Question about Kenmore Dryers
No heat, motion, but light is on and timer ticks
My Kenmore Extra Large Capacity Dryer(front loader): The drum does not move, the heat and blower do not come on, but the light is on when you open the door. The timer is clearly ticking when you turn the dryer switch. It is 12-13 years old. Please help. Never had trouble like this with my dryer. -Amy
  • 999 Answers
Check the thermal fuse on the blower housing. It is for over heat condition and non resettable.
eric
Posted on Jun 30, 2009
The dryer drum does not turn, but the motor runs
Check belt. Will require some disassembly
Apr 15, 2018 | Dryers
My dryer sounds as though there is loose change bouncing around inside but after checking inside the drum i find nothing. what could this be?
did u check the baffles? u would be surprize what can get in there I even found some coins a couple times? are u sure the noise is not from the blower housing beneath dryer
Sep 21, 2014 | Whirlpool Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
How to check and replace dryer's heating element for GE 5.8 Cu. Ft. 3-Cycle Extra-Large Capacity electric Dryer -...
unplug the machine from the wall - open the door and look in the top of the door hole - there will be 2 screws there - take them out and you will be able to lift the top off - the heating element is located behind the drum on the rear wll of the cabinet - use an Ohmmeter to test the element for continuity - if it is open - you will need to remove the front of the dryer and then the drum to replace the element - if it is continuituos the problem may be a fuse or thermostat or broken wire or an open timer
Oct 01, 2011 | Dryers
I have a Kenmore 70 series large capacity front load dryer. It will heat but the drum just stopped turning. I do not believe it is the belt. You can turn the drum with your hand very easily and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2011 | Kenmore Elite HE4 Electric Dryer
I have a stackable kenmore washer dryer heavy duty extra large capacity 2 speed motor. The dryer has been making squeeling noise and has stopped toumbling around what can the problem be.
Could be the belt which connects motor and dryer drum. Could be the drum support rollers. Replace both either way -- common problem.
Jun 03, 2011 | Kenmore Dryers
Dryer Maytag LDE 9316 ACE -what is the capacity of that model dryer? Thank you!
Capacity is a key consideration when shopping for a dryer. The more you are able to dry in a single load, the less time and money you will spend doing your laundry. Most importantly, look for a dryer with approximately twice the cubic foot capacity of your washer.
Typical dryer capacity ranges from approximately 3.4 cubic feet (for a compact model) to over 7 cubic feet for an extra large capacitor
In addition to saving time by drying on fewer loads, and money on lower energy costs, a large capacity dryer often means spending less time once the laundry is dry. There is typically less wrinkling when clothes have more room to move around inside the drum.
Whirlpool brand offers dryers with a range of capacity and flexibility.
Dec 16, 2010 | Dryers
Dryer has no heat.
the heating element has probably burned open.
pull the element out and you'll probably find the break in the heating coil.
or possibly one of the leads going to the element has burned open.
good luck.......jay
Mar 21, 2009 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
Dryers Logo
79 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
