Question about Acer H233H bmid Monitor
Screen will not display
Everytime I turn on my computer, it will go through it's booting and loading process fine. However after the Windows xp loading screen, the Monitor displays "No Signal" So to get around this I have been booting up in vga mode and set the display properties to my liking then everything works fine after. But this is very inconvinient, so anyone know how to make it work without having to boot up in vga mode?
  • 519 Answers
Have you ensured that your display card driver AND correct monitor driver is installed. This is to make sure that your display card only generates signals that your Acer monitor is capable of handling. If you do not have the driver CD for your monitor you can download the software from www.acer.com. The problem is most likely that your display card is generating a refresh rate which your monitor cant handle. Go to your display properties and lower the refresh rate of your display card and see if this solves the problem.
Best wishes,
Graemevm
Posted on Jun 29, 2009
Try installing drivers for HDMI for that monitor as it probably identified as Plug and Play monitor by you system.
They have Vista drivers on their website. If you have XP you can still download Vista drivers and install it on XP. I fixed all problems with my monitor by doing this.
To install vista drivers on XP:
1. Go to device manager.
2. Expand your monitors list there and double-click on Plug and Play monitor.
3. Go to driver tab and click Update Driver.
4. "Not at this time" for question about connecting to Windows Update.
5. "Install from a list or specific location (Advanced)"
6. "Don's search, I will choose driver to install."
7. Click "Have Disk" and point to your Vista drivers folder, choose HDMI ones (x86 or x64 according to your operating system).
8. Reboot.
That should do it.
Posted on Aug 11, 2009
SOURCE:
Windows xp start up disk doesn't work
if you are referring to the installaion disk
restart your computer during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps you
Apr 16, 2012 | Computers & Internet
Tip
13 Steps to Change or Recover Windows Administrator login Password in...
Have you lost your Windows XP administrator login password, and you don’t know what to do? Here are thirteen simple steps that you can use to change or recover administrator login password of your Windows XP computer.
  1. Insert the Windows XP CD in your CD / DVD drive and restart your computer with him. To do this, after ensuring that established the system BIOS to boot from the CD as first choice. Check your system BIOS to see what is more.
  2. a “Press any key to boot from CD or DVD” message is displayed, press a key to boot from the Windows XP disk.
  3. Windows Setup will now inspect your system and load the required files.
  4. On the “Welcome to Setup” screen, press Enter to start Windows Setup.
  5. Scroll down the Licensing Agreement screen and then press F8 to accept it and proceed further.
  6. On the Setup screen that is displayed next, you may get an option to repair Windows. Select the Windows XP installation you want to repair and then press R to start the Windows repair process.
  7. During the repair process, Setup will first check the disks on your computer and then start copying the required files. This task will take a few minutes.
  8. After the files are copied, you will be asked to restart the PC. If you don’t, PC will restart automatically after 15 seconds.
  9. When the PC restarts, don’t choose to boot from CD. Setup will automatically resume and you will see a message box informing you that the Windows installation is on.
  10. During this process, you need to keep an eye on the left had panel of the screen that informs you about the setup status. When you see that the “Installing Devices” task is in progress, press the Shift + F10 key. This will open a Command Prompt window that you can use to perform several admin tasks on your computer. Surprised! Well, yes the world’s most popular operating system does have a few security loopholes.
  11. At the command prompt, type NUSRMGR.CPL and then press Enter. The User Accounts control panel window will display.
  12. In the User Accounts window, you can perform various user management tasks, such as, reset passwords, change password, create new user, and configure no password login. After making the required changes, close the dialog box, exit the Command Prompt window and then proceed with the repair process. You may need the Windows XP product key, so keep it handy.
  13. After the repair process is complete, you will be able to log on to your Windows XP computer using the new password you set during the repair process. In case, you choose not use a password, you will not be asked for one.
This process will not have any affect your existing programs and personalized user settings. However, if you find this method to change or reset administrator password in Windows XP complicated, you may opt to use a reliable third-party tool, such as Windows Password Recovery Tool .
This is a real handy tool that enables users to perform several Windows recovery tasks, such as recover passwords, make and restore data backup, manage partitions and recover lost data.
aiosp_title=13 Steps to Change or Recover Administrator login Password in Windows XP
aiosp_keywords=windows xp password, xp password, xp administrator password,windows xp administrator password,xp login password,windows xp login password,recover xp password, change xp password, reset xp password, bypass xp password, crack xp password
aiosp_description=Have you lost your Windows XP administrator login password, and you don?t know what to do? Here are thirteen simple steps that you can use to change or recover administrator login password of your Windows XP computer.
aiospwlwbsend-->
on Apr 01, 2010 | Computers & Internet
When I turn on my Dell Latitude D600 PC, the windows xp loading page appears. After it has loaded the screen turns black and does not make any further progress.
It appears that your display works fine until Windows XP loads. Try tapping the key when powering on the laptop. Select boot in safe mode and see if the laptop works.Here's a description of safe mode by Microsoft.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
If your display works in safe mode then you have a video driver issue or virus or software issue.
Jun 20, 2011 | Dell Latitude D600 Notebook
Hi, i have a Sony vaio and it was working fine until I shut it down overnight, the next morning I tried to turn it on which started out fine but as soon as the windows emblem started loading, it didn't...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 01, 2011 | Sony Computers & Internet
I have an asus eee pc 900 notebook, my daughter has pushed something & now when turned on displays the windows xp loading screen, then displays a page that explains windows did not start successfully I...
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this should schedule when you restart then defragment your hard drive
hope this helps
Jan 12, 2011 | ASUS Eee PC 900 Notebook
Can not get it to turn on
Download Hiren Boot cd from http://www.torrentzap.com/torrent/622163/! (9Down.COM) Hiren's BootCD v10.0
Instruction on how to use it...
  • The disk is downloaded as an ISO file. The ISO files can be burned using software programs such as Nero. Burn the disk to a DVD instead of a CD by using a program such as IMGBurn.
  • Booting
  • Once the disk is burned, place it on a DVD or CD drive on the computer and restart the computer. After the computer displays its default first screen, the disk will scan and load the Hiren's Boot menu. The menu gives users three options. The options are to start the computer normally, load Mini Windows XP or load the disk. Choose the disk-loading option to work within the disk parameters and run in DOS. DOS is a simplified process that uses only text. The CD provides shortcuts to each utility.
  • Mini Windows XP
  • To clear a virus and use a large collection of Hiren's Boot tools, choose the Mini Windows XP option. A simple version of Windows XP will load on the computer. It might take a few minutes to load everything because it processes files directly from the CD. Once it has loaded, wait for the Hiren's Boot disk menu to pop up. Select the "Menu" option and scroll through the programs. The disk features Windows password hackers, registry cleaners and a large collection of antivirus software.
  • Antivirus
  • A main portion of the disk feature antivirus software. Spybot-Search and Destroy scans a computer for the most likely spyware and removes it. Malwarebytes Anti-Malware finds root kit viruses and Trojans that could affect computers and spread through networks. Super Antispyware is an all-in-one scanner that detects and eliminates all types of viruses. Run one scan at a time. Do multiple scans because one program might find a virus that another program misses.
  • **Please give a 4 thumb rating..If you find my solution useful**
    Have a Nice Day
    Sep 28, 2010 | Computers & Internet
    Cannot start up
    Do you have a copy of your OS disk:
    Try This:
    insert your Windows XP Setup CD, and restart your computer. 1.
    When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
    2.
    Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
    3.
    Do not choose the option to press R to use the Recovery Console.
    4.
    In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
    5.
    Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
    6.
    Follow the instructions on the screen to complete Setup.
    Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
    Computer monitor becomes distorted after boot up.
    Download and install the correct driver for the monito as well as the deiver for your video card, if the video is onboard, you may need the motherboard and AGP driver as well.
    You will probably need to boot in Safemode to do this.
    Good Luck.
    Feb 10, 2009 | HP Computers & Internet
    Installing windows xp
    Try first  to use hiden boot cd.With it u can see all files on hdd.When u see winxp files just delte.But i will not take responsibility couse sometimes xp wont boot up...
    But i recomneded you to save all your data and format your pc.Make sure that the partition cd must be deltet befor u contiuing with formating ur pc like in this pics:
    http://www.imagehost.ro/pict/3003390347268b3728923.jpg
    Oct 29, 2007 | Microsoft Windows XP Home Edition
    Acer H233H bmid Monitor Logo
    495 people viewed this question
    Alun Cox
    Steve Sweetleaf
    Steve Sweetleaf
