Question about Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television
All the colours are jumbled up
The colours look like they are all mixed up and it has a orange band at the top and blue at the bottom
  • 261 Answers
It looks like you colorwheel is getting defective, i recommend you replace it, just make sure you identify igf it's the one with the silver or gold bearing, because if you get the wrong one, it won't work on your Tv.
Posted on Jun 29, 2009
Adjust blue flame
should be a band you can turn where the tubes connect to the back of the knobs...if not, check for spiderwebs or gunk in the tubes themselves. There's not enough oxygen in the mix.
May 22, 2012 | Weber Genesis Silver B Grill
I have just recently purchased a BMW ci328i and do not yet have the manual. The coolant sign is starting to flash up on dash. What coolant can I use?
There are many different coolants and if you mix 2 different ones together they can react and turn into a gel which don't do the car much good! the best way is look what colour coolant is in the system already and as long as you use the same colour coolant it will be fine, main colour coolants are green,blue pink and orange, green and blue can be mixed together as can orange and pink but Pink cannot be mixed with blue or green, i would guess the coolant in your car will be the pink stuff but please check 1st, hope this has been usefull to you.
Ash
Jan 09, 2011 | 2000 BMW 3 Series
I HAVE LOST THE INSTRUCTIONS TO MY COMMTEL MOD X1 EXTENSION SOCKET AND NEED TO KNOW WHICH COLOUR WIRE GOES WHERE ??? PLEASE HELP
I lost mine too, saw this post, and then they turned up, so here you are:
COMMTEL
Surface Mounted 2/6a Slave Wall Plate - with ADSL Filter
Instructions
  • Remove wall plate back box by removing the two screws on the front face
  • Fix wall plate to skirting board or wall with screws supplied, allowing adequate space for cable entry
  • Insert exisiting telephone wires into screw connections on the ADSL face plate, following cable colour coding according to the list below, and ensure screws are correctly tightened
  • Screw wall plate onto the back box with the screws supplied, ensuring screws are sufficiently tightened
Cable Colour Coding
1. Not Used
2. Blue with white banding
3. Orange with white banding
4. White with orange banding
5. White with blue banding
6. Not Used
Information
  • No need for external filter
  • Surface fitting, replaces existing wallplate
  • Quick set-up
  • With back box
* If more than one phone or fax IS required to run off the same line, simply add more filters where required. Each individual piece of equipment will require a seperate ADSL filter
* Multiple telephone connections, long runs of cable (over 20m) or low quality telephone cable can adverely effect the performance of your connection speed
Safety Information
Before carrying out any electrical work, always switch off at the mains. If in doubt consult a qualified electrician.
Item Code: 41603016
Distributed by Commtel UK Ltd
www.commteluk.com
It might be worth mentioning that this filter swaps the polarity of the telephone wires: I don't know why. I rewired mine to use it as a master socket, and I have connected the other extensions to the filtered output. This can improve broadband speeds: see
http://www.rob-r.co.uk/other/UKphonecatwiring.htm
Oct 23, 2010 | Computers & Internet
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Our model of the LCD projection TV is KF- E50A10. The original colours have changed & only blue colours appears predominantly. I approached the local service guy & he said the problem is with the...
Sounds like the optical block is going bad. when thos happens you usually see like a band of pink and a band of blue on the top and bottom. or splochy parts of the screen with the failing color. Sony has released a lot of info on this and you can do a google search to confirm. Ive found several examples of failures. This problem is not solvable economically.
Nov 20, 2009 | Televison & Video
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
May 31, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Wires on the 21010
the blue and orange is on top and da black and yellow is on bottom
                                   or [ Blu                                    ye[ Bla
Nov 18, 2007 | Eclipse 21010 5-Band Car Equalizer
Open Questions:
Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television Logo
166 people viewed this question
Jerry Greenberg
Jerry Greenberg
