Can you help me find a reapairman. I had someone come out and pd them a service call fee and they have never fixed it.
SOURCE: ice maker not working
have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
SOURCE: ice maker does not dispense cubes
THE SOLENOID IN THE ON THE ICE MAKER MOTOR IS NOT WORKING IT HAS ICE BUILD UP ON IT OR IT HAS A SHORT IT PULLS THE PLUNGER THAT OPENS THE FLAP THAT LET ICE CUBES FALL OUT. REMOVE ICE MAKER AND THER ARE 2 5/16 SCREWS THAT HOLD PANEL IN THEN UN PLUG MOTOR AND USE HAIR DRYER & DEFROST MOTOR AND SOLENOID SHOULD WORK IF NOT MAY NEED TO REPLACE SOLENOID.
SOURCE: GE Monogram ZISS480DMCS Ice Maker Problem
The water solenoid valve should have 120v going to it. (You will need a multimeter to chk this). You will need to also chk. for proper ground when verifying the 120v. If you get 120v on each of the pin clips, then your plug is not properly grounded, which means that you need a new ice maker circuit board. This is located in the in dispenser (front panel opens).
SOURCE: general electic gsh25jfta bb
According to the manual for your refrigerator:
Blinking green light indicates an ice cube is stuck in the icemaker. To fix - Turn off the ice maker with the on/off switch. Then remove all of the ice from the icemaker by hand and turn it back on.
I hope this helps.
SOURCE: GE PROFILE PSS26msrd Ice maker
if the water dispenser is working normally and ice is not producing, take thr water filter out rinse it with hot water and put it back, this is the important thing to do after you put the water filter back you must hold the water filter reset button at least 3 seconds to reset the system and it should working fine.
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
