Question about Whirlpool Duet GHW9150P Front Load Washer
The front drum seal of the whirlpool duet dryer peeled-off.
How do you replace the front drum seal of a whirlpool duet dryer? The dryer model is GEW9250PW0.
  • 15,935 Answers
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn't cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
My plastic drum seal on my Whirlpool duet front-loading washer is chipping apart. The drum doesn't run true, is wobbly and has a rhythmic rub when turning. How do I replace the drum seal? Model GHW9100LW.
You have more serious problem than just your drum seal. The support arms in the wash tub are broken. The wash tub should always spin true. When it wobbles it is a sure sign that the suport arms or spider arms are broken. It is an expensive repair since the wash drum, the outer plastic tub and the door seal need to be replaced. Check your warranty, to see if some of these repairs can be covered. Get a few estimates before deciding whether to repair or replace it. Sorry.
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Have whirpool Duet dryer....leaves brown streaks just like everyone else's. What do I do to fix the problem? Can I do it or am I going to have to pay someone? Company should have a FREE kit to repair....it...
Hello there:
If your clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Drum has sagged in front ,bad rollers or drum support? motor wont turn drum enless i kinda lift front of drum .i dont have the manuel.Dave
Hi and welcome to FixYa. I am Kelly. If you can provide me with a mmake and model number I can tell you exactly what parts to order and change including the source to correct the problem you describe.
These parts are in most cases are:
1. The drum bearing ring: (not always bad)
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Bearing-ring-for-front-support-item-number-AP2996731.aspx
2. The front drum (Replace)seal: http://www.appliancepartspros.com/part_details.aspx?part_id=3131525
3. The rear drum seal: (replace) http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Rear-drum-felt-seal-with-adhesive--red-thread--item-number-AP3094149.aspx
4. Roller kit and belt: (replace) http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Dryer-repair-kit--29-inch-large-capacity-models--item-number-AP3131942.aspx
These are the most common failures. I would recommend ordering and replacing all parts 2 - 4. Doing this will ensure your dryer will last for a long time trouble free. (tumbling)
See this manual for general help: (Important)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Thanks for choosing FixYa.
Kelly
Jul 29, 2010 | Dryers
Duet dryer drum rubbing
There is a felt seal on the drum that might be wore and will need to be replaced.(Note if not replaced it will ware your drum and ruin it.
It is something you will probably want a repair man to check out for you.
Oct 21, 2009 | Whirlpool GEW9250 Electric Dryer
Replace the bellow in my front loader whirlpool washing machine
Hello. You don't need any special tools to do this. Feel around the edge of the bellows seal until you find a spring in the groove behind the face of the seal. Using a small screwdriver, lever it over the edge of the seal, and slowly work the ring over the seal face. Peel the seal off of the mounting flange, and roll it inside the drum. Remove the front of the washer, and remove the spring on the inner part of the seal. Replace the seal, making sure that it is oriented in the same manner as the one you took off. Reassemble in the reverse order. There are a number of very good videos on YouTube. Type in "washing machine repair" and you'll find different chapters in what amounts to a series on repair.....good stuff.
Hopes this is helpful to you. Best regards, --W/D-- please feel free to rate this carefully hand crafted answer! Thanx!
Aug 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My front loader gas Duet dryer has left brownish stains
Sounds like bad drum seals. Check all the way around the drum at the wall for sections of seals missing or an uneven gap around the drum at the wall.
Hope this helps.
Aug 14, 2009 | Whirlpool Dryers
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
this is general for all door seals - all are much the same.
disconnect from mains. take lid off
prise off the clamp holding seal to cabinet - usually a wire circle with a spring - and peel seal off cabinet. fold seal back inside drum
seal is held onto lip of tub with what is really a giant hose clip. undo this and the seal will come away from tub.
on new seal, lubricate the slot in the seal that goes onto the lip of drum with washing up fluid.
starting at top, enter the slot in seal on lip of tub. work your way round in both directions pushing slot onto lip. this is the hard part and it may take more than one attempt.
when seal is on all the way round, replace the clamp.
refix seal to cabinet (easy to do) and refit outer clamp.
test for leaks on rinse as water level is higher
Nov 10, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
215 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
