Question about Jenn-Air JGS8750 Gas Kitchen Range
Touchpad buttons dead
The 4,5,6,8,0 Convect Bake and Meat Probe buttons on my Jenn-Air JGS8750 suddenly died. I cycled the power (off & on) but still dead. Any suggestions?
  • jc manual Nov 11, 2007
    have the same Problem on jenn air model jgs8750 (occurrred on nov
    10.2007), there have similar problem to other jennair/maytag model.
    The owner of these company is WHIRLPOOL. IHOPE WHIRLPOOL IS AWARE IS
    PROBLEM. this one of many site reoporting similar problem )
  • lowa Dec 01, 2007
    jenn-aire model svd48600w. i replaced defective control clock i cannot cancel oven to turn off. i must reset the oven temp to 0 degrees to shut it off. any solutions?
Most people don't know there is a 5 year warrantee on solid state electronics. or else i found the part on I don't know if they will be cheaper
Posted on Dec 18, 2007
Get your wallet out. About $600.00
Posted on Dec 08, 2007
F3E3 Meat probe Shorted
faulty meat probe, probably a factory defect, if still covered by warranty, return oven for replacement.
Mar 22, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
1c2c is on controls of jenn air wall oven. not working m#JMW8530DAS
We've had a Jenn-Air wall oven & microwave, Model #JMW9530DAS for 9 years. We never had any problems with it except for the irritating dust that collects between the oven glass. After returning from a 10 day vacation, we got a 1c2c error code when pressing "Bake." The oven worked fine before we left so we were baffled. We tried other settings like "Broil" "Convect" to no avail. It kept telling us to call for assistance. We tried shutting off the power to the unit for a few minutes but got the same 1c2c error again. So we called a local appliance repair shop (associated to the appliance store we purchased the unit from) and paid a fee to have him assess the problem. He really couldn't pinpoint the problem but suggested it "could be the membrane or the controller." And, to top that, he said Jenn-Air stopped making the membrane but they are going to start making them again and we could get one in 6-8 months at a cost of $500. So now we were looking at a $300 controller & possible $500 labor. We were so frustrated that we decided to tackle the problem ourselves before going out and buying a new oven. We shut the power off and tried pulling the oven out of the wall. Too heavy. After about 20 minutes of the power off, we turned it back on and decided to use the "SetUp" feature as if we were using the oven for the first time, following the directions in the instruction manual. We stepped through the process (clock, auto convect, language, C/F, etc...) then pressed the "Convect" button (instead of "Bake") and voila! It worked! After the Convection Bake Preheat worked successfully, we pressed "Bake" and it worked, too. We just saved ourselves over a thousand dollars as we were going to get rid of the piece of junk. So, before you give up, try turning the power off for a half hour & use the SetUp key and walk through the process.
Feb 13, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
Funny - didn't ask about a slide in electric kitchen range - was asking about my Jenn Air Stove. You deal with them, correct? Have a Jenn Air WW2780B that I can't seem to get working. It started...
I had a customer with the same problem last month and I believe it was on the same model as yours. Let me look in my database and I will get right back to you.
Warmest regards,Richard
Nov 01, 2011 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Nov 04, 2009 | Jenn-Air SCE30600 Slide-In Electric...
My Jenn Air oven is asking me to remove the meat probe. The only thing I did before it asked me to do that was to turn it try to preheat the oven to 350 degrees
you could have a bad probe receptacle. Or a board problem. Kill power to oven, wait 10 min, cross your fingers and restore power.
Oct 26, 2009 | Jenn-Air Ovens
My meat probe on my jenn-air electric stove works but no beep
you may need to scroll through your settings to turn the beep on
Nov 25, 2008 | Kitchen Ranges
Jenn-Air Gas Range
F1 is a bad power relay board.
F8 is a shorted meat probe alarm (probe jack or the harness to the probe jack)
Dec 19, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Meat probe button on control pad
there is no real way to reset it you reset it when you turned the breaker off, It sounds like the EOC (electronic oven control) is faulty. I would just keep reset it and keep doing that to bake the turkey how hot will it get before it buzzes? is it showing any error codes?? F1, F2, F3 etc.....
Sep 30, 2007 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air JGS8750 Gas Kitchen Range Logo
371 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
