Question about Lite On Televison & Video
Parts for LiteOn p/s PB-8600-1 and PB-8600-3.
The immediate part we need is transformer 42-M86001P01 and 42-M86003P01 used in LiteOn power supplies for cable television converter boxes.
likha
  • 790 Answers
SOURCE: sony trinitron wide kv-32ls35b or kv-32ls36b
Hi
you have defective parts in power section! the problem is the power oscillation circuit! here in the philippines the cost of this trouble in around 2500 or 3000 pesos parts and labor...
Thanks........
Posted on Jun 20, 2008
  • 7 Answers
SOURCE: I Need a power supply for a logitech,momo,ffb wheel.
Contact Logitech and they will ship you one for a charge.
Posted on Jan 29, 2009
SoundMan1961
  • 10 Answers
SOURCE: Need power supply for Logitech Momo Racing Wheel
Power supply is 1/4" 24 volt dc (center pin positive) at 0.75 A.
GL on the allthread post.
Posted on Oct 23, 2009
gripfitter
  • 557 Answers
SOURCE: Turning on a Liteon power supply without being hooked up to compu
On the main plug there are several black wires(ground), and one green wire. Jumper any black wire to the green wire and there you go.
Posted on Dec 14, 2009
Testimonial: "Your solution worked perfectly Thank you very much Bill"
  • 1027 Answers
SOURCE: cannot locate the fuse in the liteon power supply
The fuse is internal, and soldered to the circuit board. It can be replaced by soldering - an old-timers trick is to get a new fuse (with pig-tails) and just solder in parallel with the old - no removal needed.
Posted on Jan 31, 2010
Trips after one minute- green indication of power supply turns to red
That doesn't sound good.
You should check if the outlet have over 240V, in that case, you should NOT use that outlet. If not, it might be the power supply that doesn't have enough resistance (electricity blockage that stop the console from being "overpowered") , and you should might get a new power supply.
Jan 10, 2013 | Microsoft 175W XBOX 360 Console AC Adapter...
Cannot locate the fuse in the liteon power supply
Jan 31, 2010 | Lite On LiteOn 150W LPX Power Supply...
Dec 13, 2009 | Computers & Internet
Computer does not turn on
you can try your power supply if it works by jumpering its pin. try to insert copper wire in pin 11 and connect it to pin 12. and turn o your power supply. But if it won't works then used tester and test its circuit boards particularly  is capacitors, resistors and even the transformer inside the power supply. Or if you can't make it then you can call a technician either in computer or electrical to test your power supply if it still working or not. In that wy can be sure in making decision if its really your power supply got problem or not.
Thanks
Jun 26, 2009 | Lite On (PA41519B1) 150-Watt Power Supply
Cable/Transformer for Quantum Server 1000
I've got the same Snap Server 1000 and lost the supply some time ago - I found a LiteOn monitor supply model PA-1400-02 does the trick and fits exactly.
Spec is 3.33A 12Volts DC out, positive inner, negative outer.
Hope that helps.
Jan 19, 2009 | Quantum Snap Server 1000 (5325301081) 10...
Acer aspire computer with liteon power supply PY300B00153201AA6E
power supplies are easy to replace. usually 4 screws. open the pc. remove the screws and unplug it from the motherboard. a replacement costs 40-60 dollars. plug it into the same place(s) you unplugged the original pwr supply. replace the screws. replace the cover and thats it.
Jan 08, 2009 | Lite On LiteOn 204Watt PA-4022-6B Power...
Replacement filter pb assy
have you tried jvc?
usually only certified service centers can get the parts through an account
or try an electronic parts supply store that might deal with them, though I have not found that they get stuff like that just the components
Oct 20, 2008 | JVC GD-V4211PCE 42 in. Plasma Television
What voltage is the dc adapter?
You will need at least a 4 amp rated regulated 12 Volt power supply.
These are commercialy available from most electronics parts suppliers.
They come on a circuit board. You can mount it in your own case and
use the original Viewsonic wire end. If you do a google search for 12
volt reglated power supplies you should find many of these.
However, with a second-hand Sprint AC adapter with 3A,
12v adapter, the screen blinks on and off
intermittently. Obviously there is some difference here between a class
2 adapter and a power supply box.
Oct 03, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
No power.
Usually, in those Sony sets, a crack developes on a small transformer in the horizontal drive circuit, which causes the horizontal output transistor to short. This immediately shorts out the switching transistors in the power supply and blows the Sony 0.1 ohm resistor fuse. A shorted flyback (high voltage) transformer will also have the same result. The power supply does NOT need to be replaced. The parts should be replaced, the flyback checked and the board resoldered by a qualified tech familiar with Sony sets.
Aug 23, 2007 | Sony KV-32V35 TV
Televison & Video Logo
136 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
