Question about HP Pavilion dv5-1000us Notebook PC
Red audio mute LED remains on, even though it still works.
2 Suggested Answers
shynysaxena
  • 166 Answers
SOURCE: red audio mute LED remains lit, even though LED
Yeah i can understand. Many HP Pavilion users & compaq users are facing same problem. Its due to the reason that the XP or Vista is not properly synchronized with their sound drivers & hence not capable to controlling that LED connected internally to sound hardware.
And also few people found out that LED is totally electrically-SHORT and hence permanently on and has no control from software.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Posted on Jun 29, 2009
Proscan 42" LED 120hz TV no audio out except with hdmi
Look for the setup menu on the TV. It is common that you need to select either TV speakers or external speakers as only one will work at a time. If you want the sound to come out the audio output, you may need to select this option. Worth checking.
Dec 08, 2017 | Televison & Video
About a year ago I noticed that the LED on my mute button will not light up/turn on when I first power on, even though the rest of the media controls light up. The result is that I lost the ability to...
WHAT OS? XP?
learn to use the control panel. (more later)
the special keys like this can fail for 3 reasons (get it serviced)?
  1. bad hp keyboard driver, (or wrong one, or missing)
  2. virus infecttions (or worse root kit attacks)
  3. bad key.
click start.
click control panel
see sound?
now click tab sounds
in the top roller button , pick no sounds (bingo all sounds gone)
error sounds and all
or pick any sound seen there, and make it go dead, or change it to any thing, (endless, choices) even sound of silence. is possible
like this , nosound.wav.
or to pindrop.wav
May 09, 2017 | HP Pavilion dv1000 Notebook
Red audio mute LED remains lit, even though LED touch-control still turns speakers on/off.
With regards,
Shyny Saxena
Jun 29, 2009 | HP Pavilion dv5-1000us Notebook PC
The audio light is red whether the sound is muted or not
1) Try updating your sound drivers, they probably control the light. It could be a hardware issue, and if the drivers don't work, there may not be any solution for you.
2) You should go into control panel and into your sound settings. There should be a number of devices listed. One of them is your HDMI output. You need to click on it and set it to the default sound output device. When you unplug your HDMI, you may need to do this again to get your regular computer speakers working.
Jun 22, 2009 | HP Pavilion dv7-1130us laptop
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
HP Pavilion Entertainment PC
I was having a similar issue. My volume button worked fine muting and unmuting the volume, the light just stayed red either way.
I went into Device Manager, then expanded the Sound, Video and Game Controller options, I rolled back the driver and it was an instant fix for me :)
Jun 07, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Innovage jumbo universal remote
TV codes 0013, 0018, 0028, 0031, 0034, 0043, 0046, 0052, 0058, 0072, 0081, 0084, 0134, 0135, 0141, 0150, 0162, 0182, 0187, 0199, 0208, 1019, 1033, 1036, 1071, 1077, 1149, 1150
vcr codes 4015, 4032, 4012, 4020, 4052, 4017, 4039
Turn on device that you want to set
Aim remote at the device
Press the device button for the item you wish to program and the LED will blink once
Press and hold the set button unti the LED lights up solid red
Using the number keys, enter the 4 digit code from the list. After you have entered the 4th digit, the LED will turn off, indicating that the code for the device was recognized.
If the device powers off, test the functions for the other buttons (except OK button). If all the functions work, press the OK button to store the code. If the indicator light remains solid red after blinking 3 times the code is incompatable. You then need to restart back on step 2.
Make a note of the correct 4 digit code for future use.
COde search setting is an alternative method to programming your device without using the code list
Turn on the device you want to set
Aim the remote control at the device
Press the decive button for the item you want to program
Press and hold the SET button until the LED light up solid red
Press the MUTE/SEARCH button. The LED will shut off first then light up solid red.
When the device turns off, press the OK button to store this code.
Code Retrieval
Press and hold the device button you want to display on the remote control
Press the NUMBER 1 then count the number of flashes
Press the NUMBER 2 etc
Press the NUMBER 3 ets
Press the NUMBER 4 etc
If the LED light flashes 10 times the number is 0
Jan 23, 2008 | Audio Players & Recorders
Cant get the red led light green again
Disconnect all input and output cables and check. If the light stays red, it suggests an internal error. If not, proceed by first connecting the Sub wires and checking, then the input RCA's and checking. Remember to switch off the system before connecting/disconnecting, I suggest also removing fuses during this process.
Mar 11, 2007 | Pioneer GM-232 Car Audio Amplifier
HP Pavilion dv5-1000us Notebook PC Logo
200 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
