Question about Kenmore Refrigerators
I have a kenmore refrigerator model 36369262991. I have water accumulating on my top shelf. It drips from the thermostat control panel. what is wrong?
    Problem Solver:
  • 6 Answers
I had a similar problem on a Whirlpool Fridge. In fact, there is a good possibility that your Kenmore is made my Whirlpool. As you probably know, Sears doesn't make appliances, but contracts with well-known appliance makers to manufacture kenmore-branded products.
If your fridge is an auto-defrost model, whenever it auto-defrosts, water from the melted ice collects in a tray behind the freezer, and drains into an evaporation tray at the bottom of the fridge through a drain tube. Over a period of time, the drain tube can become clogged, and instead of draining out of the freezer, the water overflows into the fridge. The clue is that the problem is intermittent -- the dripping stops between defrost cycles.
The fix is to remove the liner panels from the freezer, melt and sponge out any collected ice, clear ice from the drain with hot water, and clear any gunk from the drain tube with compresssed air or a flexible "snake." I used 1/8" pvc tubing as a snake.
It isn't hard to do, but if you are nervous about disassembling parts of your fridge, you will need to get a pro to do it.
Posted on Jun 29, 2009
Why does water in the fridge keeps accumulating
It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents into the fresh food area. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube. You may want to place a small tub in the top shelf to collect all the water that will pour through the vents and have some towels. it can get very wet.
Some models have a drain collector in the control panel assembly at the back and this runs into a drain grommet. this collector can plug up. You will have to remove this and clean out the collector tube.
I have found that some Frigidaire and some of the Kenmore refrigerators made by Frigidaire have a problem with water droplets accumulating in the air duct and when it defrosts thee droplets run down and drip into the fresh food section.
Aug 15, 2014 | Refrigerators
Water dripping from freezer department into refrigerator department, coming in from around the fan in the top of the refrigerator and dripping onto the top glass shelf. could there be something clogged up...
9 times out of ten that is your problem. You need to pull back panel off of freezer and check drain. Also the thermostat control panel can be removed to checj=k the catch panel in there.
Jan 09, 2010 | Kenmore Refrigerators
Kenmore refrigerator 106.72206201 - accumulating ice and water
Probably a clogged drain line in the freezer. Unplug it for 2 days and leave it open. Reset controls to 3 and C or factory settings clean the coils on the bottom outside with a vacuum and a brush and restart the fridge.
Sep 11, 2009 | Kenmore Refrigerators
Water is collecting on the top shelf.
You will have to empty your fridge and remove the back panel.clean it out by pouring warm water mixed with Baking soda into the drain at the back of the freezer compartment and let it drain into the drip pan at the bottom of the refrigerator. In the refrigerator section, find the screws that hold the control console securely to the roof of the refrigerator. Usually there are two of them towards the front. The front part of the panel will drop down and then you will see a plug to separate so now you can remove the entire control panel and sit it on the floor or kitchen table. Now you will see the hole going into the freezer section and the other hole going to the defrost pan under the refrigerator. I am suspecting the tube on the rear of the console which is on the floor or the table right now is either cracked or not fitting snuggly in the hole at the rear of the refrigerator. If you do not find any cracks, take some putty and wrap it around the end of the tube and then reinstall the console/control panel making a secure and tight fit into the hole.
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerators Logo
298 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
