Question about Lexmark X4550 Multifunction Wireless Color Inkjet Printer
Cant set up lexmark x4650 wirelessley, only prints with usb cable
I bought this lexmark x4650 a few months ago and have been trying in vain to make it go wireless. I have used the installation disc and it reaches the point where it asks me to choose a network, which I do (the name of my router). From there is says connection failed and wont go any further. My WiFi light is solid green and the printer is present in my printer folder and selected as default. I can print/scan/copy perfectly fine when the usb cable is attached to the printer and laptop but as soon as I remove the cable is says 'communication not available'. I have spoken to lexmark's online helpdesk twice and they have remotely accessed my computer to try and solve the problem, resulting in one person cutting me off today as she had obviously not been able to work it out.
I dont know if it's something to do with my router as when i access my router info in Internet explorer, my printer is not listed under my network, although my Wii is.
Also, from other notes ive seen, people have been advised to change the printer's IP address. I note that my printers IP address is different to my router (although the SSID is the same) but do not know how to change this manually.
It's like there's a missing connection somewhere but i cant figure out why my router wont pick the printer up. Help cos it's driving me insane!!!
I have the same problem with the same two products ... and I use a Mac. D-Link says it's the printer and Lexmark wants to charge $3.99 per tech support call ... when the deign to provide tech support at all (dramatically limited hours). Solution: Throw the printer away and start again.
Posted on Jan 24, 2010
I recently purchased a Lenovo All in One wireless computer. I've plugged in the USB cable as per instructions but my X4650 printer will still not print.
Have you installed the printer drivers? Is the printer power turned on before plugging the USB cable into the computer? You could have a bad cable. Try a different cable.
Dec 13, 2014 | Lexmark X4690 Wireless InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
I have a Lexmark X4650 and about every 2 inches the print is fuzzy/blurred. How can i fix this?
Some of the ink-jets that shoot the ink onto the paper are clogged.
Use the Lexmark software for the printer to run a few "print-head-cleaning" cycles, to try to unclog it.
Jan 07, 2011 | Lexmark X4650 InkJet Printer
Need illustration of everything that should be plugged in on the Lexmark X4650. Have been fighting this thing to get it to print, for the last week. Thanks.
There are 2 connections that are needed to be done on the printer. One is the AC adapter and the other one is the USB cable that connects to the computer.
mariolands_7.jpg Also you can read about setting the printer up in the User Manual: http://www.lexmark.com/publications/pdfs/2007/4650/v12364191_en.pdf
And you can read here about Wireless Setup.
Dec 02, 2010 | Lexmark X4650 InkJet Printer
Won't print, even when USB cable is plugged in
Do a BIOS update and than do a fresh installation of the printer.
Jul 10, 2010 | Lexmark X4650 InkJet Printer
My grandfather just bought a Lexmark X4650 printer. The problem is that when the printer is plugged in, the computer won't start. Windows begins to initialize, but then it just stops, and a small line is...
the problem i think are the drivers and also in the bios thad are the settings start up pc look first the usb port chanche this in the bios and computer starts from hd or dvd (cd) look also for drivers on lexmark site they are there
Mar 02, 2010 | Lexmark X4650 InkJet Printer
Won't Print x4650
Hi
Here are a few possibilities...
1. Try cleaning the contacts on the inkjet cartridge and where they make contact inside the printer. (use cotton wool and Alchol) if that does not work...
2. Pull out power cable from printer wait 1 MINUTE then insert cable and switch back on again. (some printers reset to factory settings)
3. Remove printer cable from computer... Uninstall Printer driver from computer... Switch off both printer and computer. Wait 1 minute... Reconnect cables and switch on printer and computer... Allow computer to find printer reinstall driver.
4. Try installing old cartridge to see if printer rejects that?
5. You may have a faulty inkjet cartridge (return it to store if so)
You may find more help here...
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 11, 2009 | Lexmark X4650 InkJet Printer
Cannot print with Lexmark x4875, Windows Vista OS.
You need to cancel all print jobs for a printer, you must have permission to manage documents on the printer.
1. Open printers by clicking the "Start" button , clicking "Control Panel," clicking "Hardware and Sound," and then clicking "Printers."
2. To open the print queue, double-click the printer you are using.
3. Click the "Printer" menu, and then click "Cancel All Documents." Depending on the printer, the item currently printing might finish, but the remaining items will be cancelled.
Next, you may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 4800 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
Apr 17, 2009 | Lexmark X4875 All-In-One InkJet Printer
My lexmark 5400 series does not recognize that it is attached to my computer via the usb printer port. it was purchased 8 monthes ago. i installed the the disc. all was good untill 2 months ago. it went...
Yes It might be the case where the USB fails.
But we need to take a closer look on it for proper diagnose. If you can join our premium assistance service, our experts will more likely to work upon the problem and give you the solution.
Let me know if you need further assitance from me. Dont forget to vote me.
Regards Ellin
Sep 24, 2008 | Lexmark Office Equipment & Supplies
Lexmark X4550 Multifunction Wireless Color Inkjet Printer Logo
518 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
