Question about Canon PowerShot S400 / IXUS 400 Digital Camera
I have a Cannon Powershot A430....Message is Memory Card Error. Book says that means card anomaly? What the heck is that?
  • Canon Master
  • 4,738 Answers
The card's filing system has likely become corrupted. This usually occurs with time if the card was never formatted for the camera. It will work at first, but this eventually happens. But this can be corrected. First of all, you'll probably want to recover the photos that are already on the card. For this you'll need recovery software (plenty of freeware available):
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will need to use a flash card reader with this software. If you don't have one, get one, they're cheap:
http://www.amazon.com/s/ref=sr_st?keywords=card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acard+reader&sort=price
AFTER you've recovered the photos, format the card in your camera to prevent this from happening again (dig out that instruction manual to figure out how). For Canon cameras, normally just go to the tools menu, select the item stating the card's capacity, and then follow the on-screen prompts to format (select "low-level" if asked). BUT keep in mind formatting will also totally erase your card, so again only do this after you've recovered the photos!
Posted on Jun 30, 2009
    Scholar:
    New Friend:
  • 30 Answers
Do you have anything important on this camera memory card?
If not, you can directly format this camera memory card to see whether this card error can be fixed. Otherwise, you have to replace it as soon as possible.
But, if you do have important data there, you'd better never format it before you've restore all needed data back in case of any data loss.
Here are some detailed steps for you to restore all your data back:
1. Do NOT click "Yes" to format this memory card in case that the formatting process makes things worse.
2. Do NOT attempt to write anything new on this memory card in case of any data loss.
3. Download data recovery software to help you. There are many data recovery tools out there. But, no all of them could be efficient and useful enough. You should pay much attention to opt for a proper one.
So, if you are interested, you can firstly try a memory card data recovery freeware:
http://freeware-fix.blogspot.com/2013/04/memory-card-error.html
It always can thoroughly scan a card and do its utmost to restore all scanned data back successfully.
Here is some detailed information of this freeware:
http://not-formatted.blogspot.com/2013/02/recover-data-from-not-formatted.html
4. Do not save or back up all the restored data on the same card in case of any data loss.
5. After the data recovery process, simply format this card to see whether it can work functionally as before.
In the future, you should learn a lesson to be more careful about your data and always back it up well.
Posted on Dec 21, 2013
Memory card error
What type and size memory card? The A430 works with SD and MMC cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Sep 27, 2013 | Canon PowerShot A430 Digital Camera
Just installed a new memory card in my powershot A430 and the camera says memory card error, card is locked. how do I unlock?
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 28, 2012 | Canon PowerShot A430 Digital Camera
I`ve bought a 4GB memory SDHC memory card to my Canon powershot A 430 camera, and when i put it in my camera - it says memory card error. I tried to unlock it by the small button, but didin`t help. What...
The Canon A430 uses MMC and SD cards. While SDHC cards will fit into the slot they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Dec 24, 2010 | Canon PowerShot A430 Digital Camera
I can't find a driver for my cannon powershot a430 using xp
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 16, 2010 | Canon PowerShot A430 Digital Camera
Cannon Powershot A540 SanDisk SDHC 4 gb I insert the card and receive a memory card error. Can't format
A 4 gb memory card is beyond the capacity of your Cannon A540. It is too large. I would stick with a 1 gb card in that camera.
May 28, 2010 | Canon PowerShot A540 Digital Camera
Memeory card error
The problem seem to be the card reader in the camera have contact problem, first thing is to ensure is there anything inside the hole where you insert your mem card, second ,try to use contact cleaner to clean up the card reader .hope it help.
Aug 20, 2007 | Canon PowerShot A430 Digital Camera
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
172 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
