Bikemaster 1981-1996 Yamaha Xv750 Virago All Motorcycle Deep Cycle Gel Battery Logo
A
Anonymous Posted on Jul 19, 2014
Why do i have petrol in my engine app 6 lts xv750
paul
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Bikemaster Master 1,190 Answers
  • Posted on Aug 13, 2014
paul
Bikemaster Master
Level 3:
Renaissance:
Answers
1190
Questions
Helped
263825
Points
1883
Carb flooding ! clean it !
Where is the fuel pump relay on a 2010 vw eos?
which engine (size etc)
what country?
lost the uses guide, see fuse relay page there.?
7 drivetrains (sorry canT guess them ever me)
and all this.
1.4 L I4 (petrol)
1.6 L I4 (petrol)
2.0 L I4 (petrol)
3.2 L VR6 (petrol)
3.6 L VR6 (petrol)
2.0 L I4 TDI (DIESEL) TURBO
Transmission 6-speed manual
6-speed automatic (DSG)
to fix your own car DIY, LEARN WHAT THERE FIRST AND TELL IT.
How to service my son 2005 Kia Picanto A Part list would be great plz
if its a 1.1 diesel
5.3 lts oil
climate cold-5w40
moderate-10w30
hot-15w40
oil,air,diesel filter
pollen filter
if its a 1.1 petrol
3.3 lts oil
climate cold-5w30
moderate-10w40
hot-20w50
spark plugs-NGK BKR5ES-11
gap 1.0-1.1
oil,air,fuel and pollen filter
11helpful
Whats is te cylinder heads torque for suzuki aerio 2.3 lts
Hi! Please don't forget to rate! Thanks!
Cylinder head bolt torque sequence-2.0L and 2.3L engines
Apply engine oil to the bolt threads and tighten the cylinder head bolts, in sequence, using the following 6 Steps:
  • Step 1: 38.5 ft. lbs. (53 Nm)
  • Step 2: 61 ft. lbs. (84 Nm)
  • Step 3: Loosen all of the cylinder head bolts
  • Step 4: 38.5 ft. lbs. (53 Nm)
  • Step 5: 76 ft. lbs. (105 Nm)
  • Step 6: Bolt M6 (bottom left of cylinder head) - 8 ft. lbs. (11 Nm)
How do you set air and gas on a carborator for a 1982 yamaha motorcycle its an xv750
Go to this website
http://www.viragotech.com/XV750/750viragotechinfo.html
What you want & much more for the XV750
1helpful
Torque waterpump bolts mercedes benz
Torque wrench settings Coolant pump to crankcase/timing cover: 4-cylinder petrol engone 10( Nm) or 8( lbf ft) 6-cylinder petrol engine 23 (Nm) or 17 (lbf ft) Coolant pump to housing (Diesel engine)10(Nm) or 8 (lbf ft) Coolant pump to belt pulley: 4-cylinder petrol engine 15;11 6-cylinder petrol engine 10;8 Diesel engine 15;11 Cooling fan to electromagnetic/viscous MB(try not change pumu but viscous coupling Mercedes became cool) coupling: 4-cylinder petrol engine 25;18 6-cylinder petrol engine 10;8 4-cylinder diesel engine 25;18 5-cylinder diesel engine 10;8 Viscous fan coupling to coolant pump/bearing body 45;33 Electromagnetic coupling to coolant pump / support bracket 6;4 Radiator drain plug 2;1 Thermostat housing to cylinder head (4 cylinder petrol engine only) 20;15 Alternator mounting bracket bolts 45;33 Cylinder block drain plug 30;22 Automatic transmission fluid cooler unions 20;15
Radio fuse
# 18 for radio and it is a 20amp...see below for all #'s got to and amps... 1-20amp-pwr outlet frt. 2-10amp-rear fog lights(export only)
3-15 amp-horn 4-10amp-hedlt low beam rt
5-10amp-hedlt low beam lft 6-20amp-bodycontrolmodule/pwr dr locks 7-spare 8-spare 9-10amp- rt pk lt /rt tail lt/trailer tow lt/cluster
10-spare 11-15 amp-flasher 12-15 amp-stop lts
13-10amp-bodycontrolmodule/cmtc/cluster 14-spare
15-10amp-pdc fuel pmp & auto shutdownrelays/skis
16-20amp-pwr outlet rear 17-15amp-rear wiper 18-20amp-radio choke relay 19-20amp-frt fog lts/trailer tow stop and turn lts
20-20amp-sunroof 21-spare 22-10amp-wiperswitch/frt and rear washer 23-10amp-lft park lt/lft tail lt 24-10amp-pdc blower motor relay 25-10amp-heatseatswitch/hvac controlhead/trailor tow battery charge 26-10amp-hedlt highbeam rt 27-10amp-hedlt highbeam lft
28-spare 29-15amp-heated seat module 30-10amp-heated mirrors/rearwindowdefrosterindicator 31-20amp-cigarlighter
32-10amp-radio/frtdoorlockswitches/bodycontrolmodule
33-10amp-skis/diagnostic connector 34-15amp-cluster/courtesy lts/radio/bodycontrolmodule/maplights/cmtc/underhood lt/vanity lts
35-spare 36-10amp-ignition run/start-orc/lft and rt siacm
37-10amp-ignition run only-orc 38-10amp-abs module/brake shift interlock solenoid 39-10amp-rear window defroster relay/flasher/backup lts
2answers
I don't have an owners manual and I need a fuse diagram for my 2002 jeep liberty
There is normally a diagram printed onto the the inside of the fuse case.
Top Bikemaster Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Bikemaster Boating Expert? Answer questions, earn points and help others
