Question about Garden
I have a craftsman 18.5 hp, 42 inch mower that died the other day while idling. When I cranked it, now it runs wide open and the throttle has no control. "mcolvin@cei.net"
    Sniper:
  • 109 Answers
If you start the engine and there is no control on the engine...the governor is broken/damaged and must be replaced
Posted on Jun 30, 2009
Mower cranks with throttle in choke. after cranked and throttle moved to fast or any other position. The mower dies as if someone turns it off??
Ok I assume what you are trying to say is that once it starts with the choke on and you turn the choke off it dies.
This behavior usually means that the engine is leaning out. This means that it is not getting enough gas. Often if you put it back to choke fast enough it will keep running though very roughly.
The problem is the main metering jets are plugged or there is some kind of obstruction in the carburetor. This is assuming of course that the tank is full of gas and the fuel filter is clean.
Aug 17, 2013 | Craftsman 20 hp 42 in. Deck Yard Tractor
Sears Craftsman mower-Tecumseh engine 3.75 HP- wouldn't start-replaced air filter & spark plug; dismantled carburetor and cleaned it; now it will start but only runs for a couple of seconds and dies....
check the linkage for the governor, maybe on the wrong side,when off it should be pushing the throttle wide open, the governor brings it down after start up!
Jul 06, 2010 | Craftsman Garden
Runs for about 20 seconds then dies. will run at low idle but when you increase throttle it dies after a few seconds. already cleaned carb, just had it rebuilt last year. i noticed that when it dies the...
I would check the govoner spring, maybe it is worn out or isn't on correctly.
If this isn't the case I would check the fuel air mixture screws if your carburator has them, maybe it is getting too much fuel when the throttle is turned up.
Apr 21, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
My craftsman 18 HP tractor model 917.274400 will not run
Sounds like something is clogged. It may need a new air filter or the carburetor may need cleaning out. Also I would check your fuel, if it is over 30 days old I would replace it. It may be losing compression and either need a new head gasket or the head bolts tightened when it is hot.
Good day.
Oct 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman mower with 18.5 hp Intek Will run wide open only, regardless of throttle position. Linkage appears to be okay. Stuck float? What about the bowl electric solenoid valve?
check the lever biside the mower that connects to your carb. move it by hand while running if no change the governor has broke,, need to take engine off and replace, but if you move it and it slow down change spring
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan Lawntractor 13.5HP throttle linkage missing
The easiest thing for you to do is look at another mower that has a single cylinder Briggs at how the linkage is set up. They will all be the same linkage from 12 hp- 20 hp.
Jul 03, 2009 | Oregon Scientific Oregon Fusion Blade For...
Craftsman 42 inch riding mower. Runs great
how old is your plug? try cleaning and regapping it or replacing it at any rate make sure it is gapped correctly also make sure there is no rust dust or debris is on flywheel or coil also the flywheel keyway does more than hold the flywheel in place it servs as a timing pin and sometimes the slightest wear on it can cause the machine to start hard but otherwise run great good luck hope you find the problem.
May 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
