Question about Philips Magnavox 27MS343S 27" TV
Closed caption how do i turn the closed caption on? Thank youl
  • 1,694 Answers
Go thru menu pages one at a time until you find CC / Text...
Selections might be CC1 , CC2 , CC3 , Text 1 , etc. You may
have to try each CC for your signal source......T.
More details = more help !
Posted on Nov 07, 2007
Update my roku for closed caption on my roku
To change Closed Captions settings, go to Settings>Captions Roku Closed Captioning Help
Mar 06, 2014 | Televison & Video
I have a Sony KV-27ts27 television that I bought secondhand, without a remote. I need to know how to turn on closed captions. When I had cable service with AT&T Uverse, the closed captions were working but...
Here is a link to the manual. It appears to me your set does not support closed captioning. It is too old. It mentions channel captioning, but that is for a channel identifier for reference. KV-27TS27
Oct 31, 2013 | Televison & Video
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
80% of the picture is black
Ok, if the video is present around the outside of the black box you have a problem with close captioning. It is stuck in either Text 3 or Text 4 mode. The options for close captioning are CC1, CC2, Text 1, Text 2, Text 3 and Text 4 and of course OFF. Apparently the close captioning is stuck on or is not being properly shut off. Better read the owners manual to see if you are missing a step when turning off close caption.
May 27, 2009 | JVC Televison & Video
Cant get rid of closed captions on dvd player
go to menu turn off captions thank you for using fixya
Feb 12, 2009 | Philips Magnavox DVD/VCR Dual Player
Closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Nov 27, 2007 | LG 42PX5D 42 in. Plasma HDTV
Closed caption
Solution #1posted on Jul 23, 2007 By QTV1 Rank: Guru Rating: 93.33%, 6 votes Press menu on the remote. Press the cursor up or down button untill the word CC is highlighted. Press the cursor right button to select Closed Caption 1. You will likely have to do this with the original remote. A universal remote may not allow you to do this.
Jul 22, 2007 | Philips PR1902C TV
Closed Captioning on HD channels
We had the exact same problem just yesterday when we bought our Sony 46" Bravia LCD. Nobody, neither Comcast Cable or Sony seemed to really know how to get rid of the closed caption at first and we did have a Motorola box - the box is the problem, not the tv. Here is step-by-step instructions that worked for us. 1. While TV is on, power DCT (Digital Cable Terminal) off 2. Press and hold "menu" button on digital terminal (the screen below will appear) 3. Using Up/Down cursors, highlight "Close Caption" 4. Using Left/Right cursors, put - Close Caption: Disabled 5. Press "ok-select" 6. When done, press "power" to exit menu 7. Press "power" again to turn DCT on If you go through these steps slowly, you should have a caption-free screen!
Jul 09, 2007 | JVC AV-48WP30 48" Rear Projection...
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Philips Magnavox 27MS343S 27" TV Logo
422 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
