Question about Jabra BT350 Bluetooth Headset Headset
My bluetooth wont pair, the light wont even come on, is it broken or am i doing something wrong?
  • ronald lacamera Jul 26, 2013
    my bluetooth lights wont come on and it pairs with my device it just doesent connect
Why wont kinivo bth220 wont link with my phone no matter what i try
Can you confirm if you are able to put the BTH220 headphones in pairing mode. Please try the following steps and see if works:
  1. Make sure that the headphones are fully charged.
  2. Switch off the headphones.
  3. Put the headphones in pairing mode by pressing the MFB button (center) for 7-10 secs till you see the red and blue LED blinking alternatively. Please do not leave the button as soon as blue LED appears.
  4. Follow the operating instruction of your Bluetooth device to start the pairing process.
Sep 29, 2012 | Kinivo Bth220 Bluetooth Stereo Headphone -...
Need to hard reset motorola mini bluetooth h9
try removing the pairing to your phone and pair again. If this does not work try pairing your headset to another phone and if it does it on that phone then something is wrong with the earpiece return for repairs if under warranty or if you are willing to pay for the repairs if out of warranty or replace ear piece all together as they are reasonably priced these days. If the ear piece works fine the other phone something has gone wrong with the bluetooth side of your phone return for repairs or replace depending on what you can afford to do. I hope this helps.
Aug 26, 2012 | Motorola Mobility H9 Mini Bluetooth...
Im trying to connect my Jabra BT350 to my blackberry 8520 but my blackberry bluetooth wont even find the device even the Jabra headset is turned on.....i also lost my Jabra BT350 user manual cd and i dont...
The headset has to be in learning mode first for any phone to find it, press and hold the power on button for 8 seconds until the power light comes on and stays on then search for it with your phone, pairing code can be 0000
Aug 29, 2010 | Jabra BT350 Bluetooth Headset Headset
Jabra BT2050 blinks three times; doesnot pair up
Hold round center button for 10 seconds, light will stay on and be in pairing mode.
Nov 20, 2009 | Jabra BT2050 Bluetooth Headset
Can't switch bluetooth to my phone!
you need to reset your bluetooth to factory setting.
to reset, press and hold the call button while turning it on.. you'll see the light will flash and ready to pair.
Mar 28, 2017 | Samsung Cell Phones
H710 blutooth setup problem
Try the same thing, but manually hold the boom arm in the fully open position. Seems like these units may have a faulty switch that fails to recognize when the boom arm is open or closed.
Mar 02, 2009 | Motorola Mobility H710 Bluetooth Headset
I cant pair motorola H350 to Voyager
Can you pair the voyager with anything?
Are you putting the bluetooth headset into pair mode correctly?
Feb 06, 2009 | LG VOYAGER VX10000 Cellular Phone
H-700 motorolla bluetooth
1. Bluetooth enabled?
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Dec 19, 2008 | Motorola Mobility H500 Wireless Headset
My bluetooth haeadset disconnect its self from my handset.
Well it could be one of two things. Either there is something wrong with your phone holding the connection to your bluetooth or there is something wrong with the bt device. Test this by pairing up the bluetooth earpiece with a different device. What kind of phone are you using to pair the device up with??
Nov 18, 2008 | Cell Phones
Bluetooth
I will take a guess that you are trying to pair with something other than a bluetooth headset. The iPhone cannot connect (even though it may pair okay) to other phones, headphones, or any device other than a bluetooth headset. This feature is intentionally crippled by Apple.
If my assumption is wrong, please provide additional information about what exactly you are trying to do (and with what) to get your problem resolved.
Jan 12, 2008 | Apple iPhone Smartphone
Jabra BT350 Bluetooth Headset Headset Logo
176 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
