FROM THE OWNERS MANUAL: Installing the SIM Card If your SIM card was not preinstalled, you must install the SIM card before you can use iPhone.
Install the SIM card: 1 Insert the end of the SIM eject tool into the hole on the SIM tray. Press firmly and push it straight in until the tray pops out. If you don't have a SIM eject tool, you can use the end of a paper clip. 2 Pull out the SIM tray and place the SIM card in the tray. The angled corner of the SIM ensures that the card fits only the correct way in the tray. 3 With the tray aligned as shown, carefully replace the SIM tray containing the SIM card in iPhone.
For removing the SIM Card, insert the end of the 'SIM eject tool' (supplied in the box) into the hole on the SIM tray. Press firmly and push it straight in until the SIM tray pops out. If you don't have a SIM eject tool, you can use the end of a pin/paper clip. Pull out the SIM tray and remove the SIM card in the tray. The angled corner of the SIM ensures that the card fits only the correct way in the tray. With the tray aligned as shown, carefully replace the SIM tray containing the SIM card in iPhone.
1 Insert the end of the ''SIM eject tool'' (supplied by apple in the box) into the hole on the SIM tray. Press firmly and push it straight in until the tray pops out. If you don't have a SIM eject tool, you can use the end of a pin/paper clip. 2 Pull out the SIM tray and place the SIM card in the tray. The angled corner of the SIM ensures that the card fits only the correct way in the tray. 3 With the tray aligned as shown, carefully replace the SIM tray containing the SIM card in iPhone. Similar course of action may be done for removing the SIM card.
Hi, How to correct sim card error / insert sim card
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it Step 2: If the sim seater/tray is not broken, clean the entire terminal. Step
3: If the sim seater/tray is not directly on the board, trace the
broken led and solder it, or you replace the broken led with another
sim tray. Step 4: If it is still not working, change the battery and
put a new battery, because a virus infected battery will always give
such problem. Step 5: Finally, if the problem still persist, then
check the sim card and replace with another sim card if the former is
bad because a bad sim card will always display such message as insert
sim card or sim card error.
Procedure to follow
SIM card slot is in top of iPhone. From iPhone Manual:
Install the SIM card: 1 Insert the end of the SIM eject tool into the hole on the SIM tray. Press firmly and push it straight in until the tray pops out. If you don’t have a SIM eject tool, you can use the end of a paper clip.
With the tray aligned, carefully replace the SIM tray containing the SIM card in iPhone.
