Your TV set has a short circuit either on output main power supply (90V) or in the line output circuitry specially line output transistor. Test this transistor for short and replace it and ressolder the all the solder joints around it. This task should be done by a qualified person.
I hope have helped.
Sully
Check the capacitor on power regulator area if there is puffed capacitor(bursted).blink means time delays but the power is not sufficient to stabilize because of a faulty capacitors and it triggers to stop the start kick.(some cases arehaving busted horizontal out transistors or shorted.
SOURCE: Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
My Sony KV36HS500 Trinitron is doing the same thing. Last night the next street over was hit by lightning. The "7" blink pattern was happening, so like the manual stated, unplug it for 4 hours. Which I did. The t.v. is back up and running fine. It's a nice t.v., better than the plasma I paid over a grand for, that's already shot. It's a good t.v. and good that Sony put in the stand by protection to prevent the t.v. from dying an unnecessary young death. Patience, don't rush it, unplug the t.v. and leave it sit. Also, don't use a power strip, that was my mistake, and unplug your t.v. if storms are in the area, I was too lazy to and now I had to deal with this, in 8 years, only twice did this happen. I'd buy another one tomorrow if they still made them.
SOURCE: sony trinitron wega 36 inch
break the wega into tiny little pieces and it's easier to get out of your house!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
SOURCE: Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
