Question about Linksys Wireless-G WRT54G Router
Router not working at all!
Hi!
I bought my Linksys G Router less than a year ago. It worked just fine. Recently, I sometimes had to disconnect it and the modem from the power outlets, and reconnect in order to establish the wireless connection.
However, my router is not working any more. I tried connecting my laptop directly to the modem, and that worked. However, the wireless network is not working and connecting my laptop directly to the router was also in vain.
Is this problem fixable, or should I start thinking about replacing my router altogether?
Many thanks!
  • 4 more comments
  • daldabba Jun 29, 2009
    When I completely disconnect it from power, and reset it, at the beginning, it connects temporarily, only to disconnect permanently afterward.
    No errors are displayed. Thanks :)))
    Okay, in following the instructions provided, as I opened up the browser and typed in 192.168.1.1, Error 800 popped up, unable to establish the VPN, unreachable, or security parameters etc
    Rogers is my service provider
    Okay, now it worked, only when my brother tries to connect to the network from his own laptop, the connection becomes very sketchy, turns on and off randomly and quickly. I had him turn off his wireless, so that i can use mine
    I have the WRT54G model
    thank u so much!
  • Chitownbarb
    Chitownbarb May 11, 2010
    what model is your router from linksys?
  • Niqui Itliong
    Niqui Itliong May 11, 2010
    Hi! you may need to hard reset the router and reconfigure your router settings. To hard reset, press the reset button for 30 seconds while the power is on. restart the router. What's your connection settings when directly connected to modem? Cable or DSL? If on DSL, do you have a username and password from ISP? (Do not provide your username and password info here). Connect the modem to the Internet port of the router- check the lights on the Internet port at the router's front panel to verify that it's ON. Otherwise; use another known working cable. Connect the PC to any of the numbered port on the router. Check again that the lights are lit on the corresponding port number; otherwise , try a known working cable. Open a browser and type 192.168.1.1 on the address bar. Leave username blank and type admin as password. On the Internet connection type, select PPPoE, if you have username and password from ISP. Enter the username and password then click on Save Settings or Apply. If you don't have a username and password, just leave the settings to obtain automatically. Check on Status tab if you have an Internet IP address. If you do, test your internet connection if it's working. If you are on a cable connection, you may need to enable MAC address cloning. Check on any of the tabs to see this setting as it differs based on your router's firmware version. Since you have mentioned that the router keeps losing the connection, you may need to upgrade its firmware. Contact Linksys for assistance on the upgrade. Hope this helps.
  • Chitownbarb
    What kind of errors are you getting or is it just not working at all?
    Sergeant:
    Novelist:
  • 198 Answers
Go to Control Panel- Network Connections-Network Connections and look for anything that says VPN or PPTP. Right-click on it and click disable.
Go back to your browser- click on Tools- Internet Options-Network Connection and make sure Never Dial A Connection is enabled. Click on LAN settings and make sure nothing is checked. Click OK.
Try to log back in to your router by tying in 192.168.1.1 and reconfigure the settings again.
Posted on Jun 29, 2009
  • 21 Answers
Go to Internet Options, using the connection tab, removed any connection to Dial-up and Virtual Private Network settings. If you get the 800 message do you have the capability to cancel it? If you do then you can go and do the above and see if that helps you. If you did do a hard reset to the router you have to fix all your settings again. Also, go to the linksysbycisco.com site and see if you need a firmware upgrade.
I’m happy to assist further over the phone at https://www.6ya.com/expert/barbara_87cfe34e34050f26
  • 60 Answers
In that case you may reset the router to factory default and then reconfigure. Who is your ISP?
Router works well most of the time....then for past two weeks it won't rout to other 2 PC and will not allow me to access modem. If I disconnect and plug in direct to PC modem works. Called high speed...
I have had similar problems in the past with 3 different brands of wireless routers, including the linksys Wireles-G router. In all cases, it was the same scenario, worked fine for a year or so, and then started giving inconsistent intermittent connectivity problems. Resetting, recycling etc. etc. would work for a while and eventually it would become unusable, and I would end up replacing. I went from a D-Link wireless router, to a Belkini, to a Linksys, and now use the Apple airport wireless, which I have also recently replaced with another Apple airport wireless. So unfortunately, I can't tell you if it's me doing something to kill them or if they are just short life expectancy for wireless routers, but the only fix I have experienced is replacing the router. Good luck...
Aug 30, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT54G2 Wireless router unable to connect to Internet
Try again by Disabling the WEP (or WPA), MAC Address Filtering and Firewall Setting Individually. Should be a problem with one of those. Then when you receive the Signals, try to Adjust using Bottom Up method. That means one setting at a time, Hardening the Security. Have you checked your DNS settings? Have you checked the Channels you are using? Re check them and try again.
Feel free to contact back.
Please rate the answer if it helps you to solve the issue.
Thanks for contacting Fixya!
Jun 12, 2010 | Linksys WRT54G2 Wireless Router
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless g broadband router begins flashing 2 ethernet ports simultaneously and consequently internet unavailable. Tried moving cables around between the three available ports and the same thing...
Hi
Dont think that the router is dead
1.Make a hard reset
2.Reconfigure
3.Install the latest version of firmware
That should definately sort the problem out and do let me know
Mar 10, 2009 | Linksys Wireless-G Broadband Router
Wireless won't connect anymore
Geek squad is expensive. Have you called linksys techsupport? Here is another option, try http://technicalsupport.blog.friendster.com
Jan 20, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Network has suddenly dissapeered
This is just a problem with the wireless settings of the router, you can try first to reset the router by pressing the reset button for 20 seconds while power is ON and then after that you should be able to find the default wireless name of the router which is linksys, after you reset the router just need to reconfigure it back...
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
Wireless G WRT54GS
check your laptop firewall setitings.
and also your antivirrus fire wall disable it then try.
Nov 09, 2008 | Linksys Computers & Internet
Linksys nro41 4-port router
Hi, I read your site and took it for face value, hoping to solve my problem. Like you offered, I would gladly pay $10 if your solution worked. But it seems like so many sites, pay up front and get ........... Sorry Paul
Jul 04, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
172 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
