Question about Koss (10-16-004) Headphones
No sound in right Koss HV/PRO earphone
There is no sound in right earphone. Problem seems to stem from volume control located on cord. Before sound completely stopped in right earphone ( the sound would come & go ), I had to 'wiggled/move' the cords connected to the volume controller in order to get sound to return. My problem is that I don't want to damage the volume contol box when I open it up. I am looking for a simple solution on how to open the case without damaging the unit further.
2 Suggested Answers
Grubhead
  • 5515 Answers
SOURCE: Product KOSS UR15C headhones.
I'm afraid there's is no easy way of doing it, most headphones I have fixed needed force to get the pads of and for that matter to put them back on! It's just a case of taking great care and easing it off a bit at a time. If you encounter any foam that can be glued on afterwards with Bostik solvent free all purpose glue.
Posted on Apr 09, 2010
MacBook Pro mid 2011 AUX input dose not work with my headphones.. please help me.. :(
Its very rare a mac has sound problems. Some earphones consume batteries, does yours have batteries in it? and is it powered on while connecting? With the earphones connected, check system volume and increase the sound while playing music. If there is sound coming from the mac itself then there maybe an issue with the AUX connection. Possible dust blocking the port. Clean it and try again. If there is no sound coming from the mac itself while the earphones are connected, then the AUX port is connected to the earphones and is in good working condition. Increase the volume on both devices, the mac and the earphones, if it has this feature. If there is still no sound, there may be a problem with the earphones itself. Possibly bad wires already, connect the earphones to other devices and listen for sound. If still no sound, replace earphones.
Oct 17, 2013 | Apple MacBook Pro MB991LL/A 13.3-Inch...
How do i increase microphone volume on bck08b?
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
hope this helps
Jul 02, 2012 | Computers & Internet
Have Koss hd-50 (hand me down) would like a diagram, have no sound, running winxp on dell xperion 8400, says "no active mixer devices"
i will go through the process of setting up sound on your computer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
if you need more help with this post a reply
hope this helps you
Sep 21, 2011 | Koss HD 50 Computer Speakers
I have a set of Koss SXM 30 computer speakers which do noi work on my present computer HP p6 144f PC. I can not find the driver
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
Dec 20, 2010 | Koss SXM 30A Computer Speakers
Product KOSS UR15C headhones. Problem: short in the cable which causes sound cutout when moved. Its right at the connection to the earphone. WHAT I NEED TO KNOW: How to take the earphone apart...
Apr 03, 2010 | Koss (141283) Consumer Headphones
My old KOSS TD/60 Stereophones have a broken cable right near the earphone entry point. How can I open the earphone to repair or replace the cable?
I figured that that the earphones were pretty old, so if my 'repair' didn't work I would just replace them with new ones. There is a groove filled with acoustic foam that runs right around each earcup that terminates at the cord's entry point. After removing the headband yoke by carefully popping it out of each earcup I simply gripped both sides of the earcup and applied outward pressure until the front and back halves separated. Fortunately they are held together by plastic clips that snap apart. Once I had located the fault in the cable and repaired it the earcup halves easily snapped back into place. I now have a functioning set of headphones again!
Apr 22, 2008 | Audio Players & Recorders
Koss Pro-4AA
Don't bother, Koss has a lifetime replacement policy on some headphones like the Pro-4's. All you pay is shipping. Call the repair department.
Feb 25, 2008 | Koss PRO-4AA Consumer Headphones
No sound in one ear
Have the volume control to be repaired, they a cellphone repair shop. If they can't... suggest to bypass the volume controls to its maximum control and buy an earphone that has volume control on it.
Jan 02, 2007 | Aiwa CR-LD120 AM/FM Radio
Koss (10-16-004) Headphones Logo
137 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
