Question about Dell Inspiron 6000 Notebook
No sound from speaker can hear sound using earphone
    Problem Solver:
  • 16 Answers
Please ensure that the earphones are unplugged when testing the speakers. also, please ensure that the mute button along the top of your keyboard is not lit-up or in the off position. (usually looks like a speaker with a strike through it).
please also check for a volume control switch or button that mey be set very low.
Posted on Jun 30, 2009
I'm not getting any sound out of the speakers. I have sound through my headphones but cann't get anything out of any speakers.
If you can hear the sound from the headphone(earphone jack), the fault is between the headphone itself or the speakers. Check the continuity of the speakers(voice coil) using the multimeter to determine if it is faulty or not.
If you've confirmed that the speakers are not the issue here, you may spray an electrical contact cleaner to the earphone jack of your unit while pulling and inserting the headset plug to clean the contact from dirt build-up inside. You may also replace the earphone jack with new one to back the unit in normal operation.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 18, 2011 | Teac AG-V8060 Receiver
Can't make a call do to no sound everything else works but, no sound. I plugged earphones in to listen to music and when I unplugged it I know longer could hear phone calls or when I dial the phone.
Mark, the issue with your phone is with the speaker. This has been confirmed by you when you say the there was sound produced when you used earphones.
You have to get your speaker fixed. Get it done at a local repeir store aroud you.
But in the meantime you could use the earphones for your calls so you can hear them.
But you may still have an issue- hearing your in coming calls- so if you can get a bluetooth headset, that you can hang around your ears, you would hear the calls coming in.
I hope that was helpful to you.
Have a lovely day.
May 27, 2011 | LG CHOCOLATE VX8500 Cellular Phone
No sound
Hi tom2105,
First make sure that the sound is not in "mute" mode.
Plug your headset to the earphone jack(if installed) of the TV.
If you can hear the sound there, the fault may due to open(defective) internal speakers or the earphone jack itself. Faulty internal speaker may replaced with new sets to back your sound to normal again. If the earphone jack was faulty, you may spray it first with electrical contact cleanerwhile inserting and pulling the headset plug into it for one minute to clean the contact. If nothing happens, this jack need to replaced with new one.
If you can't hear the sound after inserting your headset, this is an indication that the audio circuitry was gone bad. The most common caused of this trouble was the faulty sound IC(mounted in heatsink). This is the one converts the audio signal to sound and feed to your speaker's. I would advice you to look for a qualified technician to check this parts.
Hope I helped you.
Have a nice day!
Apr 25, 2011 | Vizio L30WGU 30 in. HD-Ready LCD...
No sound from my stereo but powers on and can see EQ is moving. But when I plug my headphones in i get sound just nothing from the Speakers
Your problem is in between the speakers and your earphone jack but it has a hight chance that the fault is in the earphone jack.
Since when you plug your headseat, sound is coming out, this is an indication that your output IC is working. When you plug the headset the line will cut-off through your main speaker to hear the sound in the earphone only. But if you unplug the headset the contact will back to the main speaker. The problem is, the lead is dirty due to dust. You can spray it using the contact cleaner. I will not advice you to spray any penetrating oil but contact cleaner only. If the symptom is still there then this is the time to replaced the earphone jack with a new one.
Hope it may help you.
Have a nice day.
Thanks for using fixya.
JDVillanueva
Jan 31, 2011 | JVC HX-GD8 CD Shelf System
No SOUND
If it has an earphone jack try to hook up your headset just to get hint if your problem is in the sound output ic. Listen carefully to your headset if there is a sound or none. If you hear a sound then you the trouble is in between the earphone jack or to your speaker. Just test the speaker and you will isolate the problem. How to test the speaker if good, simple got a battery (either AAA,AA,C,D size) then tap the speaker across the battery when you hear a crackling sound then it is good. If you confirm that the speaker is good then the faulty parts is your earphone jack, replacing it will cure the problem. If you don't hear a sound then through your earphone then the trouble is in the output I.C. or some parts around it and you need a technician to isolate the problem.
If you don't have an earphone jack then I've advice you to look for a qualified technician to look for a defective parts on the sound section.
Thanks for using fixya...
Jan 07, 2011 | Televison & Video
I cant hear anything without earphones
If you have left the earphone plugged in to the laptop for a long time, this may have bent the contacts in the socket, and stopped the speakers from working.
Apr 09, 2010 | Microsoft Windows XP Professional
Itouch loudspeaker, earphones?
No just the models with that feature have the loudspeaker. my girlfriends sisters ipod touch doesnt have it either. I hope that helps you out.
Dec 31, 2008 | Apple iPod touch
Speaker no sound
In the socket where you plug in the external earphone are bending contacts, which also switch of the speaker when you are using an earphone. Try either putting in the jack and wobbling and twisting it, or tapping the corner with your knuckle.
IN EITHER CASE - BE GENTLE
That will knock of the dirt and the switch will work again
Dec 10, 2008 | HP iPAQ hw6515 Pocket PC
-mate JAM Pocket PC Problem
Try putting in earphones and check. Sometimes the contact inside the earphone jack jams against each other and then the phone thinks there are earphones plugged in thus bypassing the speaker.
Oct 27, 2007 | i-mate JAM Pocket PC
Dell Inspiron 6000 Notebook Logo
75 people viewed this question
Alun Cox
