Question about Konica Minolta magicolor 2400 Laser Printer
I have a 2400w with a paper jam in the rear of the machine, how do I go about removing it?
  • 210 Answers
Try to pull it down, from the inside of the machine. If it is not taken out in one piece, you need to call a tech.
Posted on Sep 03, 2009
Hp fake paper jam
Usually if it says there is a paper jam, there is. Remove the paper trays, look at the rear, and also open the rear of the machine. If you had a jam and removed the paper, make sure the piece of paper is whole. A mall piece in the sensor will give the error. I had that on a large Dell network printer. Also try removing the power to the machine for 10 seconds.
Apr 14, 2017 | HP Office Equipment & Supplies
Magicolor 2400w paper jam error at transfer roller
In correctly installed transfer belt. and or roller reseat both. do the internal l machine prints demo page etc. jam if not check the print properties and paper setting of the machine in the draws they must match one could be set to letterhead paper the other normal both have to match.
Feb 10, 2014 | Minolta magicolor 2400W Laser Printer
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
Printer will not print after paper jam. after removing the jam the ready light comes on and when we try to print again the screen shows it is preparing to print but it does not print
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Dec 02, 2010 | Minolta magicolor 2400W Laser Printer
I have a paper jam with a samsung CLX 3175FN. Can't get the stuck paper out! Turning on and off didn't work.
If the paper is jammed inside the machine follow these steps:
1. Open the front cover and pull the toner cartridge out, lightly pushing it down.
2. Remove the jammed paper by gently pulling it straight out.
3. After removing the jammed paper, make sure there is no additional paper in the paper path.
4. Insert the toner cartridge and close the front cover.
If the paper is jammed in exit are follow these steps:
1. Open and close the front cover. The jammed paper is automatically ejected from the machine.
2. Gently pull the paper out of the output tray.
- If you do not see the jammed paper or if there is any resistance when you pull, stop and go to the next step.
3. Open the rear cover.
4. Carefully remove the paper by pulling in the direction.
- If the paper tears, make sure that all of the paper fragments are removed from the printer.
5. Close the rear cover. Printing automatically resumes.
Nov 17, 2010 | Samsung Office Equipment & Supplies
The paper is jammed..
Cause and solutions for paper jams
Cause 1 : Paper jammed in the Paper Output Slot, the Auto Sheet Feeder, or the Front Feeder.
Soultion : Remove the paper following the procedure below:
1) Slowly pull the paper out, either from the paper source or from the Paper Output Slot, whichever is easier.
* IF the paper tears and a piece remains insde the machine, open the scanning Unit (Printer Cover) and remove it.
After removing all paper, close the Scanning Unit (Printer Cover), turn the machine off and turn it on again.
-Be creful not to touch the components inside the machine.
*If you cannot pull out the paper, turn the machine off and turn it back on. The paper will be ejected automatically.
2)Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step 1 all the print jobs in queue are cancellled. Reprint if necessary.
if you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after moving the paper, contact your Canon service representative.
Cause 2 : Landscape credit card-size paper jammed inside the machine.
Action : Do not load credit card-sized paper in the landscape orientation.
Slowly pull out the paper from the Auto Sheet Feeder and remove it. If you cannot remove the jammed paper or the paper jam error continus after removing the paper contact your Canon service representative.
Cause 3 : Paper jammed inside the machine at the transport unit.
Action : Remove the paper following the procedure below :
!) Hold the Rear Cover Lever and then press to the right and put to remove the Rear Cover.
2) If you can see the jammed paper, slowly pull the paper out.
* Be careful not to touch the components inside the machine.
* If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
3) Reattach the Rear Cover.
Hold the Rear Cover so that the Rear Cover Lever comes to the left. Align the protrusions at the right edge of the cover with the slots at the rear of the machine and press on the lever ot reattach the Rear Cover.
Important : Press firmly on the Rear Cover until it is fit squarely in the rear of the machine. If the Rear Cover is not reattached properly, paper may not feed properly and cause paper jams.
4) If you were not able to remove the paper out in step 2, remove it from the Front Feeder. Refer to cause 1.
5) Relaod the paper in the Front Feeder and press the OK button on the machine.
If you turn off the machine in step 2, all print jobs in queue are cancelled. Reprint if necessary.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Nov 30, 2009 | Canon PIXMA iP1300 Printer
How do I remove paper jamed in the printer?
Paper Jam :
Cause 1 : Paper jammer in the Paper Output slot or the Rear Tray.
Action : Remove the paper following the procedure below.
a) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, turn the machine off, open the Scanning Unit (Printer Cover) and remove it.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
*If you cannot pull the paper paper out, turn the machine off, and turn it back on. The paper will be ejected automatically.
b) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step a), all print jobs in queue are canceled.
If you canot remove the paper or the paper tears inside the machine or if the paper jam error continues after removing the paper, contact your Canon Service representative.
Cause b)Landscape credit-card-size paper jammed inside the machine.
Action : Do not load credit card-size paper in landscape orientation.
Slowly pull out the paper from the Tray and remove it.
If you canot remove the jammed paper or if the paper jam error continues after removing the paper, contact your Canon Service representative.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 25, 2009 | Canon PIXMA MX300 All-in-One Printer
Magicolor 2400w gives paper jam error at transfer roller, after I cleaned the printer -laser head.
My 2400W was standing a long time without being used, and when I wanted to use it, it made a very faint image and showed "paper jam at transfer roller". Also, the image stayed on the transfer belt, but never got transferred to the paper. I tried a lot of things, nothing worked, but the message from weirdal1968 above pointed me in the right direction.
I eventually scratched / scrubbed / cleaned the copper pad on the left side of the optical imaging drum - this copper pad probably receives the bias voltage for the imaging drum from a springy stainless steel wire. There was some visible darkening of the copper pad where the stainless steel wire touched, this is what I cleaned. And then, presto, problem solved - the image came out great, and no more "paper jam at transfer roller" error message.
Oct 12, 2009 | Minolta magicolor 2400W Laser Printer
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
88 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
