Question about Gateway MT3705 Notebook
Laptop power flickers on and off
My Gateway laptop power flickers on and off. I purchased a new charger and doesn't seem to be the problem.Could it be the battery or the plug where the charger connects.Is there any way to rule out the battery without taking it in and costing more money. I don't want to get into alot of money trying to figure out what is wrong.
  • higginsrus Jun 29, 2009
    Thank you! I did that and there is no power at all.So am assuming that it is the plug in area. I am hoping it is not an expensive fix.
  • 61 Answers
Its probably the connector where the power supply plugs in. Pull out the battery and turn on the laptop with only the AC adapter plugged in. If it doesn't turn on, or doesn't stay on, its the connector.
Posted on Jun 29, 2009
  • lazyart Jun 30, 2009
    Sometimes the connector is a separate piece that can be removed (have seen this in some Dell laptops). Most likely though either the connector has to be replaced (and it's soldered in) or a new motherboard (expensive).
    Check fixmyjack.com for some guidance.
I have a gateway nv79 and it won't turn on. The
Step 1:
If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Feb 10, 2013 | Computers & Internet
My zoom g1xn suddenly stopped working. When i connect the power source, it doesn't turn on. . . When i tried batteries, i turned on but the display was flickering then it turned off. . . What is wrong?
Try another cord/charger. Check the AC jack in the machine. Is the battery charging with the cord/charger plug in? Has the laptop AC jack been pulled by the cord? Damaged?
Dec 11, 2012 | Computers & Internet
Charger light goes out when plug in computer
it could be that the connection jack on the mainboard has been dislodged from the solder joint, common among Gateway comuters and HP units too. is the DC jack loose from the notebook ? if so thats the issue it seems. You will have to bring it to a computer person to resolder. if not and youc an do it yourslef, save money -- but be careful not to damage anything on the mainboard.
Jan 03, 2012 | Gateway NV5207u Notebook
I have a gateway mp8708 and it wont charge, boot, or even power the charging led. i tested the charger and itd fine. what could be the problem?
One of two things are likely your problem:
1) The battery is so dead that it's preventing any power from reaching the rest of the PC. Try pulling the battery out, plugging the laptop in, and turning it on.
If that doesn't work,
2) The motherboard power converter is burned out. If this is the case, unfortunately you will need a replacement motherboard or a replacement laptop.
Good luck, and hope this is helpful!
May 18, 2011 | Gateway MP8708 Notebook
I need to purchase a new charger for my Gateway CX2724 laptop. Will any charger for a Gateway laptop do, or do I need to look for one for my model specifically?
there are different voltage outputs and amperage ratings on different chargers. as long as the plug fits, and the numbers are the same, you'll be fine. I would try to get a charger meant for your unit though.
Mar 27, 2011 | Gateway CX2724 Laptop Charger...
WAS MISSING CHARGER, but was running on battery. will not charge battery or power up, no lights. Battery went dead MT6821 GATEWAY
All you need to do is be sure whu will need to replace both.
If the problem is with either the charger/battery you will need to figure that out first.
Please have the battery charged of your laptop, and try using the laptop only with the battery and without the charger, If it works fine you will have to check the charger now.
In order to check the charger, please take out the battery from the laptop, now connect your charger to the laptop and try switching on the laptop. If it does not work then your charger is faulty.
You can purchase the accessories online at various portals. I am providing one of the portal information:
http://www.laptoptraveller.com/battery-gateway-mt6821-laptop-notebook-accessories.html
Sep 01, 2010 | Gateway Computers & Internet
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Hi I have a gateway laptop and I have a brand new charger for it as well, but the computer keeps flickering as if the charger is not in. When the computer is off the battery charges normally, but when it...
Hi
The problem may be the DC power connector beginning to come off the motherboard. This is a fairly easy repair. My company will make the repair better the the manufacturers original. You can take it to someone locally.
Aug 05, 2009 | Gateway Computers & Internet
Gateway MT3705 Notebook Logo
770 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
