Question about Lenovo ThinkPad R500 Notebook
How do I reset Lenovo Thinkpad R500 to factory settings?
I want to reset to the factory setting but do not know how. Also do not have Recovery discs. It runs slow and I thought resetting it might speed it up.
    Top Expert:
  • Lenovo Master
  • 76,099 Answers
By resetting it to its factory settings won't make no effect to its processign speed.
Posted on Jul 20, 2014
SOURCE:
SOURCE: reset factory password on t61 lenovo
Pulling the bios battery does not work on the Lenovos - youll be wasting your time. Where did you get that information Jadestar - Ill bet you can't name one person for whom your solution works on these laptops!!???
Posted on May 21, 2009
sparky1500
  • 1066 Answers
SOURCE: How do you restore a
try hitting F11 repeatedly when you first turn it on to access the recovery partition.
Posted on Oct 28, 2010
PeteGeek
  • 83 Answers
SOURCE: I have a virus on
If you can, see if you have Lenovo's Rescue and Recovery application. If you computer is crashed due the virus, you can order them from Lenovo here.
Posted on Mar 22, 2011
elix0411
  • 3530 Answers
SOURCE: need to know how to
Welcome to Fixya
Turn off the computer and press the button that sit beside the power button. That button is called the ONE KEY BUTTON. This will restore your computer back to the factory default state.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Aug 16, 2011
  • 68 Answers
SOURCE: factory reset for lenovo t410
if it is a newer model computer, 1 to 2.5 years old,there is an option in your Control panel setting to allow you to do that easily. or u tuibe may have a video of step by step to change the setting back
Posted on Jun 07, 2012
How do i reset a Lenovo Thinkpad T500
Reset could mean one of several things. I assume you know how to simply reboot it. If it is hung you can hold the power button down for about 6 seconds to turn it off.
If you forgot the password, contact Lenovo support at http://support.lenovo.com/en_US/
Provide them with proof of purchase and original receipt to prove ownership of laptop.
If you want to restore factory defaults then installed on the ThinkPad T500 is a program called Rescue and Recovery, which helps you diagnose and fix problems with the Windows operating system. To access this software, reboot your T500 and press the oval-shaped blue ThinkVantage button -- located on the upper-left area of your keyboard -- when the ThinkPad logo appears. When the Rescue and Recovery menu appears, choose the option that describes what you want to do. Follow the directions on the screen to run the appropriate action.
If you need the recovery disks then try
https://ez93.com/dl/lenovo-t500-restore-factory-settings.html
Jan 26, 2015 | Lenovo ThinkPad T500
Reset Lenovo thinkpad R500 to factory settings
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 20, 2014 | Lenovo ThinkPad R500 Notebook
How to reset lenovo thinkpad r61?
Please follow the steps below to reset the lenovo to factory settings
Note: All your data will be lost. So keep that in mind.
So take the backup of your data first in a separate HDD or flash drive.
1. Switch off the Computer
2. Press the power button and then immediately start tapping f11 key on the top of your keyboard.
3. You will hear a beep sound and then stop pressing it.
4. You will get the screen says windows is loading files. Wait untill it finishes.
5. Select the default language which is US and Click on next .
6. Enter your login credentials (username and password) if you use to login to the windows.
7. Then you will get the system Recovery Options screen where you need to select the last option "Lenovo Product Recovery"
8. Again preferred language will be English US and hit Next.
9. Accept the terms and conditions and hit next and then hit Yes on the warning.
10. Then it will start resetting the Lenovo Think pad to the factory default with no previous data. Same as when you purchased it.
If you have any query you can ask before restoring the Computer.
Hope this helps you. Reply if that fixes your issue.
Sukhiii
May 07, 2014 | Lenovo ThinkPad R61 Notebook
How to reset all settings to my lenovo a269i mobile thru pc
Is it a think pad ?
Power off your Thinkpad.
Press and hold the "F1" key and turn your Thinkpad on, still holding the "F1" key down.
Release the "F1" key when you hear repeating beeps. Wait for the "IBM BIOS Setup Utility" to load.
Select "Startup" using the arrow keys and press "Enter."
Select "Boot" or "Startup Sequence" and press "Enter."
Select "CD-ROM Drive."
Press the "F6" key repeatedly until "CD-ROM Drive" sits at the top of the list.
Insert your recovery CD into your Thinkpad's CD-ROM drive.
If you have multiple recovery CDs, insert the CD that has "Disc 1" on its label.
Press "F10" to save your changes and exit the BIOS Utility.
Select "Yes" and press "Enter" when the "Setup Confirmation" window appears.
Your laptop will restart. Wait for the Recovery Utility to load.
Select "Restore to Factory Specifications" to erase the contents of your hard drive and reinstall the Windows version and drivers that your Thinkpad originally came with.
Follow the Recovery Utility's onscreen instructions.
When prompted to insert another disc, do so according to the numerical labels on your recovery CDs (e.g., insert "Disc 2" after "Disc 1" and "Disc 3" after "Disc 2").
Your Thinkpad restarts when the restore process finishes. Power off your Thinkpad.
Hold down the "F1" key and power on your laptop to access the "IBM BIOS Setup Utility."
Press "F9."
Select "Setup Defaults" from the menu and press "Enter" so that your Thinkpad no longer boots from the CD-ROM drive.
Press "F10" and select "Yes" to confirm your changes.
Your Thinkpad will restart and load your newly installed operating system.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-61432
ThinkVantage Technologies downloads
Feb 20, 2014 | Computers & Internet
Restore IBM Thinkpad R500 Windows Vista to factory settings, erasing all passwords
You need a recovery disc for this operation. If you're any good with computers at all, and do not do this lightly, you can download dukes ban. Again this is not for novice pc users. This will literally and completely wipe your entire computer. Nothing will be recoverable and you will have to set everything. even the Hard Drive sizes. You will then need an OS disc like windows vista, windows 7, windows xp, etc and reload the entire OS back onto the hard drive.
Aug 05, 2013 | IBM ThinkPad R50e Notebook
I want to reset my laptop to factory settings
If you have a Factory Recovery Partition, Reboot and use the procedure in this forum: http://forums.lenovo.com/t5/R-and-L-Series-ThinkPad-Laptops/Product-Recovery-Windows-XP-ThinkPad-R50e/td-p/92036 OR, If you have the Factory Recovery Disks, put Disk 1 in the CD ROM and reboot, OR contact IBM for a Set of Factory Recovery Disks, if available.
Mar 01, 2013 | IBM ThinkPad R50e Notebook
I have a IBM Lenovo r500 laptop and I am having trouble loading windows 7 on it. I have updated the bios but it has worked since then. Now I am having error messages trying to reinstall it on a clean...
Yes! it could be, is the window 7 a upgrade disc? the reason I ask it will detect the previous version and install, but if the hard drive has been completely formatted it won't install on empty hardware. If that is not the issue go into bios and reset to factory default it might make the difference.
Apr 09, 2012 | Lenovo IBM ThinkPad (2647X800C) PC...
How do you restore a lenovo SL510 thinkpad to its original default settings without a disc??
Oct 28, 2010 | Lenovo ThinkPad SL510 Notebook
My laptop doesn't shutdown
Go to Start > Run and type services.msc. Locate the nVidia Driver Helper item and right click it. Select Properties. Set the startup value of the service to “Manual” or “Disabled”.
Dec 23, 2008 | Lenovo ThinkPad R500 Notebook
Lenovo ThinkPad R500 Notebook Logo
1,009 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Sunny Solanki
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
