Question about Kenmore Washing Machines
Washer will not stop filling up
Will not stop filling up. model number 110.28912790, serial #cj2016719
  • 15,935 Answers
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Washer stops and fills more than normally during wash and stops after a few seconds and just continuously beeps and it flashs constant where it says wet on the cycle . It is a whirlpool duet 4.0 front...
Christina Johnson, we're sorry to learn of your concern. We'll be glad to further review. Please send us an email with your name, contact number, address, model and serial number at Whirlpool_Reviews@Whirlpool.com.
Oct 14, 2017 | Whirlpool Washing Machines
My magtag washer leaks only when i am filling it
First you need to list the model number and possibly the serial number if you can find it in order for me to figure out what type of washer it is then i can help you. I will also need to know whether it is a top load or a front load. Thank You. You may need to re-ask the question with the model number and serial number or message me at etsi00257@hotmail.com because I am a certified appliance repairman and have repaired quite a few Maytag washers.
Mar 10, 2013 | Washing Machines
My washer is leaking when i fill it
First you need to list the model number and possibly the serial number if you can find it in order for me to figure out what type of washer it is then i can help you. I will also need to know whether it is a top load or a front load. Thank You. You may need to re-ask the question with the model number and serial number or email me at etsi00257@hotmail.com because i am a certified appliance repairman.
Whirlpool model wtw6600sw2 makes a squeeling noise when attempting to fill
I would call the Whirlpool machine repair person for a quote as only an experienced engineer will know what the problem is eric
Jan 13, 2018 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer is filled with water after running it completely damaged my blanket because it got soked in water!!!
your pump motor is out, whats your model number and serial number, i could probably source the pump motor part number for you......if your washer is filled with water, and not draining, your motor is out........these LG motors go out fast....
Feb 09, 2010 | LG WM2688HWM TROMM SteamWasher
Washer fills and starts for a while and then stops
I recieved the followng letter from sears last week since we had registered our OASIS He washer two years ago since we purchased it new. The washer has a serial number that is authorized to get a replacement board, and the part has been shipped to my house. Once it arrives, we are to call the local Sears dept for someone to install the new board.
For washers that have the first four of the serial numbers as:
CS48-CS52 or CT01-CT49 qualify for the replacement Control Board.
1-800-847-9083 between 8am-8pm M-Saturday.
Good Luck all.
Mar 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Free advice on what recalls maytag is fixing free on front loading neptunes w/built in water heater
Fee advice???are youlookingperhaps for possible recalls on the maytage front loader?? a call to the manufacture with the model and seriasl number will enable you to acess all the current recalls
Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Tub fills with water
replace water valve in the washer. Serial number is needed to find the correct part number. It's likely 22003834, but call any parts supplier with model/serial numbers to verify.
Good luck,
Vlad
First Choice Appliance
Jan 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Whirlpool
Whirlpool
