Question about Nokia 1661 Cell Phone
Phone does not have a ring tone every time i try to set one it shuts off then restarts
Restore factory settings with code 12345
Posted on Jul 11, 2009
I have the same phone with the same problem... fix it by reseting to factory settings... pass code was 12345.
Posted on Jan 04, 2010
5 Suggested Answers
  • 3 Answers
SOURCE: My Nokia 1661 will not produce an audible ring
All phones have an option to reset to factory settings inside the menu somewhere, not sure if this will fix the problem?
Sometime different profiles are set funny like the ring volume being set low, maybe try a different profile?? hope this helps.
Posted on Oct 07, 2009
vrabhilash
  • 52 Answers
SOURCE: my phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Posted on Jul 17, 2008
  • 12 Answers
SOURCE: No ringing tone for nokia 1650
Any phone that turns off during performing a setting has a deffective software,if under warranty swapp it with your manifacturer, if out of warranty just purchase an other one from wallmart1
Posted on Sep 08, 2009
If i want to enter ringing tone and to select the phone will off and restart
hi there!
the phone goes off and restarts by itself when you try to choose/set a ring tone? its possible that the ring tone file is missing or corrupted. or if that ringtone came with the cellphone when you bought it, try removing the battery for a minute, put it back in, turn on the cellphone and see if the same issue happens, you may wanna have the cellphone look onto by a technician because its already a hardware issue i believe =)
Apr 06, 2011 | Computers & Internet
Tip
How to set ringtone when unable to set in Nokia 1200,1202,1203etc.
This trick is very easy but we could not discover.Here follow the instruction step by step First power on the phone, press menu and select setting in sub-menus. Then press "RESTORE FACTORY" reset it by entering 12345 (default code) or the code you have already modified!!!!!!!! ha....ha.........Before restore factory you have seen that there was no tone displayed in ring tone setting sub-menu besides when you try to set the ring-tone suddenly the phone shut down and automatically power on itself.....No tension no upset entertain the lovely NOKIA tone.........
on Aug 07, 2010 | Cell Phones
No ringing tone while getting call from somebody also when I goto setting to change ring tone I can not play any of tones and I ca not close the window as well and I have to restart manually .
Possible that there are errors in your software. so remove the battery and memory card. scan your memory card for virus or corrupt files. If not format the card.Now reset and start the phone , if there is no change in your tone settings, the the software needs to be reinstalled.
Please make sure that a recently downloaded music file or ring-tone has caused this breakdown , if so remove the file and try once again.
Jan 22, 2011 | Cell Phones
I get no ring-signal when I have an incoming call. When I try to choose signal in the menu the phone restarts.
hi,
your phone have a software problem, it will fix by a certified technician in nokia care center by programming it...just pay a little amount of money..but wait ,i have a solution to that you can also fix that without spending a single cents and leaving your home...
procedure...
1.in your phone,go to menu
2.)settings
3.)restore factory settings
4.)enter your security code
5.)wait until your phone reboot..
test the phone ,go to tone settings and choose the ring tone you want..
i hope it will help you ,tested in my cellshop many times...
Jun 19, 2010 | Nokia 1661 Cell Phone
Double ring tone issue
Go to the same place that you go to to put it on vibrate and scroll down to set ring tones/alerts and sms text and change the settings the volume should be set to silent.
Apr 20, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Ring tone volume issue
you can reset your phone setting to original just save your number in simcard and save your important data then put any different simcard and goto menu setting and phone setting then last option factory reset your phone will restart then try ring tons
Mar 31, 2010 | Nokia 6600 slide Cellular Phone
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
Nokia 1661 my phone not ringing why ?
Mar 22, 2010 | Nokia 1661 Cell Phone
My Nokia 1661 will not produce an audible ring tone. When I go to the Settings - Tone Settings - Ring Settings, the phone automatically shuts off and restarts, asking for the security code. When I first...
Oct 07, 2009 | Nokia 1661 Cell Phone
Sep 08, 2009 | Nokia 1650 Cell Phone
Nokia 1661 Cell Phone Logo
372 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
