GO VIDEO DVD + VCR model: DV 1130 I want only the basic connection
Only audio, no image. Only appears on screen " PROGRESSIVE SCAN MODE". I can't go to menu to check if I can correct it. Please let me know.
MY e-mail is
Thank you.
  • ELDUFF Dec 09, 2007
  • blakeqiu Dec 14, 2007
    On the GoVideo DV2140: Can't find a solution to fix the Progressive Scan Mode to disable it. I only get audio and the tv screen has the blue background with the words "Progressive Scan Mode". Someone on this site suggested plugging the unit directly to the tv. I did. I held the "play" button for much longer than five seconds but the "P" on the unit screen did not go off. Anyone have a manual to upload/download or any other "tricks" to get this thing working? Thank you!! BMN
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Posted on Aug 10, 2008
  • 3 Answers
Unlock Oritron DVD players - DVD hack window.google_render_ad(); Oritron DAV2100 / DVD600 / DVD650 / DVD720 / DVD760 / DVD800 / DVD810 / DVD820 / DVD1030 / DVD2117 / DVD2118
  1. Turn on the player (without a disc inserted)
  2. Press MENU
  3. Press 1, 6, 7
  4. Enter region (MUTE or 0 for multi-region)
Oritron DAV2503 / DAV3102 / DVD2113 / DVD3116 / DVD3119 / DVD4110 / DVD4119
  2. Wait for the "no disc" message
  3. Press 1, 6, 7, 1, 9 slowly
  4. A menu comes up
  5. Select "Configuraton"
  6. Select region (0 = codefree)
Oritron DVD1000 / DVD200
    Method 1:
  2. Press MENU, 9, OPEN, 5
  3. Enter region (MUTE for codefree)
    Method 2:
  2. Press MENU, 1, 6, 7
  3. A menu should pop up
  4. Enter region (MUTE for codefree)
Oritron DVD3112, DVD4112, NPD3117
Posted on Nov 02, 2008
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
Progressive scan
I have a zenith dvd/vcr receiver model LH-C245M i accidentally put it on progressive scan mode and appears on on my TV screen how can i get back to normal viewing? can you help me with this one Please. Thank you hoping for your great response.
Jan 11, 2008 | Progressive DVHE210 210 DVD Player
Issues with my goldstar
Goldstar dvd/vcr combo was stuck in progressive scan. I used the posted solution and now it is out of progressive scan but it continuously reads the dvd and I cannot get the dvd to play. "Reading" conitues to appear on the screen. Any suggestions?
Dec 29, 2007 | Goldstar GBV241 DVD Player/VCR
DVD player wont show picture
to turn it off select connection method 3 above and progressive scanning mode, to set the mode, set progressive to off in the display menu so that the p scan indicator light on the front panel goes out. do all of this in interface mode. you can also do this by pressing and holding PLAY > on the front of the unit for more than 5 seconds, still watch for the p scan indicator to go off. this works best when the unit is connected directly to the television.
Dec 04, 2007 | GoVideo Go Video DVD/VCR Combo
Progressive scan
lpug ur dvd. without turning the power on press and hold the stop button then press the power button
Sep 22, 2007 | Pioneer DV-373 DVD Player
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
GBV441 Goldstar DVD Player / VCR Combo
this is the right solution, the solution in the User Manual doesn't work
Nov 04, 2006 | Goldstar GBV241 DVD Player/VCR
I can not turn off the proggressive scan!
Try this to disabel the progress scan mode: Pointing the remote at the player, press the STOP key to stop any disc that is playing. Next, press the STOP key again and hold it for five seconds before releasing it. This should turn the Progressive Scan off.
Oct 05, 2006 | Zenith XBV442 DVD Player/VCR
Televison & Video Logo
703 people viewed this question
Top Televison & Video Experts
