Question about Samsung SCH-i600
I just purchased a MicroSD card for my new Samsung i600. When I install the card in the phone and go to Storage Card , it says "storage card not found".What do i do?
    Problem Solver:
  • 6 Answers
Check the manual, and make sure the card you are using isn't larger in capacity than your phone accepts.
I have encountered a problem where the contacts on the card don't easily mesh with the electrical contacts on the phone. May sure the card is inserted the right way, and clicks into place.
Posted on Jun 29, 2009
How do I add additional memory to my Samsung SM-T710 reader? What little I can find tells me I can add up to 128 GB with an optional MicroSD card.
MAKE SURE YOU TURN OFF YOUR TABLET before adding MicroSD card storage.
Your Samsung SM-T710 Galaxy Tab has a place for a MicroSD card on the lower edge of the unit below the volume button.
You will see a small hole. If there was no 'tool' included with your tablet, you can use the end of a paper clip bent out to create a small stiff wire you can use to insert into the hole.
Once you insert the tool/paper clip into the hole, the tray which is used to hold the MicroSD card will pop open.
When you have purchased your MicroSD card, you can insert it into the tray (it is 'keyed' to only fit one way in the tray). Then push the tray fully back into the slot, and your new storage should be ready to use.
Once you turn on your tablet, the tablet should recognize that you have new storage. It may ask you to 'format' the card.
You should explore options in your Settings to have your tablet use the new storage as the default destination to store music, pictures or videos. And it may allow you to install new programs to the SD card, saving space on your tablet's internal storage for the operating system.
Dec 15, 2016 | Samsung Electronics - Others
Why so less space?
The HTC Desire has 8 Gigabytes of internal memory, but due to the preloaded Android OS and software only 4.5 Gigabytes are available for use. It does not take long to chew up 4.5 GB if you have a lot of music, videos, pictures, and apps. This phone does have a microSD slot though, so you can expand the memory with up to a 64 Gigabyte microSD card. So, below is how you find out if you have a microSD card available:
1. Go into Settings on your phone, and select Storage. This will generally show available storage devices on your phone, including any installed microSD cards. *CAUTION* Your storage devices can be formatted from here - so be careful Not to Format Any Devices as that will wipe all data from the device. If this is not readily visible, move on to option 2.
2. If you are uncertain as to if you have a microSD card installed view the youtube video: http://www.youtube.com/watch?v=iJDqdBFtE6U
Open the cover on your phone as detailed in the video and see if there is a card installed where indicated. The card's capacity should be clearly marked on the card.
I hope this helps :)
Apr 14, 2014 | HTC Desire Cell Phone
How can I download music to my fusion2 phone
First you:
2.9.1 Using the microSD Card as USB Mass Storage
To transfer all your favorite music and pictures from your PC to your mobile phone's microSD card, set the microSD card as USB mass storage.
1. Connect your mobile phone to your PC with the USB cable provided. Your PC will detect the microSD card as a removable storage device.
2. Open the notification bar, and then touch USB connected.
3. Touch Turn on USB storage in the dialog box that opens to confirm that you want to transfer files You can now transfer files from your PC to your mobile phone's microSD card. When your microSD card acts as USB mass storage, your mobile phone will not use this memory space. Ensure that you follow the correct procedures to disconnect the USB mass storage device (your mobile phone) from the PC when you have finished transferring files.
Then:
8.3.1 Copying Music to the microSD Card
1. Connect the phone to your computer with a USB cable and mount the microSD card.
2. On the PC, navigate to the USB drive and open it.
3. Create a folder in the root directory of the microSD card (for example, Music).
4. Copy the music from your computer to the folder you have created.
5. After copying music, unmount or eject the drive as required by your PC's operating system to safely remove the mobile phone.
6. Disconnect the mobile phone from the PC.
Once done open music player and play music.
Ref: http://www.att.com/support_static_files/manuals/ATT_Fusion2.pdf
Dec 13, 2012 | Computers & Internet
Ive tried installing the samsung PC studio disc on laptop so i can upload my pictures from phone it wont load ????
You have the option to make it work like a mass storage device. Once you plugged the USB cable on the phone, instead of PC studio, use mass storage. You can then browse the memory card like a thumb drive.
You still also have one option. Remove the microSD card and then insert it into a card adapter. And then finally, insert it to a card reader on your laptop.
Sep 04, 2009 | Samsung SGH-D900 Cellular Phone
Where can i put the themes for my samsung sgh i900
the theme needs to be in ".tsk" format, then you can place anywhere on the phones memory or "my storage" not storage card (microSD) open start>settings>today and it will be there
Jun 21, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
SanDisk 2GB microSD not working on BBerry Curve
Two options--Go to Options > Media Card, set Auto Enable Mass Storage Mode When Connected to Yes.Another one go to this site http://forums.pinstack.com/f8/mass_storage_issues_heres_the_fix-96938 and on the first post there is a file "BB storage Activation new.rar" of size 3.63 Mb.Download it,extract it and upload it on your phone and just install.It will definitely solve your problems.Also you need to register there to download that file...just do it no problem.
Jun 01, 2009 | SanDisk 2GB microSD Memory Card
I have a storage memory card in my phone. But its not installed.
Hello ninidontcare,
The microSD card slot is located under the back cover of your device.
1. Remove the back cover.
2. Insert the microSD card into the slot with the gold contacts facing down (in the same orientation as the
image just to the left of the card slot).
3. Replace the back cover.
You may need to format the card before it will work properly, the phone should advise you if you need to do so.
Mar 29, 2009 | HTC Touch HD Smartphone
I760 sandisk installation
The MicroSD port is on the left side of the phone just above the volume control. It's a little plastic door labeled "MicroSD" which you open up and insert the card into. Once the card is in the phone open your File Explorer. In the base directory (My Device) you will see a Storage Card folder that you can put files into.
Sep 17, 2008 | Samsung i760 Black Phone
I purchased a 2GB microSD memory card for my cell phone, and i dont know how to put music on it from my computer
Connect your cell phone with the data cable. the computer automatically detects the External storage device(your memory card). open the external storage (in my computer). paste your music files in that
Aug 02, 2008 | Lands Phones
Memory Problem
try goin on phone settings and then go on memory card and it will say storage then change your storage meter to mass storage
Feb 14, 2008 | Samsung SCH-u740 Cellular Phone
Samsung SCH-i600 Logo
74 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
