Why doesn't my ac work on 97 pontiac sunfire? (It's full 134a)
  • steven_hamil Jun 29, 2009
    I checked & the compressor is coming on & the a/c high line is getting cool but not cold, the car is a 96 sunfire.
  • 1,056 Answers
Check to see if the compressor is coming on. Turn of the engine and inspect the wire going to the compressor clutch. make sure it is not unplugged. Check all the wires to the pressure switches, make sure they have good contact. Note: never put 12V to the compresso clutch unless you have good knowledge of electronic, and electrical system. You can really damage some electronic circuits inside. If there is no 12volts going to the compressor clutch, check for blown or missing fuse. See if a relay clicks. When you turn on the ac.
Posted on Jun 29, 2009
  • Ronado Panaligan
    Ronado Panaligan Jun 29, 2009
    You meant the low side is not getting cool. The high side is suppose to get hot. Check the low side pressure. It should start at around 45 psi, and gradually go down. If its too high like 60psi it might be overcharged or there maybe a clog.
Heater doesn t work
Your control panel might be broke..
Sep 25, 2013 | 2002 Pontiac Sunfire
Code to unlock the radio in a 97 sunfire
The radio will have to be removed from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or engraved in the metal casing.
Jul 03, 2010 | 1997 Pontiac Sunfire
97 pontiac sunfire
They are called wiper arms. Not sure of the 12x12 part?
Mar 12, 2010 | 1997 Pontiac Sunfire
Type of freon is used in the 97 Sentra A.C.
The sentra uses 134A freon. Happy hunting!
Oct 29, 2009 | Nissan Sentra Cars & Trucks
Coolant light won't go off on 97 Pont. sunfire
try checking the coolant resivoir level sensor has not come loose or got a bad conections in the plug.
Jun 01, 2009 | 1997 Pontiac Sunfire
A diagram for 95 pontiac sunfire 2.2l with ac
can u hook up a 2200 1998 sunfire motor in a 1995 sunfire 2,2?
May 09, 2009 | 1995 Pontiac Sunfire
97 pontiac sunfire 2.2 liter serpentine routing diagram needed
this is normally located under the hood next to the hood release lever if it is missing from yours then try www.autozone.com or go to your local Pontiac dealership in the parts department or an auto parts store like Napa or Autozone
Apr 26, 2009 | Pontiac Sunfire Cars & Trucks
Clutch problems
Best clutch to uae in the sunfire is the AC Delco replacement cluch kit. It can be bought at most parts stores, and it will come with the throwout bearing, preasure plate and new disk. If your not equipped with a car lift and engine supports craddle, it can be difficult.
May 28, 2008 | 1997 Pontiac Sunfire
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
