Question about Electric ELECTRONIC SPEED CONTROLLER Airplane
Eletc speed odometer doesnt work on a harly davdison fuse okay
  • 583 Answers
Pull the speedo sensor from the top of the tranny and clean it off. The sensor is magnetic and tends to pick up any tiny metal fillings, floating in the tranny fluid, rendering it useless. Most times a cleaning will get it back to working. also second possibility is voltage regulator.check if regulator is faulty replace it to solve the problem.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jun 29, 2009
Speedometer does not register
check your fuses, if okay may be bad gauge cluster or speed sensor(s)
Feb 18, 2014 | Chevrolet Silverado 1500 Cars & Trucks
My speedometer not working? is it cause of the after-market radio i put in be the reason.. mitsubishi galant 2002 6 cylinder
So we can rule out the speed sensor and its circuit to the PCM.
I just checked through another area of my database and it seems the speed sensor is systated as on the side of transaxle, near firewall, maybe you can dheck that out to confirm, just out of curiosity and for future reference and some portion of testing requires unplugging the conections.
Anyway I will provide a complete diagnostic pocedures for you to check through and hope an answer is found.
PS. After going through the diagnostic procedure, I believe your radio is the cause of the problem. Refer to # 10
SPEEDOMETER DOES NOT WORK
1. Connect scan tool to data link connector, check for Diagnostic Trouble Code (DTC). If DTC P0500 (Vehicle Speed Sensor) is set, diagnose this DTC first. Go to step 6 . If DTC P0500 is not set, go to next step.
2. On Eclipse, if trip odometer is not working normally, go to next step. If trip odometer is working normally go to step 5. On Galant, if tachometer is not working normally, go to next step. If tachometer is working normally, go to step 5
3. Disconnect instrument cluster connector. Turn ignition switch to ON position. Connect DVOM between ground and instrument cluster connector terminal No. 52 (Black/White wire) on Eclipse or terminal No.29 (Black/White wire) on Galant. If battery voltage is present, go to next step. If battery voltage is not present, check harness connectors and harness wiring between instrument cluster and ignition switch for damage. Repair as necessary.
4. Using a DVOM, check resistance between ground and instrument cluster harness connector terminal No. 34 (Black wire) on Eclipse or terminal No. 30 (Black wire) on Galant. If resistance is less than 2 ohms, replace instrument cluster printed circuit board or speedometer and tachometer. If resistance is greater than 2 ohms, check instrument cluster connector and harness wiring. Repair as necessary. If connector and wiring are okay, go to next step.
5. Disconnect vehicle speed sensor connector and instrument cluster connector. Turn ignition switch to ON position. Connect DVOM between ground and harness side of instrument cluster connector terminal No. 29 (White/Blue wire) on Eclipse or terminal No. 16 (Yellow/Black wire) on Galant. Voltage should be 5 volts. If voltage is okay, repair or replace instrument cluster printed circuit board or speedometer and tachometer. If voltage is not 5 volts, check instrument cluster connector and harness wiring. Repair as necessary. If connector and wiring are okay, go to next step.
6. Disconnect vehicle speed sensor harness connector and connect DVOM to harness side. Check vehicle speed sensor power supply voltage between terminal No. 1 (Black/White wire) on Eclipse or (Black/Blue wire) on Galant and ground. Battery voltage should be present. If voltage is okay, go to next step. If voltage is not present, check vehicle speed sensor harness connector and wiring. Repair as necessary.
7. Using DVOM, check resistance between ground and vehicle speed sensor harness connector terminal No. 2 (Black wire). Resistance should be less than 2 ohms. If resistance is greater than 2 ohms, check instrument cluster connector and harness wiring. Repair as necessary. If connector and wiring are okay, go to next step.
8. Disconnect vehicle speed sensor harness connector. Connect DVOM between ground and harness side terminal No. 3 (White/Blue wire) on Eclipse or (Yellow/Black wire) on Galant. If 9 volts are not present, check vehicle speed sensor harness connector and wiring. Repair as necessary. If 9 volts are present, go to next step.
9. Check harness wiring between vehicle speed sensor connector to radio and tape player connector, auto-cruise control ECU ECM (M/T) or PCM (A/T) connector and instrument cluster connector. If connectors or wiring are damaged, repair as necessary. If connectors and wiring are okay, go to next step.
CAUTION: To prevent damage to scan tool, always turn ignition off before connecting or disconnecting scan tool.
NOTE: If ECM (M/T) or PCM (A/T) is replaced, immobilizer-ECU should also be replaced. Each ECM (M/T) or PCM (A/T) has an encrypted code for immobilizer-ECU, and is registered in immobilizer-ECU.
10. Connect scan tool to data link connector. Turn ignition switch to ON position. Read DTC. Disconnect radio and tape player connector. If DTC P0500 does not reset, replace radio and tape player. If speedometer does not work, disconnect auto-cruise control ECU connector. If DTC P0500 does not reset, replace auto-cruise control ECU. If speedometer does not work, disconnect instrument cluster harness connector. If DTC P0500 does not reset, replace instrument cluster. If DTC P0500 resets when any connector is disconnected, replace ECM (M/T) or PCM (A/T).
9_6_2012_10_56_48_am.gif9_6_2012_10_57_03_am.gif9_6_2012_10_57_17_am.jpg9_6_2012_10_57_28_am.jpg9_6_2012_10_57_39_am.jpg9_6_2012_10_57_52_am.jpg9_6_2012_10_58_05_am.jpg9_6_2012_10_58_16_am.jpg
Sep 06, 2012 | Cars & Trucks
The speed odometer is not working
If the speedometer is not working but the odometer is, the problem is usually in the cluster.
If both are not working, the problem may be the speed sensor in the transmission.
Aug 05, 2012 | 1999 Toyota Tacoma PreRunner
The gauges on dashboard are not working
Sound like a fuse blow problem; I suggest check and test each fuse acco4rding with the fuse description in the Owners Manual.
Other choice could be some loss harnesses connections, will need take off the dashboard to check it.
Hope this helps.
Feb 09, 2012 | 2000 Buick LeSabre
1996 quest van replaced the speed sensor and still my gauge doesnt work nor the odometer
Check the A.B.S. fuse. That happened to mine when the abs quit working.
Feb 09, 2011 | 1996 Nissan Quest
Speedometer stop working where's the cable?
Your vehicle does not have a traditional speedometer cable. Instead it uses a VSS (Vehicle Speed Sensor) to read speed of the vehicle below is a short test to help you determine if it is the VSS that has failed.
SPEEDOMETER VEHICLE SPEED SENSOR TEST
1. Press and release trip odometer button until function number 6 appears in display window.
2. Turn a front wheel and observe display (pulses are added to number in display. Check impulse signal for speedometer vehicle speed sensor. If 7 pulses are generated per wheel revolution, vehicle speed sensor is okay.
3. If specified number of pulses are not generated, check for open in wiring harness between speed sensor and instrument cluster. Repair wiring harness if necessary. If wiring harness is okay, replace speedometer vehicle speed sensor.
Jan 21, 2010 | 1996 Volkswagen Passat
I have a honda cbr and the odometer dsnt work
the speed sensor next the starter motor
sends a voltage pulse to the speedometer.
If you can get at the connectors
just down from the speedo you can
check for this pulse.
Block the back wheel off the ground.
Unplug the connectors and hook
a volt meter to the pink/green +
and the green/black - wires
on the harness side not the speedo side.
Turn on the key and then
check for a 0-5 volt pulse
when you turn the wheel forward
slowly.
If you have a pulse the speed sensor
is likely okay and your speedo
circuit board is faulty.
If you get no voltage pulse then you have
to check the pulse closer to the
speed sensor or check the connectors
and wires for faults.
No pulse can be a faulty speed sensor
or just a bad connection.
Have you checked the fuses well?
Sep 09, 2009 | 2008 Honda CBR 600 RR
Electric ELECTRONIC SPEED CONTROLLER Airplane Logo
24 people viewed this question
Top Electric Toys Experts
ray gallant
Robert A. Watson
Robert A. Watson
Tom Chichester
Are you an Electric Toy Expert? Answer questions, earn points and help others
