Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Deck belt keeps tearing up then falling off
The decking V Belt broke. I replaced it with a new one and now that one is tearing and fell off after about 10 minutes of mowing. I checked the diagram and the belt is on the pulleys correctly. Just wondering.......is the pulley in the very front supposed to turn easily? Mine isnt.
  • Dwain Pippen May 11, 2010
    What is the model number under the seat so I can see what you have?
    Genius:
  • 1,114 Answers
If it's an idler pulley, where the belt changes direction from the engine - yes it should turn freely. If it's a double pulley where the drive pulley from the engine connects with the deck/blade pulley, then it it's not going to turn totally free because of the blade pulleys connected to it. But in all cases, none of the pulleys should be seized. Try using WD40 or PB Blaster on the pulley bearing surface to loosen it up - or a new pulley...
Posted on Jul 02, 2009
Have a 1045 ltx cub cadet lawn tractor,belt for deck keeps coming off when disengaging?
be sure the belt guides are in place. they hold the belt in so the belt wont fall off when not tight or at an angle.
Jun 29, 2017 | Cub Cadet Garden
Tip
95T Treadmill Belt and Deck Replacement
Video Demonstration of a Belt and Deck Replacement on a Life Fitness 95 T Treadmill
  • This video demonstrates the steps necessary when performing a belt and deck replacement on a LifeFitness 95T treadmill
  • Tools Necessary:
    • 9/16" Socket Wrench or 9/16" Hand Wrench
    • Long Flathead Screwdriver
    • Phillips Screwdriver
    • 4MM Allen Wrench or Allen Socket
    • 8MM Allen Wrench
    • Plastic Putty Knife
    • Shop Vac or Vacuum
  • Begin by turning off power at the treadmill and unplugging the unit from the wall
  • Remove the upright tube caps from the inside of the uprights
  • Remove the Phillips screw and tilt the cap in at the top
  • Remove the motor shroud by first taking out all four screws in the shroud
  • Then remove the screws at the top of the front panel and loosen the lower screws
    • This will leave enough play to remove the shroud as shown in the video
  • Now with the Phillips screwdriver, remove the finger guards at the end of the treadmill from each side of the rear roller
  • You will need to slightly twist the finger guards to get them out from under the belt
  • Using the 8MM Allen Wrench, loosen the bolts on each side of the rear roller by 10 full turns
    • At this point, you can completely remove the rear roller bolts while keeping count of the number of turns at each side of the roller
  • Do not include the 10 full turns from the previous step, only count the turns for this step and make note of the number of turns for future referenc
  • Carefully remove the rear roller from the treadmill and set it aside
  • At the motor compartment, use the long flathead screwdriver to lift the tensioner arm and remove the drive belt from the drive motor pulley
    • CAUTION Pinch Point
  • Using the 9/16" socket wrench or hand wrench, remove the bolt from the front roller mount
  • Carefully remove the front roller from the frame and set the roller aside
  • Use the 4mm Allen wrench or socket to remove the 4 deck bolts from the deck
  • Once the 4 deck bolts are removed, you can pull the deck and belt from the frame
  • Be careful to not let the deck drop too far down into the frame during removal
  • Damage to the anti-static tinsel can occur if deck drops too low into the frame (as seen in the video)
  • It is recommended to thoroughly clean the treadmill before completing your belt and deck replacement
    • While the belt, deck and rollers are out of the frame is a great time for cleaning
    • Dirt, debris or other contamination can cause noise, early damage or premature wear on new parts
  • Use a plastic putty knife to scrape away any debris build up from the front and rear rollers
  • Vacuum most of the painted surfaces then wipe clean with a Sportsmith equipment wipe
  • Once you've completed the cleaning of your treadmill, it should now be ready for reassembly
  • It is necessary to install a new deck surface with the new treadmill belt
  • Your unit may have an unused side of the deck that can be flipped into use or the deck may need replaced
  • Before installing the new deck surface, inspect the tinnerman clips
    • The tinnerman clips are what the deck bolts thread into
  • Simplify the installation process by placing the new treadmill belt over the new deck surface
    • Ensuring the belt is installed in the proper direction
      • If marked, use the arrows on the inside of the belt
  • Now place the belt and deck into the treadmill as a unit
  • Install the front two deck bolts (closest to the front roller) about half way
  • Then use a long tool to line up the deck holes by the rear roller while placing your weight onto the deck to allow the bolts to start
    • Install these bolts in about half way
  • Now tighten all four deck bolts
  • Carefully insert the front roller under the treadmill belt and into place
    • Making sure to install the drive belt over the pulley on the front roller
  • Install the pulley end of the roller into the frame and align the other end with its bolt hole
  • Install the bolt and using the 9/16" socket or hand wrench, tighten it
  • Again, use the long flathead screwdriver to lift the tensioner arm and reinstall the drive belt onto the drive motor pulley
    • Practice CAUTION as this is a Pinch Point
  • Install the rear roller under the belt and while pulling back on the roller install the roller bolts on each side
  • Remember to keep count of the number of turns on the rear roller bolts
    • Reinstall the roller bolts using the same number of turns you noted from earlier
  • The belt may still be too lose, but that is ok as it can be fixed in a moment
  • Plug the unit back into the wall outlet and turn the power on
  • Start the unit at a very slow speed and observe the tracking of the belt
    • If the belt is not turning with the front roller, make small equal turns of the rear roller bolts until the belt begins to move
  • If the belt moves quickly to either side of the frame, quickly press the STOP key to keep the belt from being damaged
  • If the belt is moving to the left side of the unit, you can tighten the bolt on the left side of the rear roller
  • If the belt moves to the right side, you can tighten the bolt on the right side of the rear roller
  • Once the belt is tracking straight, move on to the next step
  • Re-install the finger guards over the rear roller with the Phillips screwdriver
  • With the unit stopped, step onto the treadmill and straddle the running belt with a foot placed on each side of the frame
  • Start the unit at a walking speed and begin to walk on the belt
    • If the belt stops on your foot fall or with your weight, make small adjustments such as 1/4 turns on each side of the rear roller until the belt slippage or hesitation is no longer felt
  • Continue this adjustment until no slippage or hesitation is felt at running speed
  • Now reinstall the motor shroud and upright tube caps
  • Log the repair into the Maintenance record of the treadmill display electronics
    • Press STOP then hold the PAUSE key until the display comes on and reads SERVICE MENU
    • Use the UP or DOWN arrow to scroll to MAINTENANCE and press ENTER
    • Display now reads MAINTENANCE MENU
    • Use the UP or DOWN arrow, scroll to REPLACING BELT/DECK and press ENTER
    • Display will read REPAIR LOGGED and will then return to the SERVICE MENU
    • You can press STOP key to exit the SERVICE MENU
  • This completes the belt and deck replacement on the LifeFitness 95T treadmill
Life Fitness Treadmill Belt and Deck Replacement Video 95T
on Apr 28, 2014 | Life Fitness Exercise & Fitness
A diagram of deck belt on deck 46 inch cub cadet
Look here then when you put in your Model number look under ATTACHMENTS for a parts diagram showing the Belt layout
http://www.cubcadet.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10051&catalogId=14101&langId=-1#/s/CUT/782/
Jul 27, 2014 | Cub Cadet Garden
Toro 17-44 can't keep deck belt from coming off
is the deck adjusted level?is it the right belt?
Apr 23, 2012 | Garden
Belt is being cut
you might have a bad pulley somewhere else on the deck or you may have the belt on wrong
Apr 14, 2012 | Garden
The cutting deck is so unstable & the belt drive
For the deck,they do move it allows them to cut evenly on uneven surfaces.Lower the deck and inspect everything on top of the deck.These mowers have several arms to hold it in place.Make sure none are disconnected,or have broken clips.Make sure to wiggle each of the arms,some times they can fall in a position so that it looks like that is where it belongs.
As for the drive belt.Just keep the mower out of the weather as best as you can.Feel the pulleys for burs,and make sure there is no debris hanging that may be scrapping the belt.
May 14, 2011 | Troy Garden
The deck belt keeps falling off of my Troy-Bilt 14AT809H766 Horse riding lawn mower. Why? How do I fix it?
Either the belt is stretched out and needs to be replaced or there is an idler/tensioner pulley that may be weak and not putting enough pressure on the belt.
Jun 30, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
I have aTroy Built Super Bronco MD 60TG in the operators Man page 44 part #26 Spring Ext .94Dia, 6.74 fell off can not find where to reinstall can you send a diagram or tell me. Pat
The spring is connect to a stud on the front side of the deck in front of the right pully as you look at the mower. The rear of the spring is connected to an brace at the back of the deck behind the same pully. This spring assit in keeping the V-Belt tight when the blades are engaged. Fault stud broke needed replacement.
Sep 15, 2009 | Garden
Having trouble replacing a 42 craftsman riding mower belt...help Ithe old one broke off but the new one it on too tight...the replacement one is the right lenght help please
do you remember the routing of the belt? there should be a diagram on the deck somewhere - best thing to do is rout the belt while the deck is lowered, leaving the loop at the front to put around drive pully on bottom of engine. once that is all hooked up, there are deck adjusters on either side of the deck - that you can adjust to relieve some of the tension on the belt - turn the adjusters clockwise to tighten, counterclockwise to loosen - let me know if this helps or if u need more info - i have a 10 year old 42" deck tractor out in my barn and if need be, tomorrow i will walk u through - online how to adjust the deck
Sep 06, 2009 | Craftsman Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
259 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
