Question about Fedders A6X05F2D Air Conditioner
Fedders a/c model #A6X05F2B. Just posted a question but if a manual is available it would be helpful.
GO TO WWW.FEDDERS.COM AND DOWNLOAD IT U NEED TO HAVE ADOBE 9
Posted on Jun 30, 2009
  • David Ohm Jun 24, 2013
    can't find repair manuals on fedders. com
My window unit is leaking alot of water in my house
clean the filter . make certain its tilted ot the outsid eby about 1 inch. let me know if htis does not solve it or if it does thank you jon
Jul 25, 2011 | Fedders X Chassis A6X05F2B Air Conditioner
I have a Fedders dehumidifier Model A7DH45B2A REV-A. The nipple on the float broke off. Where can I buy a float? Do you have one? How much is it?
Although Fedders, as you knew it is no longer in business, some parts are still available.
Here is a link, with an explodes view of your model's parts.Locate th epart you need and then enter the part number, to see if it's still available. FYI Maytag Dehumidifier parts are interchangeable with Fedders. Fedders made the units for Maytag.
http://www.appliancefactoryparts.com/dehumidifiers/fedders/a7dh45b2a.html
I hope this helps you find what you need.
Jun 19, 2011 | Fedders A7DH45B2A Dehumidifier
Living in Burlinjgton Ontario Canada. Looking for owners manual. How can I get one?
Henry, unfortunately Fedders as you knew them is now out of business, A company by the name or Airwell bought parts and manufacturing and it's now call Airwell-Fedders. You particular model is no longer available. However, if you contact Airwell-Fedders Customer Service 866-829-2440 or email them customerservice@airwell-fedders.com they should be able to help you with the manual.
Good luck. I hope this helped you.
May 24, 2011 | Fedders SFPEB08F2B Air Conditioner
Fedders a6xo5f2b-0j leaks inside even though its tilted out?
I have a fedders a6x05f2b and the compresser comes on but the fan does not. What can I do?
Jun 28, 2010 | Fedders AED24E7F Wall/Window Air...
Need a window install kit. The original got
With a glass cutter, you could cut the glass to the correct size and using some angle aluminium strip and some silicone, then seal between the unit housing and glass. Hope this helps
Nov 04, 2009 | Fedders X Chassis A6X05F2B Air Conditioner
Okay I got a reply for help on my fedder air conditioner, but for some reason I never found the owners manual where I was sent to so Thank You for your help and now I will send the Model #out so maybe...
OK, now with the model number you provided, I can determine that it's an older model and the manual is no longer available online. The part number for the manual should be #CRC23230258N013
This supplier states to email them for price and availability, scroll down a bit and you'll see the manual in the list of parts available.
http://www.appliancefactoryparts.com/humidifiers/fedders/a6d24e7a-k.html
Here's a link with the contact info for Fedders you can give them a call and see if they can provide you with one. I've spent quite a bit of time searching all possible sources for the out-of-print manual and came up empty, although I did find a couple of shops that once had them, they've run out as well.
http://www.fedders.com/contactus.asp
Hope this helps, and best of luck in finding a manual for your AC.
Aug 07, 2009 | Fedders Appliance Air Conditioner Wall
My Fedders plug in AC will not start. Is there a reset button? The model # is A6X05F2B
Hi, yes right on you plug, if not, make sure there's voltage in receptacle, check your plug for any damages, your fan should be blowing, it seems to me you have no power in receptacle, check house panel for trip breakers, or you will have to go further, by removing front cover, with power off, and check master switch, sometimes master switch goes bad, if you don't want to go further call mechanic.good luck.
Aug 04, 2009 | Fedders AED24E7F Wall/Window Air...
How do i add freon to fedders model # A6X05F2B
you dont!!! Only an EPA certified technician can do this. Besides that this is window unit and therefore it is a sealed unit not meant to be recharged. Some newer models allow for this but not this Federers. It probably just needs a good coil cleaning is all, if its losing refrigerant than it has major problems not worth fixing---buy a new one thats more efficient---the energy savings will pay for the unit.
Jun 15, 2009 | Fedders AEQ07FBG Air Conditioner
Fedders air conditioner beeps but doesn't turn on.
Unplugged unit first. Take control panel out but dont unplug wiring. Cut Firth wire out from the center on the touch pad six wire plug. Cap both ends and plug back in. now unit will run on high cool and turn it on and off by plug and unplug
Aug 15, 2007 | Fedders X Chassis A6X05F2B Air Conditioner
No power
Probably blew out the thermistat and the compressor, along with the the capacitor. Probably not worth the repair. good Luck
Jun 13, 2007 | Fedders X Chassis A6X05F2B Air Conditioner
Fedders A6X05F2D Air Conditioner Logo
444 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
