Question about Kenmore Washing Machines
My washer is a he5 and display a code of F35 do you know what is that
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
What does F35 code mean and what to do?
  • Run an empty cycle without using any detergent. Often the fault code displays when too much detergent is used and the detergent sits in the drainage system. A cycle without any detergent is often enough to clear out the buildup.
  • 2 Pull the drain hose out of the standpipe mounted to the wall behind the washing machine. Complete a visual inspection of the hose for any clogs. If you see any, remove the screw that holds the hose clamp onto the discharge pump and then force water through the drain hose with pressurized water from a garden hose. Reattach the hose and then run an empty cycle to see if the code goes away.
  • Read more : http://www.ehow.com/how_11368049_fix-whirlpool-washer-f35-code-alert.html
    Oct 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    My whirlpool duet washing machine displays code F35 and won't complete the washing cycle.
    Hello & Welcome to FixYa
    F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
    Kevin
    Apr 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore elite he5 is displaying code f35...can't find find what this code stands for
    Welcome to FixYa.
    The F35 error code on most not all ...Whirlpool built front load washers ( this includes Kenmore, Amana, Maytag, Speed Queen and of course Whirlpool...but will vary slightly based on model number ) indicates the control has detected an analog pressure sensor error...please post the complete model number inside the door opening.
    Whether the sensor is faulty or not remains to be seen, here's what to check first.
    **Unplug the washer from the wall before servicing...safety first**
    This error "F35", can be caused by the air pressure tube between the bottom of the washer tub and the analog pressure sensor, examine by removing the top and back panels and inspect the hose and dome, i.e.
    If you find a cut/torn hose or loose connection in tube, then this is the likely cause the error. If it however appears okay, then you will likely need to replace the analog pressure sensor, i.e.
    As I alluded to though, make sure the hose is clear and not cut and the air-dome at the tub isn't plugged and if not you'll have to replace the switch.
    Let me know how you make out and I'll help further in any manner I can. Good luck.
    Regards,
    Macmarkus :)
    Mar 11, 2011 | Washing Machines
    F35 code
    The following list of codes indicates an electronics communication problem with the washer:
    Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
    Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
    To remove the error display, press Pause/Cancel twice.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    Take care
    Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Code F35 on Kenmore Elite HE5t front loader washer.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
    Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
    I have kenmore elite HE5 front loading washing machine. it keeps flashing F35 during cycle and there is no help in the manual.
    Nov 22, 2009 | Kenmore Elite 45986 Front Load Washer
    Has code F35
    I just got the same error code F35 and sometimes it says SUD. Help pls Kenmore HE5 Steam Washer.
    Nov 14, 2009 | Kenmore Elite 45986 Front Load Washer
    F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
    Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
    Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    I have a Kenmore he5 front loading washer. It
    Jul 09, 2009 | Kenmore Washing Machines
    Washing Machines Logo
    51 people viewed this question
    Sal De
    fordexpert
    Whirlpool
    Whirlpool
