Question about Kenwood Protalk XLS TK-3130 (2 Channels) 2-Way Radio
Yaesu FT-727R Hi,I have not used this unit for several years and have purchased a new battery which I have charged but when I turn the unit "on" nothing happens not even a light for the display .Are there any fuses that I should look at??Pls advise.John
  • yobicamo Nov 08, 2007
    There seems to be another internal battery ( aButton type) CR.... which I will replace and hopefully the unit will work.
  • Joseph Crocker
    Joseph Crocker Jun 10, 2017
    If the memory battery dies you will have to enter code for reboot. with the blank screen displayed enter 443300 then should come to life or for extended rx-tx enter 001111. at least until the battery pack is removed.
  • 21 Answers
That second battery is the memory battery for the memory chip in the unit. It is more like a watch batter y. It lasts longer but needs replaced from time to time. Hopefully replacing that should get er going.
Posted on May 11, 2009
    Brigadier General:
  • 6,966 Answers
The Yaesu FT727R does not have any internal fuse that I know of. Straight from the Battery + terminal it goes to the on/off switch (that is coupled to the volume control). From the switch it goes to circuitry (PCB). Incidentally, it is the battery that normally has a thermal switch/fuse that cuts off when a certain temperature is reached (when charging).
Other than check the battery terminals/contacts for corrosion and do a little abrasive cleaning, am afraid you'll have to open the unit for a look and see. Should you be interested, a schematic diagram is available here.
Good luck and kind regards.
Posted on Nov 08, 2007
  • Louie  Role
    Louie Role Nov 09, 2007
    Copy that, its the memory battery CR2032 3V Lithium battery.
  • Louie  Role
    Louie Role Feb 01, 2008
    Hi again yobicamo.
    Any developments with your Yaesu FT 727R?
I need a new battery for a yaesu ft 26
Try "Batteries Plus" either online or possibly a local outlet. I found the batteries for my FT51 there and half the price of the factory ones.
May 19, 2010 | Vertex FNB-27SM,...
Yaesu ft-50r HT getting very hot and not charging battery
From the description your battery has one or more shorted cells. Replace the battery.
Mar 15, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu FT-11R amateur radio squelch problem
It sounds like perhaps you have CTCSS turned on so it's blocking received signals that aren't using sub-audible tones. Make sure the "TSQ" indicator is not showing. Most Yaesu radios have the SQU or "T.SQ" option easily found in their menu structure..
Nov 12, 2009 | Vertex FNB-38, YAESU,FT-11R,FT-41R,FT-51R,...
FT-11r no longer powers up with a known fully charged battery ? The battery was left in the unit a couple of months with a discharged battery. Could this have damaged the unit ?
It's unlikely leaving the battery pack attached ruined the radio, unless it leaked and corroded the contacts. Be sure they're clean and bright. Double check to be sure the battery pack really is charged to rated voltage.
Oct 09, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Battery will not stay charged Acer one will perform perfectly with the battery charger, the computor will not turn on with out the charger. I installed a charged battery and the unit works as advertised....
Before you replace the battery, put the charged on back in again to see if that on charges. If it does then the original problem will have been a defective battery.
Regards.
Aug 20, 2009 | Acer Aspire One AOA110-1588 Notebook
FT-10R will not turn off, the only way is to remove the battery
I t sounds as if you have a faulty on/of switch check it out with a meter or a bad connection around that area.
good luck John
Apr 27, 2009 | Vertex FNB-40, YAESU,FT-10R,FT-40R,FT50,...
I need a memory battery for a ft 50r both sides are sorderd the main board
I just had my FT-50R repaired due to a overheat issue with a reverse polarity diode. When I asked Yaesu to alao check my Yaesu for the memory battery I was told by their top technican that the radio does not have a memory battery in it. I hope this helps.
Apr 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu VX-3R ham radio will not turn ON!!!!
Even though this is several months old, I thought I would post this reply. I had the same problem when I ran the battery completly down. The charge light didn't come on and the unit would not turn on with the power or battery. Sent the unit back to Yaesu for warranty work and they replaced the switch board. Unfortunately after I got it back and ran the battery down again..... Well, it's back at Yaesu AGAIN! Looks to me like there could be a problem with the power circuit being overloaded when it tries to charge the flat battery!!
Nice little rig, but it may be for sale once I get it back!!
Mar 29, 2009 | Radio Communications
Yaesu Ft-50 hard to turn on
The rubber power button is impregnated with carbon and when pressed, it makes contact with two points on the printed circuit board, turning on the radio. This button eventually wears out and needs to be replaced, which is a rather easy process.
I've performed the operation four times - takes about 15 minutes. The button is available from Yaesu.
I also tried "repair kits" for these buttons which are supposed to replace the conductive surface. Both times, they failed again within a couple of weeks.
The upside is the new button is not as quite as tall as the original and requires depressing it below the surface of the case to switch, which prevents accidently turning off the radio.
Good luck, and 73
DE NøAWN
Mar 17, 2009 | Yaesu NABC NABC LMR NICD BATTERY FNB-V47...
Yaesu FT-50R battery drain
scotwho, I personally do not know the radio you are asking about, but I do have many years working with radios in troubleshooting. What I am guessing is, if the heatsink gets hot, then whatever is connected to the heatsink has shorted out. Two main parts come to mind here, and that's the audio chip, and the transmitter output final/chip. Possibly the main IC (brain) that controls most everything, but I doubt that. The radio needs to go to a repair shop that can troubleshoot the damage/ and find an answer as to why it occurred. A lot of times the factory's do not use heatsink compound when they assemble the units, and after an x amount of time the part/parts will fail. 10cents worth of heatsink compound can make a radio last a few years longer.
Probably not the answer you wanted but I hope this helps,, let us know. Mechanic
Feb 19, 2008 | Radio Communications
Kenwood Protalk XLS TK-3130 (2 Channels) 2-Way Radio Logo
878 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
