Gemsound XP 550 blown fuse
I bought this amplifier about 14 months ago, out of warranty, of course. It is a Gemsound XP-550 power amp. I used it for the forst time this past weekend and it worked great for about 2 1/2 hours, then blew a fuse.
The answer I received made sense, probably the outputs are blown and to return it under warranty. Unfortunately, I was using this as a back up amp and have had it for over a year when I first used it, so the warranty is no longer valid.
I was sent a schematic but of course, I have no knowledge of the internal workings. A friend looked at it and ran some specs on diodes on the output and said they read wrong. Is there something beyond replacing these diodes that I should figure? I live close about 40 miles southeast of Seattle, WA and wondered if there was a place here I could take it to and have it repaired? Or any suggestions would be helpful.
Thanks, Cecil McWilliams
  • 4,234 Answers
This is a standard amp design which should be a relatively simple repair. The output transistors are probably shorted. Check those first. Second, check the rectifier diodes in the power supply. Usually there are protection circuits that will prevent the fuse from blowing if the outputs are shorted.
Let me know your progress. I will attempt to get the service manual for this unit to get you more details.
Dan
Posted on Jun 29, 2009
Ren 550 s amp does not have blown fuse but is not working
Chances are that you have internal problems with your amp, they have a 1 year warranty so I would check to see if you can get an RMA to get it fixed or replaced. They still sell this model, so chances are good you may be covered. It seems like these are mostly sold in Europe, Onlinecarstereo.com sells them as an authorized seller. To get the 1 year warranty you probably will need to have bought this from an authorized dealer. But try anyway.
http://www.renegadecaraudio.com/renegade_rens_amps.htm
Apr 02, 2013 | Renegade REN 550 S - 550W 2-Channel Car...
Gemsound xp-550
A diode/rectifer or voltage stabliser, or leaky capacitor in the power supply.
Also the main transistors in the power amp or if it has an output IC - that!
If you can in anyway disconnect the power supply section from the amp circuit, you can isolate which part is faulty. For if it blows when disconnected from the power amp, you know it's just the power supply that's gone. And if it does not blow - then it's the amp!
Aug 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
GemSound XP-550, worked great for about 2 hours
The outputs are probably blown. This should be under warranty. Return it for a replacement.
Dan
Jun 29, 2009 | Audio Players & Recorders
Gem sound exa 3950 amp
Hi...
If it's a straight-up power switch then it will need to be replaced if it works off a relay then the relay is gone.
website
http://www.gemsound.com/contact.html#
Mar 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Jl 500/1 amplifier will not turn on
you may have burned the channel you were using..try taking the cover off the amp and checkin for burned spots or any wires that may be loose or touching within the amp.
Feb 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
My amp
where is your location my friend? did you check your amps power input requirements. you may be having the wrong voltage supplied to your amp. unless there is a defect on the amp unit you bought otherwise check your voltage settings first
Aug 11, 2008 | Audio Players & Recorders
Gemsound power speaker pxa105
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
Apr 07, 2008 | NAD C350 2-Channel Amplifier
207 people viewed this question
 Grubhead
Grubhead
