How bad is the reported problem with this model? How many cars have had this problem? Do pistons and rings need replacement? What is the approximate cost?
SOURCE: 6 Cyl 1998 Toyota Camry Oil Pressure Light
these cars have problems with bad oil pressure warning switches you may have someone put an oil pressure gauge on the car and make sure your pressure is within spec and go ahead and change the sender if it checks out please rate -jeff
SOURCE: toyota 1ge engine 0n a Toyota mk 2 heavy fuel consumption
it can be some reasons mybe cylinder head, inlet valve worn out.
it can be cuporator valve releasing more petrol into the inlet.
Brakes it can be. check contacpoint.
SOURCE: 2002 toyota corolla with 72k miles is using excessive oil
TOYOTA COROLLAS SUFFER PISTON RINGS CAUSING THEM TO BURN OIL BUT YOU DONT JUST REPLACE PISTON RINGS AS THERES A MODIFIED BLOCK ALSO IT WOULD BE A GOOD IDEA TO CHECK YOUR INLET MANIFOLD FOR OIL AS THERE IS A CHECK VALVE (BREATHER) WHICH ALOWS OIL INTO THE INLET MANIFOLD CAUSING RAPID OIL BURNING I WOULD GET THIS PROBLEM SORTED ASAP AS SOON YOUR EM LIGHT WILL COME ON DAMAGE YOUR CATALYST AND IT WILL NEED TO BE REPLACED
SOURCE: excessive oil consumption with no noticeable leaak
Check your PCV valve, Does It Smoke ? Seems if it is not leaking in order to use a lot of engine oil it would have to be noticably burning oil causing smoke from the tail pipe...
SOURCE: newly overhauled toyota corolla 2e engine emits black smoke
I have toyota corona 3s engine it smokes black and fuel consuption is high we have changed the engine oil and cylinderhead gassecate but still black smoke is comming what should i do
