Question about HP Compaq ProLiant DL380 G4 Server
Audible alert I can hear an audible alert coming from the array and I see the following error message in the screen: ADDING (8) FAIL xx0x000R R5ID:0 I have no idea what it can be.Thank you
  • 39 Answers
Re: Audible alert
Run Array Configuration utility from your SmartStart disc. If the array is degrades the system will show to you.
Posted on Dec 17, 2007
0 characters
3 Points
Ml150 g3 high speed fan , i can not turn it off
Can u confirm that is it giving some error massage in startup screen and install smart array and check that windows is coming or not, If windows not running then installed OS in your server
Feb 28, 2013 | HP ML150 G3 Rack Conversion Kit (1249012)...
Following arrays have missing required members and cnnot be configured: Array#1-RAID-0
RAID 0 will fail with a single drive loss. So if you lost a drive, you lost the array, and most likely your datas. It should never be used in a production environment, because it can not be rebuilt.
Feb 25, 2013 | IBM x3400 Server
I have a Compaq Proliant ml370 G3 with an HP smart array 641 controller that I am trying to load SCO open server 5.0.6 on. This is tied to three drives in a RAID 5 config. When I try to run the Smartstart...
SSCD is not supported for the installation of SCO 5,6,7 or 8 you may need to create the arrays using ORCA at the bios of the 641 controller at post and then install SCO directlly from the installation cd.
To access ORCA press F8 or F9 when the smart array controller is posted at the bios screen
Sep 21, 2010 | HP Compaq ProLiant ML370 G3 Server
POST errors forcing server to crash
Its best you log a case with HP support. If your system is still under warranty or if you bought support along with the system, they will fix the problem for you.
Apr 01, 2010 | HP ProLiant DL380 G5 Server
System Fault indicator light on in a Gateway 975 Rackmount Server
If it is on steady and green, the server is operating normally.
If it is on steady and orange, the server is "in a critical or unrecoverable condition"
This is according ro the manual located at
If it is orange, for further diagnostics, you should see POST error codes, or hear relevant audible beep-code patterns, which can be interpreted by checking the tables in the PDF Server manual linked above. (Pages 125 and 128 respectively.)
If it's green, of course, you dont have a problem.
Feb 19, 2010 | Gateway 975 Rackmount (gtwy975) Server
Dell Poweredge 4300 will not boot up after cmos battery replaceme
Configure your System bios and reboot. Your Hard disk drive was not configured. Pl configure. it will work properly
Aug 22, 2009 | Computer Servers
SCSI Devices not detected when posting ML530 Server.....
To get to the BIOS for your server, press F10 at start-up. This should get you there to verify if settings are detecting SCSI devices. If they are there, you may have to reinstall the SCSI controller drivers. Good Luck.
Jan 30, 2009 | HP Compaq ProLiant ML530 Server
Run Compaq Array Configuration Utility
Hi Foambob,
Try all means to get a smartstart CD.
Normally new version will be able to use on older hardware , but no guarantees.
I have always found it easier to use smartstart CD auto mode.
You can also do the install and then run ntssd to update all the drivers etc., but I don't recommend it for novices. Use the auto mode , it takes longer but safely and surely.
Good luck
May 21, 2008 | Compaq ProLiant 5500 Server
Drive array problem
Hi Nick ,
As of now you can Select "F2" to accept data loss and re-enable logical drive. This Load OS Normally .
It seems that one of the HDD in the RAID 5 has failed , Did you notice any LED indications like red or amber on the HDDs ?? if so get that hdd replaced . Make sure the Failed HDD is replaced .
You can run the Array Diagnostic Utility from HP System tools to check the Failed Drives and also frimware version of the controller . If the frimware is not latest Update it from HP website. DL380 G4 should have Smart Array 6i controller .
Hope This was Helpful
cheers :)
May 17, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL380 G4 Server Logo
65 people viewed this question
Top HP Computer Servers Experts
Are you a HP Computer Server Expert? Answer questions, earn points and help others
