Question about Dell OptiPlex GX150 SF PC Desktop
Hi i have a optiplex gx150 that has been reformatted. Im doing a course on windows xp proffeisonal, in order to learn the upgrade from windows 2000 to windows xp prof, what will i need. Should i get a buy a windows 2000 OS then buy a disk for the Drivers for the optiplex gx150, Then once installed go through the stages of upgrading to windows xp prof, as i have a windows xp prof os disk with licence?
  • Brannigan Jun 29, 2009
    Hi there, thanks for your comment,. i am able to find some on ebay with licence.???
    Scholar:
  • 37 Answers
Generally to upgrade from a former O.S. to a Newer O.S. you would simply do it in Windows. Place XP O.S. in CD Rom Reader than follow the instructions to upgrade. Simply enter the Product key for your XP O.S. when prompted. Good idea to save your Data first.
A much better method and a good learning experience, especially if the old O.S. is overused and or corrupt or you dont have all the drivers etc is to do it from scratch i.e. boot from the Installation disk and do the install without having to go into windows.
1) save ALL your data, forget trying to save programs ..once installed they lose their .exe installation files and have to be reloaded from the original disk.
2) Leaving CD ROM disk tray OPEN, shut down computer then place disk into tray and turn on.
3) If your Computer has a Boot Order F key than press it when booting and select CD ROM from the list. I
4) Normally you will see a Line in the upper right indicating that if you want to boot from the CD press any key and do so and the temp files for the installation should start loading.
5) If the computer goes into Windows then you would have to go into the BIAS which may be the F 12 key or F 2 but usually indicated in the Boot up. If not it could be DEL button or if necessary call DELL and they will tell you the BIAS key and go into it while booting up and prompted. Go to BOOT ORDER and follow directions how to change the BOOT ORDER to make C.D. ROM FIRST on the list.
6) Save changes and you will get the message as in #4
7) After Computer loads temp installation files it will shut down and restart . IF prompted to "FIX" Operating System select NO
8) It will continue until you see a screen indicating your Drive or Drives, their letter(s) etc. asking if you want to DELETE THEM: Press "D" and you DO WANT TO DELETE THEM and follow instructions after. I think the next key you press is "L" and the screen returns. Do the same with ALL DRIVES ON THE LIST UNTIL THEY ALL INDICATE THEIR "RAW" SPACE. Do not worry your new O.S. Disk will reformat them properly in the next step but its ESSENTIAL you DELETE THEM to insure a "clean installation"
9) You will be asked on the next screen if you want to FORMAT the RAW DRIVE and if so how: either NTFS or in FAT. NTFS is the default System of Choice now so select that. You will be given a choice of FAST or Normal Format ...STRONG SELECTION is " Normal" especially if the old O.S. had a lot of files and had not been formatted since you obtained the computer.
10) The O.S. disk will then FORMAT the Hard Drive (sector it into usable form coordinated with an Index etc; this is automatic and may take a awhile but let it finish.
11) After the Formatting, you will be asked which drive you want to install Windows on and you simply select your "C" drive or if not clear the one with the largest jvolume.
12 From then on it is automatic mostly, you will be prompted to perform certain tasks like entering the Serial Key, select Language and Location, Time zone, ETC. Some you can ignore or delay like if asked what type of connection to the internet you prefer, if you have a Network etc etc. You can do all that later
13 Windows will continue loading and an eye should be kept on it to see if there are any other questions you may want to answer but its pretty automatic and will end with a bunch of questions which are simple to ans, not critical and can be revisited later like Passwords, Preferences etc.
14 When it ends you will see the Typical Microsoft Screen with the Start Button and Basic applications that Microsoft puts on the Disk...
15) Do not worry if the screen seems distorted of the sound does not function or the computer does not connect to the Internet etc etc. This is usually DRIVER issues which is the Next Learning Experience to Tackle which i will go throught briefly :)
ITS SAFE TO ASSUME THAT THE MANUFACTURER WILL HAVE ALL THE DRIVERS YOU NEED ON THEIR WEBSITE, IN THIS CASE DELL BUT YOU HAVE TO DETERMINE WHICH YOU NEED....
Go to START > Control Panel and Select "SYSTEM" (a computer screen with a check mark Icon)... Select HARDWARE AND then DEVICE MANAGER. Simply look for YELLOW CHECK MARKS NEXT TO ANY DEVICE THAT THERE IS NO DRIVER FOR and MAKE A NOTE.
LOOK SPECIFICALLY FOR ONE THAT INDICATES:
"NETWORK ADAPTORS" IF THIS IS NOT CHECKED THEN PLUG IN YOUR " CABLE" FORM YOUR MODEM, GO TO THE MANUFACTURERS WEBSITE, IN THIS CASE: DELL.COM and look for SUPPORT, DRIVERS AND DOWNLOADS AND FIND YOUR COMPUTER MODEL AND OPERATING SYSTEM LISTED IN THE DROP DOWN BOXES.
Simply go to your list and find the corresponding DRIVER and DOWNLOAD IT, SELECTING: "RUN" IN ALL CASES AND FOLLOW THE INSTRUCTIONS, BOOKMARK THE PAGE INCASE YOU ARE ASKED TO RESTART THE COMPUTER. Start with the Major COmponents first: ( Chip Set, Video, Audio, wireless network etc)
SPECIAL CASE: IF YOU NOTICE AT FIRST WHEN YOU GO INTO THE DEVICE MANAGER THAT THERE ARE NO "NETWORK DRIVERS" (YELLOW MARK THERE) THEN YOU WILL KNOW YOU ARE NOT ABLE TO LOG ONTO THE INTERNET WITH THE COMPUTER JUST YET...YOU WILL HAVE TO USE ANOTHER COMPUTER TO GO THE THE DELL WEBSITE AND DOWNLOAD THE NETWORK DRIVER THERE BY SELECTING "DOWNLOAD" NOT "RUN", SAVING IT AND THEN USING AN EXTERNAL DRIVE OR USB THUMB DRIVE etc to DOWNLOAD THE DRIVER AND TRANSFER IT TO THE "NEW" COMPUTER. LOAD IT BY PLUGGING IT IN TO THE USB PORT AND SELECTING RUN AND INSTALL IT THEN YOU WILL BE ABLE TO LOG ON TO THE WEBSITE AND DOWNLOAD THE OTHER DRIVERS. You may also be able to use a CD ROM to download the Network Driver to and install it in the NEW computer......
After completing these installations, go back to the Control panel and System> Device Manager to see if you missed anything; ALL YELLOW CHECK MARKS SHOULD BE GONE. iF NOT THEN GO BACK TO SEE WHICH YOU MISSED AND DOWNLOAD IT.
You can now install your programs, data, periferals etc; you have completed a MAJOR Procedure in Computing the Professional Way, CONGRADS ! Your Computer, incidently should work infinately better, faster and pretty much like "new"
If you want to learn more; suggest you look up:
How Operating Systems Work?
How Drivers Work?
WHY Formatting a HARD DRIVE is so Important, what does it do ?
How Does a HARD DRIVER WORK?
At this point suggest you pick up the pieces of your head after it EXPLODES andPAT YOURSELF ON THE BACK... You are well on your way to becomming a qualified Computer Tech; this is a one of the major procedures you will encounter in MOST Computer Breakdowns. Operating System Breakdowns due to Corruption, Virus, User Error, etc are the MOST common cause for Computer Repairs :)
Posted on Aug 20, 2009
  • 3 Answers
Unfortunatly you can no longer buy a copy of windows 2000. Also the optiplex gx150 will xp but very slowly, make sure you have at least 256mb of ram. See if someone around you has a windows 2000 disk that you can borrow for educational purposes.
Posted on Jun 29, 2009
  • jlandis Jun 30, 2009
    yes you should be able to find someone on ebay who is selling a licensed copy of windows 2000. That would work just fine and it shouldn't cost you alot either.
How can I upgrade the memory of dell gx150 optiplex to 1 gb
Sorry - but you CANNOT upgrade the OptiPlex gx150 to 1 GB RAM - the maximum memory that system will recognize is 512 Mb.
Apr 26, 2014 | Dell Computers & Internet
I have Dell Optiplex GX150 with Windows 2000 Professional. It worked fine untill I changed to XP. Then no sound at all. Now I changed back winsows 2000 and still no sound at all. The sound hardware tell me...
download and install the xp soundcard drivers for the gx150 here-
http://support.euro.dell.com/support/downloads/devices.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&SystemID=PLX_PNT_P3C_GX150&os=WW1&osl=EN
Aug 01, 2010 | Dell OptiPlex GX150 PC Desktop
I have a Dell Optiplex GX1 desktop. I have been unable to start Windows and receive the error message: Windows root system32/ntoskrnl.450L exe failure. How do I correct this problem?
You will have to boot in to repair console from XP cd and run it so it can try to repair the Operating system. Put in cd and restart and if it does not ask to boot to cd u have to change boot order in bios to boot to CD rom first. If all this fails you have to reinstall windows. Hope this helps.
Apr 05, 2010 | Dell OptiPlex GX150 PC Desktop
Internet connection
pls inform your connection at LAN it maybe in The IP address promblem..the same address you can entr so that u can use and internet anytime..
Jun 26, 2009 | Dell Optiplex GX150 Tower Computer - 1GHz...
DELL OptiPlex GX150 Upgrading
The fastest processor you can install in a GX150 is a Pentium III 1.13 Ghz processor.
The Socket 370 was a design used only for P3 processors.
Max RAM for that system is 512MB no way to upgrade past that.
If you paid $100 for a GX150, you paid way too much (You can buy a refurbished Dell Dimension C521 for $225 at their refurb site)
Jan 26, 2009 | Dell OptiPlex GX150 PC Desktop
Can a OPTIPLEX GX150 be upgraded to a p4 it was a cheap xmas present and just would like to know
No. Even if it could you could only use 1ghz of a 3 to 4 ghz processor. You will need to buy a new motherboard in order to do that. Here is the specs. let me know if it isn't the right computer.
http://www.bizrate.com/desktopcomputers/dell-optiplex-gx150-1-ghz-pentium-iii-desktop--pid306165798/
Dec 30, 2008 | HP Pavilion 8650C PC Desktop
Boot problem with Dell Optiplex GX150
To reinstall Xp from the CD you need to press F2 and go into the BIOS then select the boot order configuration and make the CD the first boot device and the hard disk the second boot device.
After installing XP, if you wish you can go back into the BIOS and change the boot order to boot from the hard disk first.
Dec 13, 2008 | Dell System Board for Optiplex GX 150,...
I own a Dell Optiplex GX150. I am trying to access the system partition that will allow me to restore back to my factory settings. This computer was purchased back around 2001 and did not arrive with any...
Contact Dell technical support to get the CD read the partition on your hard drive to restore to factory settings. It won't be able to work without one since it has to boot from the CD in order to get it to work.
Dec 10, 2008 | Dell OptiPlex GX150 PC Desktop
Dell system restore
Depending on the operating system, most of the time it is located in the start menu, programs, accessories, then system tools. Restore is a process that takes the computer back to a specific date and time called a checkpoint. Reformat is a process by erasing the entire hard drive and re installing the version of windows you are running.
Nov 13, 2007 | Dell OptiPlex GX150 PC Desktop
Computers & Internet Logo
161 people viewed this question
Alun Cox
