Cars & Trucks Logo
A
Anonymous Posted on Jul 20, 2014
Brake system diagrams 2003 F-150
Broken tubing up front, just need diagram for 2003F-150 braking syetem
A
Anonymous
The brake lines connect to the calipers. That's about it!
5 Related Answers
Anonymous
  • 110 Answers
  • Posted on Nov 06, 2008
SOURCE: Rear brake diagram
Look at other side rear brake, if you can't transpose it in your mind, then stick a big mirror in front of the other side and take a photo of the brake image in the mirror ... hmmm,  you may end up thinking like this after a while.  I don;t know that that is a good thing;~).
good luck, ..ajm
please rate all solutions
Anonymous
  • Posted on Mar 25, 2009
SOURCE: replace front brake pad 2003 toyota 4 runner
Diagram is unnecessry.
Pull both front wheels
Work one at a time leaving the other for reference
Find the retention spring ... its a paperclip thickness wire spring... dislodge center retention loop and undo from both ends which engage brake pad retention rods.
Pull the rods out
Pull the old pads out... laying everything on the ground
Use scrap wooden wedges to pry between the rotor and the caliper ...inside and out until the calipers are fully withdrawn. Use the new pads to measure if they are far enough back.
Note... the brake fluid will have dropped in the master cylinder over many months of wear... do not fill it. When the calipers are pushed back they will fill the reservoir again... one wheel at a time.
Be sure to identify the correct pad based on what you took out and what is on the other side (if you screwed up the layout)
Make sure to take the old antisqueek backing plate from the old pad and place it on the new pad. They don't use lubricant on these anymore.
Replace the pads... the retention rods... then the retention spring
Do the other side
Then progressively step on the brake peddle until full tension is felt
Check the master cylinder reservoir... probably needs no additional fluid.
New pads will register in existing ridges in each disc in no time at all.
You should check the discs to see if they need to be replaced during this operation...using some calipers
Anonymous
  • 232 Answers
  • Posted on May 30, 2009
SOURCE: need Rear Brake Diagram for 1994 Chevy K2500 4x4
Here is the diagram,It is always a good idea to only disaasemble one side so you can use the other side as a reference,I also reccomend using a set od brake pliers,they will the disassembly and reassembly much easier.
Anonymous
  • 1776 Answers
  • Posted on Jul 19, 2009
SOURCE: Repair rear brakes on Easy Go Golf Cart
You should go to the autozone website at autozone.com and register your vehicle. It's free and handy and you will have access to a full online repair manual for your vehicle. There will be information on the brake system, that will aid you in making repairs or troubleshooting problems, Hope this helps and good luck.
Anonymous
  • 1985 Answers
  • Posted on Nov 26, 2009
SOURCE: need a wiring diagram for a chevy s10. brake
your power starts at the brake light fuse,check with a test light,then proceed to stop light switch on brake pedal under dash,one wire will be hot when when you check it with your test light, the other won't be until you press down the brake pedal then the power flows through to the second wire,if no power to second wire replace switch,if you have power remove tail light bulbs and check for power in side socket.
Need diagram for a 2004 chevy avalanche brake line
Brake line diagrams have never been avail
& you don't need them
If your replacing a rusted out brake tube, you
fabricate & duplicate the part your replacing
Given some experience you really could pump
a complete vehicle from scratch
To be working on any product, you have to understand
how it works & how to diagnose & make repairs,of coarse
almost no one has the thousands of dollars in tools at home
to do much on a car
I see you said can't flair line correctly
If that skill is lacking or you do not have the correct
tools your done
Brake tubing is only avail at auto parts stores in different
lengths of straight tubing, as you probably know
No diagrams
No ready made what ever tubing your replacing
Shouldn't say this,but repair shops don't do well
with brake tubing & some don't want the job
They just lack the skills & patience to do a decent job
Need to replace all metal brake lines
There has never been brake line diagrams
Very little of value in factory manuals
You don't need diagrams, as your replacing what
is already there
You will be fabricating brake tubing you bought at
the auto parts store & can adjust the routing for ease
of bending etc & still use the original mounting points.
I'm I missing something you want to do?
Front brake line diagram for a 98 dodoge intrepid
Brake Tubing Diagrams have never been
avail,even in Factory Service Manuals
Braking system 1984 delta 88
You get under the car & measure what you need
Better to remove all the rusted lines,then measure them
Get 3/16" brake tubing at auto parts store
Only comes in various lenghts, of straight tubing
Has to be cut,bent,double flared & you may need
fittings.
There is no prints or diagrams for brake lines
I need a diagram showing me what the rear back brakes are to look likgoing on a 1987 chreverolet silvrado truck
You want a diagram for the rear back brakes as opposed to the rear front brakes? Just curious....
Here is a diagram of a typical GM rear drum brake system.
Diagram of brake line on front passenger side for 1998 Audi A4. Question? Does the 98's have the senor on the brakes, as my neighbor changed my brakes last nite and said, the old ones dont have the...
Was the brake line removed ? There is no reason a brake line needs to be replaced unless the line was broken or damaged.
One way to check if your car has sensors, is to look for a harness that runs and is secured on the strut. Also check the hub, there is usually a slot in the back where the sensor is mounted.
Some vehicles come without brake sensors, best thing to do is call local dealer, supply them with your VIN and ask them if it comes with sensors.
What were the repairs done to your brakes ? What is the problem after the repair was done ? You may only need to bleed the complete system if calipers were replaced.
6helpful
I need a diagram of the entire breaking system on a 1993 ford taurus i just replaced a rear line and i think i stripped the extention piece i had to add to the end of the break line. the one that goes into...
here is a 96 taurus
Item Part Number Description 1 2C296 Anti-Lock Brake Tube 2 2C219 Anti-Lock Brake Module 3 2005 Power Brake Booster 4 2263 Front Brake Tube 5 2B091 Brake Pressure Control Valve 6 2140 Brake Master Cylinder 7 2B547 Brake Load Sensor Proportioning Valve 8 N802191-S60 Bolt 9 2L568 RH Rear Brake Tube 10 2L569 LH Rear Brake Tube 11 2C287 Brake Fluid Distributor Tube 12 N808531-S301 Bolt 13 — Front Side Member 14 N802324-S56 Bolt 15 18124 Front Shock Absorber 16 2B121 Front Disc Brake Caliper 17 2078 Front Brake Hose 18 2264 Front Brake Tube 19 2553 Rear Disc Brake Caliper 20 2A442 Rear Wheel Brake Hose 21 N808728-S60 Bolt 22 — Side Rail 23 N802324-S60 Bolt
Item Part Number Description 1 2B547 Brake Load Sensor Proportioning Valve 2 — Body 3 N802191-S56 Bolt (2 Req'd) 4 2L568 Brake Tube Assy 5 2L569 Brake Tube Assy 6 2265 Brake Tube Assy 7 2B255 Brake Tube Assy 8 5500 Rear Suspension Arm and Bushing 9 W611634-S301 Bolt A — Tighten to 11.4-15.6 Nm
(8-12 Lb-Ft) B — Tighten to 10-14 Nm (7-10 Lb-Ft)
Brake Hose, Rear —Drum
Item Part Number Description 1 — Rear Side Rail 2 2L569 Rear Brake Tube 3 N602324-S60 Screw 4 N611193-S60 Screw 5 2C023 Left Hand Rear Hose and Connector 6 2210 Rear Drum Brake Backing Plate 7 18125 Rear Shock Absorber 8 2267 Rear Brake Tube A — Tighten to 16-20 Nm (12-15 Lb-Ft)
2answers
Brake line diagram
Brake Lines and Hoses
Double-walled steel line is used in the hydraulic lines between the brake master cylinder and the front tube connector, and between the brake master cylinder and the flexible brake hose at the rear wheels.
Double-flared brake lines provide good leak-proof connections.
When replacing hydraulic brake lines, hoses, or connectors, tighten all connections securely. After replacement, bleed the brake system; refer to Section 206-00 .
The wet appearance of the outer cover of the rubber brake hose is referred to as "sweating." This is a normal condition for neoprene rayon braid hose and is not a sign of leakage or cause for replacement of the hose.
Hydraulic Brake System Components — Non-ABS
Item Part Number Description 1 2005 Power Brake Booster 2 2455 Brake Pedal 3 2261 Rear Wheel Cylinder 4 2552 Rear Disc Brake Caliper— (Mexico Only) 5 2B120 Disc Brake Caliper—, Front 6 2B091 Brake Pressure Control Valves 7 2140 Brake Master Cylinder
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
