Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2 Logo
I
Isaac Hirsch Posted on Jul 20, 2014
How to replace battery - Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2
meshkatsaiam
Level 1:
Spread the Word:
An expert who has shared 5 answers on their Facebook wall.
New Friend:
  • Contributor 14 Answers
  • Posted on Jul 20, 2014
meshkatsaiam
Contributor
Level 1:
Spread the Word:
New Friend:
Answers
14
Questions
0
Helped
2102
Points
26
What is the model of your phone or tablet? Whatever, if the backcover can be opened, just buy a new battery and replace it. Or the most safe way is to go to the customar care and tell them to replace the battery.
My kindle has suddenly gone blank & shows me the picture of an empty battery
Hello, Judy-Ann -
So . . . an empty battery icon means the battery needs to be replaced. Eventually, rechargeable batteries no longer hold their charge.
The instructions here will show you how to replace your kindle battery with a new one:
https://blog.the-ebook-reader.com/2015/03/17/kindle-battery-replacement-how-to-guides-videos/
If you reside in the USA, I see Batteries Plus sells the replacement batteries for Kindles:
https://www.batteriesplus.com/battery/tablet-and-e-reader/amazon
Be sure to recycle the dead Kindle battery properly.
Best wishes.
How to replace battery Samsung Galaxy A tablet
Batteries are not user serviceable.
If you need a replacement battery you'll need to contact Samsung for authorized repair.
It'll probably be cheaper to just buy a replacement, used Galaxy A tablet on eBay than to replace the battery.
My tablet wont hold a charge
Hello, Jason -
The rechargeable battery for your tablet probably needs to be replaced with the proper replacement battery. Rechargeable batteries do not last forever.
If you have no idea what sort of battery your tablet uses and if you have no idea how to go about replacing the battery, then, I suggest you take your tablet to a reliable local computer repair business.
You will probably need to pay an upfront evaluation fee to determine if the tablet needs a new battery or if the problem is caused by something else. That fee will be deducted from the cost of the battery replacement (or whatever repair work) charge.
Note: You did not state the make and model of your tablet, so I cannot provide more precise instruction, like the make and model of replacement battery and how to go about replacing the battery yourself.
Best wishes.
Where can I take a kindle fire to get battery replaced
Amazon Kindle Fire HD
Kate, The source, radio shack, computer repair store or even a friend that is some what knowledgeable about computers. Kate you can even google search (Amazon Kindle Fire battery replacement) and maybe do it yourself after watching video or reading guide. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Good Luck.
How to Replace Your Amazon Kindle Fire Battery
Kindle Fire Battery Replacement
Kindle Fire HD 8 9 Battery Replacement
2answers
How do I change the battery on my 10 inch tablet
Tablets are not constructed to allow changing of the battery. The cover of the tablet would need to be removed and the battery will be connected with soldered wires so you need some electrical soldering skills and tools. Even then, getting a matching battery as a replacement will prove difficult.
My kindle of two years old battery will only charge to half full, is that normal and can I replace the battery
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Places like Batteries + are able to replace some tablet batteries.
Where can I find a replacement 3555A2L battery for my Kindle Fire D01400?
Here is a site that sells the replacement 3555A2L batteries for the Kindle Fire D01400:
3555A2L Battery for Amazon Kindle Fire D01400
Top Irulu Tablets & eReaders Experts
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Paul Bade
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
