
    Genius:
  • 1,114 Answers
So, it's not the relay, and the clutch does work- when it's working. Have you checked the wiring connections; from primary to relay, from switch to relay, from relay to clutch, etc. Also, I would check the switch contacts and the engage switch itself. It may be defective.
One way to possibly track down the problem is to start the mower in neutral and engage the PTO. While the mower is running and the deck is engaged, go over the wires and connections to see if you can find the source of the problem by giggling the plugs and connections. Just be careful of the rotating blades!
Posted on Jul 02, 2009
  • Joel Grant Aug 09, 2011
    Why it has not been mentioned I do not know, but the most likely problem when the clutch works with the mower cold, but will not re-engage when hot is simple misadjustment of the clutch magnet gap. Very VERY easy to fix. Just get underneath with a thickness guage and tighten the 3 lock nuts until you can just barely move a 0.012" shim in and out of each of the three slots between the adjustment nuts. The shim should travel about 2/3rds if the way to the core of the clutch. As the coil in the clutch gets hot, electrical resistance increased and the power of the clutch decreased; this is why it will work cold but not hot. If the clearance is beyond 0.018", clutch enguagement will be slow and unreliable.
  • wildcat_4646
    wildcat_4646 Sep 20, 2012
    Joel is 100% right
Joel Grant is 100% right
Posted on Sep 20, 2012
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
Rider will not turn over more than once no matter how many times I try.
I sounds like there's significant resistance to the engine turning over. I experienced this when the electric PTO/clutch seized - and the mower was trying to turn over the engine AND the mower blades because the PTO wasn't disengaging. Try taking the mower belt off the PTO and see how the engine turns over. If it's still slow, the problem is in the engine. If it spins normally, replace the PTO clutch. BTW - when my clutch seized, it also burned out the PTO switch. The switch is pretty inexpensive, so if you're replacing the PTO/clutch (I found one online for about $175.00 - MUCH more expensive at the dealership) - you should probably replace the switch as well.
Jun 28, 2014 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I need part no. for manufacture date 2005 cub cadet lt 1045 modle ps-sv600 0009 pto clutch
I have a 2005 Cub Cadet LT1042, Spec. No. PS-SV590-0003, but my parts manual also lists part numbers for the LT1045. The clutch part no. given for your model is 717-04174.
Hope this is helpful.
Paul
May 10, 2013 | Oregon Scientific Electric PTO Clutch for...
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
PTO WONT WORK on myCub cadet ride on mower LT 1045
i seems you already found the cause its a electrical problem look at all the wires you have a loose connection some ware the wires also like to break where they go into the clutch
Jun 28, 2012 | Cub Cadet Garden
Pto shuts off durning mowing
hook up a test light so you can see if it looses power when it shuts off
May 14, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub cadet riding mowe
is the mower making any sounds when u crank it or nothing at all?
Feb 07, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Blown fuses when mowing
you have a wire that is shorting out somewhere, i would trace the wires from the clutch all the way back to the fuse including the relay and pto switch. You will more than likely find your problem in the control circuit between the fuse, pto switch and relay since this is what is fuse protected.
Aug 06, 2009 | Oregon Scientific Electric PTO Clutch for...
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
4,353 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
