Casablanca Fan Mykonos MyKM45 Ceiling Fan Logo
L
Larry Mead Posted on Jul 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where to get parts for casa blanca ceiling fan?
The bottom globe fell out and needs to be replaced
rjnworbnhoj
Level 2:
Filmmaker:
Uploaded 5 video answers.
New Friend:
  • Expert 142 Answers
  • Posted on Jul 20, 2014
 rjnworbnhoj
Expert
Level 2:
Filmmaker:
New Friend:
Answers
142
Questions
0
Helped
36509
Points
378
Are you referring to the light globe? You can go to any home decor or home depot/lowes and find replacement covers, and the make sure the screws the hold it in are not stripped and need to be replaced as well
2 Related Answers
Anonymous
  • 625 Answers
  • Posted on Sep 10, 2007
SOURCE: Casa Blanca Fan Installation
how wide is the beam - be more specific please.
Anonymous
  • 70 Answers
  • Posted on Jul 25, 2008
SOURCE: Item #44953 56 inch Casa
im not familiar with this model but you will need a pole to give the blades clearance from the celing and electricl conections uyou sometimes get two poles but as long as you have plenty clearnce one should be ok
How do I remove the glass globe on a 70" Casa Vieja Coastline Modern Contemporary fan?
To remove the glass globe on a 70" Casa Vieja Coastline Modern Contemporary fan, you need to follow these steps:
Turn off the fan and wait for the blades to stop moving.
Locate the screws that hold the glass globe in place. These screws are usually located at the base of the globe.
Use a screwdriver to loosen the screws. You may need to turn them counterclockwise to loosen them.
Once the screws are loose, gently pull down on the globe to remove it from the fan.
If you have any trouble removing the globe, please refer to your user manual or contact Casa Vieja customer support for assistance.
WHERE CAN I PURCHASE CASA VIEJA AEROSTAT FAN REPLACEMENT BLADES? 52IN
I searched for you out of courtesy. FIXYA unpaid volunteers do not work for a company selling parts or repairs.
I used http://www.google.com and entered the words Casa Vieja fan replacement blades
For anyone reading this question, Googling is a skill that you want to practice, as it can save you time and money.
https://www.lampsplus.com/products/52-inch-casa-vieja-aerostat-wide-palm-blades-outdoor-ceiling-fan__v0201-v0205-v0217.html
52 Casa Vieja Aerostat Wide Palm Blades Outdoor Ceiling Fan V0201 V0205...
I took the fan down to relocate, but now I can't remember in which order to install which parts to ceiling.
At the bottom you will FIND a URL that shows various "TYPICAL" installations.
Please keep in mind that this job usually requires a permit... simply because an IMPROPERLY SUPPORTED ceiling fan is a VERY DANGEROUS hazard to you & your family.... (guests, kittens... puppies (pet pythons, in-laws, etc.)).
Re-posting with the make and mode can get you a more precise answer.. but the finish cover is usually mounted on the support shaft first... Then... (on older CASA BLANCA the canopy IS the support socket for the ball (a final closure is done with a small ***** (small threaded device: SOUNDS LIKE "SKI+RUE") fitted panel)).
the ball is then (pin) attached to the support shaft and you will find it fits into a pivot bracket that would allow mounting on sloped surfaces as well as regular flat ceilings.
Wire connections can then be accomplished (best done with all power off (AT THE BREAKER))... and then the canopy can be finally secured.
Hope this helps (be safe, work safe!).
Please do look at the illustrations
https://www.bing.com/search?q=diagram+for+ceiling+fan+mount&form=EDGEAR&qs=PF&cvid=71ee787480044313b33337a7629f81d4&pq=diagram%20for%20ceiling%20fan%20mount&PC=DCTE
Apr 02, 2016 • Dryers
The lights flicker on and off when powering on
Your Minka Aire is also available on AMAZON...
The trouble you are describing involves YOUR control module INSIDE your fan body... I had a SIMILAR TROUBLE on a CASA BLANCA... had to replace the CONTROL MODULE myself... but for the 13 foot ceiling... and needing to ALSO upgrade the WALL SWITCH (Intelli Touch W32 Wall Control) to match... It was an EASY JOB.
Remember to ground out your hands before touching delicate electronic equipment (or an anti static wrist strap)...!!
Also remember... the REAL PROFESSIONALS always remove power (when possible).
Be SAFE.
To VERIFY, Technical Assistance... and get PARTS
Check out the links below or call:
Fan Man Lighting
15465 Cedar Ave S
Apple Valley MN 55124
(952) 898-2754 local
(866) 600-FANS (3267) toll free
Hours of Operation (Central Time)
Monday - Thursday
10:00 - 7:00
Friday 10:00 to 5:00
Saturday 10:00 to 5:00
Sunday 12:00 to 5:00
Fan Man Ceiling Fans and Lighting
Your search returned the following results
Fan Troubleshooting
The lights suddenly stopped working. It is only about 2 years old. When you turn the switch on they will briefly come on and then go off.
Hello Lisa Gray James,
I had the luxury of having a couple of old Casa Blanca fans in the house when ours went kaput (but the point I will try to make
is quite portable... between MANUFACTURERS.
Typically most wall controlled fans are designed to work over a standard light-switch circuit. the ADDITIONAL functions are accomplish through EACH vendors own proprietary switch-fan interface... (in the Casa Blanca case I am attaching below) they use their "RF" signals from their switch... and the control boards emit audible tone to make the user confident something is working.
I had NOT yet discovered the availability of the replacement unit below... but by swapping the living-room switch with the bedroom switch I was able to prove the trouble to Casa Blanca's 21Z2 control board (inside the fan)
Old style 21Z2: no longer available
Inteli Touch Circuit Board RMM 9901120 or 7801240
is manufacture discontinued (Inteli-Touch & Inteli-Touch II)
but the replacement units (Inteli-Touch 3) will work nicely...
Casa Blanca recommended that BOTH the switch (W32)
and control board should be changed... I complied.
(saved my good W12 switch as a spare)
BUT DO NOT hesitate to call the FAN MAN to discuss your options and needs... it looks like a multi vendor site... and I have also seen them on AMAZON.COM
New Inteli Touch 3 System
Jan 17, 2016 • Dryers
The globe for my casa vieja ceiling fan broke. where can i buy a new one? how do I measure the size to know what I need?
You can find replacement globes at most lighting or building supply stores. The dimention you need is the diameter of the circle that the globe sits into.
1helpful
2answers
Casa blanca fan motor speed control
www.casablancafanco.com
Jul 28, 2008 • Dryers
2answers
Top Casablanca Fan Dryers Experts
Paul Bade
vince
john h
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
