SOURCE: My W2207 monitor keeps going to sleep
Hi,First there is no signal from the PC . check if the display card has come out while moving the monitor, or just reinsert the display card in the PC , then boot the pc .
SOURCE: computer asleep
I have to keep my pc in safemode now as mine is also in constant sleep mode and I can not get it out, It is the only way it will load up! :-(
SOURCE: my computer keep shuting saying monitor going to
start button >settings >control panel > Power Option > set time for monitor to sleep if inactive...if you dont want the computer to sleep go up to the hibernate tab and uncheck it. If you want the computer to stay on regardless, move all drop down menus to "never" instead of a time.
SOURCE: I have a HP vs17 monitor that keeps going to
I assume you have already tried this monitor with other PC and get the same result, just want to narrow down the problem before taking thing apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
the monitor (or display) sleep is an OS setting. which OS are you using.
