Question about Nikon COOLPIX Cameras
Why does my camera keep saying battery exhausted even when I change the batteries?
I have changed the batteries numerous times even putting in new Duracell batteries and yet it still keeps saying battery exhausted. It is a fairly new camera ( I've purchased it brand new from Staples and have had it for less than one year).
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • Nikon Expert
  • 151 Answers
If batteries leaked in the camera the connections IN the camera may be dirty. Putting in a new battery takes care of the battery connection but not the camera connections. This is why it is very important to take out batteries when you are done taking photos. When you want to shoot again you put the batteries back in and set the time and date. You MAY be able to clean the connections with a pencil eraser. If you use a pencil eraser please blow out the dust from the eraser. If you are positive the camera then I cannot help you here.
Posted on Sep 02, 2015
SOURCE:
  • 4 Answers
SOURCE: camera batteries drain quickly
Open the battery door and check the contact between the camera and the batteries. Most often then not there is just a bad contact and it's ruinning your baterry life.
Make sure that the contact are well placed and that there is no rust or dirt build up around there.
Posted on Dec 20, 2007
  • 24 Answers
SOURCE: Nikon Sb600 does not fire every time
I know you mentioned rechargeable batteries, but you did not say was what kind. I have had my -600 now for more than two years and suddenly I started to experience flash failures, and the ready light would not come on to indicate flash is ready. I called Nikon 24/7 tech support and they recommended NiMH rechargeable batteries. (I was using regular alkaylines). Instantly my problems were solved, flash after flash it recycled instantly. In the manual they list the recycle times and the NiMH are the fastest. The tech said they were very good on power.I was skeptical, but he was right, it turnes out.
So, if you are not using NiMH for rechargeables, that could well be your problem. NiCads won't cut it!
Posted on Dec 23, 2008
leorcid
  • 281 Answers
SOURCE: Will not power on even after changing and testing
Check for the battery contacts inside the battery compartment. If you see them rusted, clean them gently with alcohol. Do not scrape with any sharp objects. Make sure the contacts are clean and reinsert the batteries. Get back if it is still dead.
Posted on Dec 22, 2009
Testimonial: "This was a logical next step that I had already done... I should have stated in my original problem. Maybe it is the on/off button."
  • 261 Answers
SOURCE: The SB-600 will not switch on? was ok last time i
Have you put in those batteries correctly?
Also, make sure the door is fully closed.
atdlee@netzero.com
Posted on Jan 18, 2010
  • 261 Answers
SOURCE: I have the Nikon D90, and a brand new, (today)
Hi Jane,
Try this:
Turn on flash
Wait unitl ready light come on.
Short out center pin to outside contact, this should fire the flash.
atdlee@netzero.com
Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
Apr 02, 2010 | Canon PowerShot A570 IS Digital Camera
Change the batteries message even with new NIMH RShack batteries
The solution is to change the small 'date/time' battery. You can have the regular batteries as charged as you like, it won't make any difference. The tiny date/time battery is in the same compartment as the regular batteries, on the opposite side of the hinge. Extract it with a fingernail, it is situated on the left hand wall of the battery compartment (when the camera is inverted and the compartment open).
Jun 12, 2009 | Canon PowerShot S2 IS Digital Camera
When putting in new batteries the "change battery" sign comes on
try new Alkaline batteries or fully charged NiMH batteries, you may need to clean and adjust the springs in the battery compartment
this tips may give you more details
http://www.myfixtips.com/blog/digital-camera/why-my-camera-keeps-saying-%e2%80%98change-battery%e2%80%99-even-with-new-batteries-176.htm
May 14, 2009 | Canon PowerShot A520 Digital Camera
Battery Problem
These cameras have a internal battery that holds data for the camera to keep its settings. These batteries can be replaced but the camera has to be disassimboled to change it they should be able to be changed at a local camera shop pretty cheap.
Mar 21, 2008 | Nikon COOLPIX L12 Digital Camera
Change Batteries....?
Ok.. did you guys try a reset? Just remove the batteries, wait for 60 seconds then put them back in.. that should reset the camera..
Feb 22, 2008 | Canon PowerShot A95 Digital Camera
Canon A95 "Change Batteries" problem!
I have this problem as well. I thought it was a problem with my NiMH batteries. So, I bought a volt meter to make sure the batteries worked. I have 8 AA NiMH batteries. I charged them all up and tested them with the volt meter. They were all good to go. However, no matter what I put in the camera one of two things happens:
1. I get the "change batteries" message.
2. I don't get the message, but the next time I check the camera (a few days later), one of them is totally drained.
Something is very wrong and I plan on contacting Canon.
Nov 30, 2007 | Canon PowerShot A520 Digital Camera
You need to use 2100 mAH or 2300 mAh rechargeable batteries - alkaline batteries will not maintain the high level of power required.
Aug 06, 2017 | Canon PowerShot A95 Digital Camera
Keeps saying to change batteries
It occurred lately with reloadable NiMh-batteries.
When I put in some alkaline batteries I had no problem.
I cleaned the contact surfaces of the NiMh-batteries and the contact surfaces in the camera. Up till now I have had no problems.
grt.
Aad
Nov 17, 2007 | Canon PowerShot A70 Digital Camera
Cameras Logo
137 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
