1992 Toyota Previa Logo
A
Anonymous Posted on Jul 19, 2014
Where are the timing marks on a 2.2cc toyota estima lucida "?"
1992 Toyota estima lucida
Richard Warren
Level 3:
Genius:
  • Toyota Master 2,548 Answers
  • Posted on Jul 19, 2014
Richard Warren
Toyota Master
Level 3:
Genius:
Answers
2548
Questions
Helped
640811
Points
6606
If there not on the balancer) it may not have any,only it should T.D,C mark,most car,s are timed by the computer.
5 Related Answers
A
Anonymous
  • Posted on Oct 09, 2008
SOURCE: I have 1992 Toyota Lucida Estima. Petrol.
10W40
Anonymous
  • 405 Answers
  • Posted on Dec 22, 2008
SOURCE: TOYOTA LUCIDA ESTIMA, INSTALL SUNROOF
I have two things to tell you. Most all sunroofs I have removed, you have to remove inside trim arpound the glass and generally have two bolts on each side that hold it in. Be sure and get any glas in tracks out also with a vacuum first then compressed air, you and probably find a cheap replacement for the glass at www.car-parts.com If you need step by step instructions go here, best site to get them, cost twenty bucks though, BUT if you NEED it, it is well worth it. I have nothing to gain for trying to help you. If this doesn't help you as a fixya vote, plaes do not vote on me at all, thans, I just do this for the rating. God Bless and Merry Christmas
Anonymous
  • 2004 Answers
  • Posted on May 14, 2009
SOURCE: engine oil capacity
it's a 4 liter oil
Anonymous
  • Posted on Aug 20, 2009
SOURCE: hi i have a toyota estima lucida diesel and it chucks out smoke.
I have had the same problem and am fairly sure it is the glowplug not working (I haven't tested it yet). The cylinder with the dead glowplug keeps filling with fuel until it gets hot enough to start burning it, in which case it is very rich and therefore smoky. Once it runs for a while it burns the excess fuel off and runs fine. If it were any other cause the engine wouold not retain its normal power etc when hot. The lumpy running indicates that it is related to one or two cylinders only.
Anonymous
  • Posted on Mar 15, 2010
SOURCE: how easy is it to fit a prop shaft coupling on a Toyota
Undo front coupling first and slide shaft towards the rear of the vehicle. Just enough room then to slide the front coupling downwards may need to use hammer on old front coupling.
Replace front coupling. Replace rear coupling.
I am looking for a radiator for a 1992 Toyota Lucida Estima 2tz engine petrol propelled, new or used radiator
If you cannot find one from a dealer, a parts specialist or a scrap/junk yard try some of the Toyota owners forums. Another option is to have the radiator you have professionally rebuilt. However this could be more expensive.
1helpful
2answers
I can't start My car lost my fob to start can I bypass the immobilizer???? Toyota 1992 estima lucida
have you tried using the Key? I do not believe the 1992 has a True Immobilizer for Security. You can get a FOB off EBAY and then bring your car to Toyota and they can reprogram your car to that FOB.
3helpful
I need the timen mark to toyota lucida 92 engine 3c whit turbo to put timen belt on
hey i have timing marks for 3ct 93 estima if you want them ill have to email you can email me at [email protected] there to big to upload on this site.
1helpful
Where is the location of the thermostat of the 92 toyota estima lucida(prtrol),and how to replace it,thanx
it is located in the housing on the engine block where the lower hose meets the engine.
8helpful
Cylinder head torque spec lucida estima 2.2
help cant get a manual for our car, change head but unable to find the torque setting for it, its a toyota lucida estima 2.2 thanks
6helpful
Timing marks on lucida estima 3CT engine
hi the timming marks are on the plastic case thanks brian
1helpful
2answers
I couldn't find Estima. Having problem with my 1992Toyota Estima.
they mean power relay for the glow plugs so it will maintain the current of the glow plugs needs.
2answers
Lucida estima
a lucida estima is a seven seater toyota passenger vechile
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
