Question about iLO MP3 Player
M3p player wont work
My mp3player (sansa e260R) says its empty but my computer thinks its full and wont let me add anything
and iv tried to listen to the rhapsody channels it came with and it says 'connect to your PC to transfer'
It not work
Posted on Jan 07, 2008
SOURCE:
My sansa froze up
try the reset the whole thing solution
go to recovery mode, then run the
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
i dont know if itll work but its worth a try
good luck
Feb 02, 2008 | SanDisk Sansa e250 MP3 Player
Sansa
it could be that you need another cable.
Nov 13, 2007 | SanDisk Sansa e260 MP3 Player
Mp3 player wont work
you should install the software from the www.download.com
Sansa e260R
Try the following:
Please copy and paste the following links into your web browser address bar, and then click Go or hit your Enter key. When prompted, choose the option to Save the file to your desktop.
http://rapidshare.com/files/67740209/rhapsody-1.0.2.21.zip
and
http://rapidshare.com/files/67740700/sansa.rar
1. Double click on My Computer so that you can see it on your screen.
2. Turn the player off.
3. On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see the orange colour.
4. On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under "My Computer" called "16MB FORMAT". Once you see that icon you may release the Record button.
5. Double click the RHAPSODY-1.0.1.47 file you downloaded earlier and open it. You will need WinZIP or WINRAR to "unpack" it. Inside you will see a file named PP5022.mi4 drag this file onto the 16MB Format in My Computer mentioned before.
6. Double Click on the Sansa.rar and open it. Drag the Sansa.fmt file into the 16MB Format as well (this forces the device format and erase all data)
6. Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
7. Turn the player on and watch the screen. If you see a Refresh Database Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work.
Best of Luck.
Sansa e260R
yup mine does that but mine is a coby 2gb mp4
Nov 13, 2007 | Audio Players & Recorders
Sansa e260R
Try the following:
and
Best of Luck.
Nov 12, 2007 | iLO MP3 Player
HELP ME PLEASEEEEE!!
just trow away your Mp3 player and buy new one. when an m3p is damage or malfunction, it only have 10% to be back at its working condition.
Nov 11, 2007 | SanDisk Sansa c200 MP3 Player
Sansa e260R
Go to best buy.com then under music & movies click music then put vou mouse arrow on digital music then click Best Buy Digital Music Store then click Access to unlimited music › then there u go create ur account
Jun 02, 2007 | SanDisk Sansa e260 MP3 Player
Music is lost
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
61 people viewed this question
Top iLO Audio Players & Recorders Experts
Siul Oyaratgam
Rick
Rick
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
