Question about GE Profile Harmony DPGT750EC Electric Dryer
Doesn't heat the first load
Similar problem - my GE Harmony dryer doesn't get warm during the first load, which takes ages to dry. Subsequent loads seem to work ok, but it doesn't always work. My vent is clear, so I wonder if the problem is dust inside the cabinet.
Thoughts?
  • 33 Answers
Blower motor not getting up to speed probably.
Press home.
Press help.
Press both back and my cycles and hold until service mode comes up.
It will tell you what is wrong.
Turn off when done.
Posted on Aug 03, 2009
Dpsr610eg8wt not drying
broken heating coils most likely , very common with age
Apr 10, 2014 | GE Profile Harmony DPGT750EC Electric...
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer is not drying clothing, takes approx 4 hours to dry one load, I can see condesation build up behind electric panel where numbers are.
Sounds like you have a blocked vent. Make sure there is good airflow. Heat and airflow is what drys and if one is removed you will not operate correctly.
Eric
Jun 29, 2010 | GE Profile Harmony DPGT750EC Electric...
Problem drying
no, what setting do you have the dryer on? is the dryer getting hot? if it is set correctly and is heating as it should then you need to check the vent hose, it is probably restricted with lint. Be sure and clean it from end to end.
Mar 12, 2010 | GE Profile Harmony DPGT750EC Electric...
Takes 2-3 hrs to dry a load. Put new dryer hose on. Vent not clogged. Lint filter cleaned each load.
Dryer turn on makes a humming noise intermitantly and won't dry at all have changed coils. It's not the fuse or vent. Help??
Nov 24, 2009 | GE Profile Harmony DPGT750EC Electric...
The dryer stops drying after about 3 loads....
Without a specific model I will say in general there is a over heat condition. A component is getting too warm and needs to cool down to work again. This could be a faulty/failing component or as simple as a partially restricted vent. Some manufacturers recommend allowing a rest period between loads. One or two in a row is usually fine but too many without a break can tax a non-commercial model. That being said, ahem, it is not uncommon for ours to do 5 or 6 successive loads at time(and I know better).
Eric
Jun 10, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Electric Dryer - Starts out heating but then screen says SENSING
nicknames, usually with long dry times I suspect a pinched or clogged vent. Make sure you check that first. You can do a test to check the moisture sensor. The 2 sensor bars will be on the inside of the drum just below the vent cage. Press the home and then help button. Next press and hold the help and start/stop button for 3 seconds. On a dry sensor, you should see a voltage of approx 4.75 displaying. Now get a wet rag and hold them across the 2 sensor bars. You should see the voltage drop to about 1.0 volts. If it does this your sensor is ok. Check the vent and this out first and we will take it from there. Catriver.
Dec 03, 2007 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
100 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
