Related Tags:
This problem should be removed because:
Problem with Alpine PDX-4.100 Car Audio Amplifier
amp going into protect mode
I have an alpine pdx.100 running 2 type x component speakers in rear deck and two 6 1/2 type rs in my kick panels. whenever i turn them up loud the amp kicks off. if the gain is too high will this make it go into protect mode. I have alreafdy changed my alternator and voltage regulator. any help?
Solutions (1)
If you set the gain too high on the AMP, at loud volume levels some clipping or distortion of the output signal will occur. Most amps have a Circuit inside that detects this clipping or distortion and applies protection to prevent damage to the speakers and the amp. It would help to know if you are driving the speakers with a Line level output or using the speaker output from your deck. There are many things that can cause an amp to go into protect mode, and knowing a little more about your setup will help to solve the problem.
car amplifier wont turn on
my car amplifier wont turn on, it was working 2 nights ago but on the way home it just died and this morn it turned on but only got one bass...
Alpine PDX 1.1000 low power output - sub not loud
I bought a new Alpine PDX 1.1000 amp to power a Pioneer 12" sub (TS-W1241C) rated at 600 watts nominal/1000watts max. The sub is about...
i have an alpine pdx
i have an alpine pdx 1.600 powering a 10 in. JBL woofer with a jvc KD-G340 head unit. i have hooked it up to spec but when i turn the head...
hi.i've got Alpine PDX-2.150 Car Amplifier and...
hi.i've got Alpine PDX-2.150 Car Amplifier and one day it blow the fuse's.i checked and it was blown MOSFET's (all 4) replaced...
Add Your Solution
i need to replace a circuit board in an alpine...
the audio input plugs are broken
When listening to music, I notice channel2 has
When listening to music, I notice channel2 has loads of noise. Fuzzy noise almost as if its an old record playing. The...
Just installed new pdx-4.100. Music stops
Just installed new pdx-4.100. Music stops for a few seconds then comes back on by its self when radio (also new) is...
i just installed this amp and i have a low static
i just installed this amp and i have a low static noise through all the speakers. if i turn the volume up the static...
my pdx 4.100 make hissing,
my pdx 4.100 make hissing, why? i try use the other brand rockford amp no hissing. i try put out RCA cable from pdx...
Fix-O-Meter
156
156 people viewed this problem
- 0 people are following this problem. Be the first!
Top Alpine Car Amplifier Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
Setting the Gain too high will cause the protection circuit to turn on.
The best way to set is as follows:
If your amp has a Clip indicator LED, you should set the gain so that the LED barely flickers when you are playing at loud volumes. If you dont have a Clip Indicator, adjust the gain to just below the point you start the hear some distortion in the output signal.
If that still does not fix the problem, try the following:
Double check all your power and ground wiring. Make sure you have good, solid connections on your power feed wires from your battery and a good, solid ground connection close the amp. If the connections arent good it can cause power loss through the wires which can contibute to Clipping and Protection problems.
Excessively long (20ft or more) power wires will cause these problems too, and you may have to try using a larger gauge wire (4 or bigger on long runs!). Most Amps will draw almost 10-15A of current under heavy load and this can result in a loss of about 3-5v at the amp end of the wire so your amp only sees 7-9v of the actual 12 you want to give it. This can be alleviated by using a capacitor (1F or so), if you have the money, but it may not solve the problem. If you can, shorten your power supply wires and try a different ground.
Also you can check your speakers to make sure their impedance or 'Ohms' are within the specs for the amp. Check your owners manual for your speakers and amp to get this information, or look it up on line. Most amps like about 4 ohms or more to work properly. It may also be printed or typed on the bottom and back or your speakers and amp.
