Question about Mtd Garden
Old Yard Man Rider-squeals when the key is turned on? Ran fine up until, I tried to start it this morning, checked the plugs, lines etc! Sounds like a car that is already running, and you try to turn it over again....That screach....
  • 376 Answers
Check the gear on top of your starter. Sounds like it may be stripped out.Let me know
Posted on Jun 29, 2009
2004 Yard Machine Rider is backfiring through carb any solution? I've tried replacing the plug,checked the key and cleaned out carb bowl.It was running fine then this happened.
Hi, check and adjust the valve clearences. When you do this take the piston 1/8 inch past top dead centre on the compression stroke and check the clearence, it should be around 5 thou on the inlet valve and 7 thou on the exhaust. regards Phil.
Jul 02, 2012 | Garden
Yard works mower wont start
check the fuel filter if not you need to clean your carburator
May 02, 2012 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
My wife was driving my 95 monte carlo and it ran out of gas added gas but still did not start tried starting fluid still nothing changed the fuel pump and fuel fillters still nothing The battery has been...
turn on the key (not cranking) and push in the pin in the fuel line valve to see if you get a steady stream of fuel (use a rag to stop the spray for getting all over)-this will bleed the line of air. you might have to remove the plugs to check for flooding too, dry the plugs off if they are wet.
May 23, 2011 | 1995 Chevrolet Monte Carlo
I have a 2001 IS 300 with 160,000 mi. I was having trouble starting the car in the morning where it would take 2 or 3 tries to get it to turn over. It is in a garage in California, so not in extreme cold....
try if this works\improves your situation;
turn the key to ON but don't crank, let it sit for 2 seconds. Do this 2-3 times, then put it in the ON position, wait 2 seconds then crank. As for what it is, could be spark plugs, fuel pump\line issue, etc..
Jan 04, 2011 | 2002 Lexus IS 300
Yardman 6.5 HP XL 21'' CUT S/N#D06786CN
See if it will start with a little splash of fuel down the carb.
If it starts for a second you probably have a plugged main jet.
The mowers collect a little bit of fuel in the bottom of the carb and then water comes along and it makes rust and gunk and turns the brass stuff all green. You remove the main jet and clean the two holes on the bottom and the little tiny hole at the top of the threads *(you should wire brush the threads and get a tiny piece of wire strand to clean this jet.)
I know you ran the mower till it ran out of gas....but that was only till it ran out of enough gas to fuel the main jet. There was still fuel residue in the fuel line and the bowl.
This should be a fast fix though. Good luck and be careful!
Jul 18, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Transaxel broke & I replaced with new. Now engine won't start, just clicks. Battery is charged. Ran fine until axel broke
check the wiring under rider possible hit and disconnected or damaged wiring also check connections at battery -also check fuse by solenoid and solenoid
Jun 09, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
1994 Camry won't start. Have replaced the fuel
Sounds like a relay or sensor. It could be the Crank Shaft Position Sensor which is usually the culprit.
Do you have any check engine lights on? If so, then I would have codes read right away to determine exact problem location
Aug 05, 2009 | 1994 Toyota Camry
Mtd rider trans belt will not stay on
it sounds like the spring got stretched or came loose. or wrong belt or the dowl pins around the pully came off?
May 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
104 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
