Question about Poulan Ght225 25cc Gas Hedge Trimmer
How do I replace the fuel line? When i replace the
How do I replace the fuel line? When I replaced the line, I connected the filter to the fuel Line but when I try to prime the line, fuel spills out the vent line.
  • 11 Answers
SOURCE: Poulan S25 Chainsaw - fuel line replacement
should only be top cover and access fuel line through filler cap with long nose pliers first remove line from carb
Posted on May 14, 2009
#1 Taper
  • 1041 Answers
SOURCE: How to you repalce a fuel line on a weedeater gb1/22v leaf blower
When replacing fuel line, make sure that you have the correct size lines. Depending on the size of your engine, the lines may vary in size. The primer bulb line will sometimes be larger in diameter than the fuel line to the carburetor. The primer bulb line will be the shorter of the two. When replacing the fuel line, make sure you have enough line to go from the bottom of the tank up to the carburetor. Give yourself a couple extra inches to work with. Cut one end at an angle, this makes it easier to feed down through the hole. Continue feeding the line until it comes out of the gas cap hole. Then cut the end of the line square again and attach the fuel filter that goes on the end of the line. Place the filter back in the tank, then adjust the line so that the fuel filter lays comfortably at the bottom of the tank. Then attach the other end of the line, (where you inserted it), to the carburetor, cutting off any extra line you may have.
Posted on May 23, 2009
#1 Taper
  • 1041 Answers
SOURCE: Fetherlight xt200 fuel line connections
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
dontbother10
  • 2220 Answers
SOURCE: How to connect the fuel lines for Poulan Model # 1950 Chain Saw
The following link should be very helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
A link to a Poulan model 1950 Type 7 follows (may not be your saw, there are 7 different Types and 2 Woodsharks (LE))
http://www.ordertree.com/modelinfo/PWE/1950-Gas-Saw-Type-7/75.1950-Gas-Saw-Type-7.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 22, 2010
  • 2239 Answers
SOURCE: Walbro WT891 carb on a
Who connected these hoses? the normal routing for a machine with a primer is like this, the fuel hose from the tank with the filter on the end goes to the carb fuel inlet nozzel ( not to the primer ) nearest to the pump cover ( cover on carb held with one screw ) the pipe from the metering side of the carb connects to the shorter nozzel on the primer bulb ( suction side ), the longer nozzel on the primer ( pressure side ) connects to the pipe going back to the tank, just remember the primer pulls fuel from the carb,into the bulb, and pushes it back into the tank, it is not actually a primer it is a purge. because it is connected this way it is impossible to flood the engine no matter how many times the bulb is pressed.
Let me know if it starts and runs.
Posted on Jan 31, 2011
How to change the filter and line from pump to filter
Should not change all the fuel line .Cut the bad line fuel and Measure the required distance . and take with you the bad line fuel to Advance Auto Parts . and ask him for new line and fuel filter and Link to connect the line fuel together , make sure no leak . good luck .
Nov 21, 2011 | Chevrolet Lumina Cars & Trucks
How do I install a new fuel filter?
Important: There is no service interval for in-line fuel filter replacement. Only replace the in-line fuel filter if it is restricted. 1. Relieve the fuel system pressure. Refer to the 2. Raise the vehicle. 3. Remove the fuel feed quick-connect fitting (4) at the inlet of the in-line fuel filter (3). 4. Remove the threaded fitting at the outlet of the in-line fuel filter (3). 5. Drain any remaining fuel into an approved gasoline container. 6. Inspect the lines for cuts, swelling, cracks, and distortion. Replace the lines as required. 7. Inspect the O-ring on fuel filter outlet pipe for cracks or damage. Replace the O-ring as required. 8. Inspect the fuel vent pipe (2). 9. Inspect the fuel return pipe quick connect fitting (1).
Oct 21, 2011 | 1999 Oldsmobile Aurora
Can you replace an inline fuel filter without replacing the whole gas tank?
the in-line filter is in the fuel line between the tank and the engine, seldom do you have to even touch the tank much less remove it in order to replace that filter. there is a screen on the pump inlet of the
in-tank fuel pump and most likely you are going to have to drop the tank in order to replace the pump or the fuel level sender. make sure there is not a service access hole in the rear of the car such as under the spare tire which could give you access to the top of the tank. on the other hand it is not unusual to find yourself in a situation where a lot of the fuel line must be replaced when you replace the in-line filter. as such you may find yourself with no room to connect the new fuel line to the nipple on top of the tank, without lowering the tank a bit.
Jul 05, 2011 | 1997 Isuzu Rodeo
I need instructions on replacing the line on our Remington Lawn Trimmer
Hi pwdw71...
You will need to go to the lawnmower/weedeater parts house with a sample of both lines to be able to replace the lines with the right size fuel lines.
Also check/clean/replace the fuel filter inside of the tank.
Also take your Mfg. and model number with you.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.
The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru and primed the carburetor by the primer bulb.
You will insert the big line into the fuel tank far enough to be able to install the fuel filter.
Free Answer...Please take time to rate me
Jul 04, 2011 | Electric Garden
LOCATION OF FUEL FILTER 1999 BUICK PARK AVE
It's on the left hand frame rail, in front of the left rear tire.
107125379
CAUTION: Refer to Caution in Cautions and Notices.
  1. Remove the quick-connect fitting at the fuel feed pipe (3).
  2. Remove the threaded connection (2) at in-line fuel filter.
IMPORTANT: Inspect the O-ring on fuel filter outlet pipe for cracks or damage. Replace as required.
  1. Inspect the fuel lines, O-rings for cuts, swelling, cracks, and distortion. Replace the lines as required.
  2. Inspect the fuel return line (4).
  3. Inspect the fuel vent pipe (1).
  4. Drain any remaining fuel into an approved gasoline container.
  1. Remove the protective caps from the new in-line fuel filter.
  2. Install the new plastic connector retainers on the in-line fuel filter inlet and outlet.
Install the new plastic connector retainers in the same position as on the old in-line fuel filter.
  1. Install the quick-connect fitting (3) at the inlet of the in-line fuel filter.
IMPORTANT: Make sure that the O-ring is installed on the outlet pipe before installing the pipe
  1. Install the threaded connection (2) at the in-line fuel filter.
Tighten
Tighten the in-line fuel filter outlet nut to 30 N.m (22 lb ft) using a back-up wrench in order to prevent the nut from turning.
  1. Lower the vehicle.
  2. Tighten the fuel tank filler pipe cap.
  3. Install the negative battery cable.
7.1. Turn the ignition switch ON for 2 seconds . 7.2. Turn the ignition switch OFF for 10 seconds . 7.3. Turn the ignition switch ON 7.4. Check for fuel leaks.
Oct 20, 2010 | 1999 Buick Park Avenue
Change the fuel filter
The fuel filter will be located above the fuel tank. You will need to remove the front fuel tank strap to change the filter. Make sure you relieve fuel pressure before removing the lines otherwise gas could potentially spray everywhere including all over you! Remove the two lines from the filter (sometimes there is just one) remove the bolt that secures the filter to the tank. Remove the line from the filter to the metal fuel line.
After you install the new one make sure the connection is solid where the plastic line from the filter connects to the metal line. This connection is the one that fails quite often after the filters are replaced!!
Sep 26, 2010 | 2003 Dodge Grand Caravan AWD
1987 Cutlass Supreme not turning on. Think fuel system?
Fuel Filter REPLACEMENT Gasoline Engines The fuel filter is located behind the fuel inlet connection on the carburetor. On 1976–87 vehicles fuel filters incorporate a check valve and are not interchangeable with earlier years. Replace the fuel filter every 15,000 miles (24,135 km), or sooner if engine flooding is a problem. Fig. 1: Hold the large fuel inlet nut on the carburetor while using a flare wrench to loosen the line connection 86681247.jpg
  1. Using an open–end wrench (preferably a line or flare nut wrench), loosen the fuel line connection from the larger fuel filter nut. You will have to hold the other nut with a wrench to keep it from turning. Most of the time these units are quite difficult to remove. It is a good idea to apply a lot of penetrating oil to the threads and then tap the nut lightly.
  2. Once you have the fuel line disconnected from the carburetor, remove the larger nut from the carburetor with a box–end wrench or socket.
  3. Remove the filter element and spring from the carburetor.
  4. Check the element for blockage by blowing through the fuel inlet end. If the element is good, air should pass through easily.
  5. Once you have checked and/or replaced the filter, reinstall the carburetor nut and the fuel line. Be careful not to strip the threads. Fig. 2: Install the new spring and filter in the order they were removed 86681248.jpg
Jul 13, 2010 | 1987 Oldsmobile Cutlass Supreme
Replace fuel filter
The fuel filter is located near the rear of the vehicle, forward or rearward of the fuel tank, depending upon application. There is no service interval for fuel filter replacement. The filter only is replaced if it becomes restricted.
REMOVAL & INSTALLATION Relieve the fuel system pressure at the shrader valve on the fuel rail. For details regarding this procedure, please refer to Fuel System of this information.
  1. If not done already, disconnect the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Clean both fuel feed pipe connections and the surrounding areas at the in-line fuel filter with a clean rag to avoid possible contamination of the fuel system.
  4. Using a backup wrench, remove the fuel line fittings from the fuel filter. Most of the models fuel gilter wrench sizes will be 16mm and 20mm.
  5. Either disconnect the quick-connect fittings by pushing inward toward the filter and grasping the plastic tab around the connector and pull them apart. Or remove the fuel filter mounting screws, then remove the filter from the vehicle.
  6. Discard the fuel line O-rings and replace with new ones during installation.
To install:
Install new O-rings to the fuel line fittings.
Connect the fuel lines to the fuel filter.
Position the filter in the same position it was during removal. Using a backup wrench, tighten the fuel lines to 20-22 ft. lbs. (27-30 Nm).
  1. Install the fuel filter mounting screws if used.
  2. Lower the vehicle. Install or tighten the fuel filler cap, then connect the negative battery cable.
  3. Start the engine and check for leaks. Turn the ignition switch to the ON position for two seconds.Turn the ignition to the OFF position for ten seconds. Turn the ignition to the ON position. Check for leaks.
Jun 07, 2010 | 1992 Oldsmobile Ninety Eight
Fuel line replacement on Poulon 2050 14 inch Gas Chain Saw
First rule is to replace only one line at a time. Needle nose pliers is the only tool you should need. Replace the fuel line from the filter in the tank to the carburetor by removing the filter from the line, extract the line out of the tank, and remove the other end from the carburetor. Use the old line to measure for the replacement. Measure the point where the old line passed through the tank wall down to the filter connection. Mark this point on the new line, and push the line into the tank far enough to attach the filter (which you have checked for plugging), then pull the line back out to the mark. Make sure that you use the proper line for this connection as the filter must flop around to the lowest tank level so that the saw doesn't run dry of fuel when operated on it's side. The other connections are straight forward--just replace one at a time. Don't be stingy in making looping turns as you don't want future kinks. Hope this helps!
May 02, 2010 | Poulan 14" Chainsaw
Replace fuel filter
  1. Relieve the fuel system pressure. For details regarding this procedure, please refer to Section 5 of this manual.
  2. If not done already, disconnect the negative battery cable.
  3. Raise and safely support the vehicle.
  4. Clean both fuel feed pipe connections and the surrounding areas at the in-line fuel filter with a clean rag to avoid possible contamination of the fuel system.
  5. Using a backup wrench, remove the fuel line fittings from the fuel filter.
  6. Either separate the quick-connect fittings or remove the fuel filter mounting screws, then slide the fuel filter out of the mounting bracket.
  7. Discard the fuel line O-rings and replace with new ones during installation.
To install:
  1. Install new O-rings to the fuel line fittings.
  2. Connect the fuel lines to the fuel filter.
  3. Position the filter in the mounting bracket, in the same position it was during removal. Using a backup wrench, tighten the fuel lines to 16 ft. lbs. (22 Nm).
  4. Install the fuel filter mounting screws.
  5. Carefully lower the vehicle. Install or tighten the fuel filler cap.
  6. Connect the negative battery cable.
  7. Start the engine and check for leaks.
Location of the fuel filter
Unfasten the retaining bracket can make removal of the fuel filter easier
Either use a clean rag or compressed air to clean the surrounding areas of the filter
Use a backup wrench to disconnect the fuel line fittings from the filter
Disengage the quick-connect fittings, then remove the filter from the vehicle
In-line fuel filter mounting and related components
It sits in front of the fuel tank.
Dec 07, 2009 | 1992 Buick Riviera
Poulan Ght225 25cc Gas Hedge Trimmer Logo
169 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
